Jumanji..original film..won't backup
Chip9399
#1 Post by Chip9399 » Mon Aug 30, 2021 12:17 am
I’m new to this so bear with me and teach me a couple things, I have been backing up my collection for plex, I just purchased the 3 film collection of jumanji, 2 of the films welcome to the jungle and the next1 level backup fine, but the original will not.. any suggestions? Am I to understand that files have to be dumped for each film to backup???
Using a
LG WH16NS60 with 1.02 firmware,
Re: Jumanji..original film..won't backup
#2 Post by Billycar11 » Mon Aug 30, 2021 3:51 am
full error log
brymer28
#3 Post by brymer28 » Wed Apr 03, 2024 3:15 am
My UHD 4K BD of Jumanji: Welcome to the Jungle (2017) has acted this way for me since I bought it. It will never advance past about 20% or so. It just hangs. You have to cancel the rip to do anything.
Here are the logs from my attempt with a WH16NS60 1.03 (yes, the awesome 1.03) :
#4 Post by Woodstock » Wed Apr 03, 2024 3:21 am
Log not included... Add it in between [code][/code] tags
brymer28
#5 Post by brymer28 » Wed Apr 03, 2024 7:45 am
Attachment adding failed, full log is 1703 lines. I'll have to add 300 lines at a time to try to keep character limit for posting character limit:
Debug log started at Wed Apr  3 02:49:34 2024 , written by MakeMKV v1.17.6 linux(x64-release)
001005:0000 MakeMKV v1.17.6 linux(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file:///home/bmerkley/MakeMKV_log.txt
Network access is ENABLED, CURL version 7.81.0/OpenSSL/3.0.2/1.43.0 (x86_64-pc-linux-gnu) , proxy server not set.
001003:0020 DEBUG: Code 0 at 1x16b4G!]9Eznq-@H9$38R:29393631
SDF  v098: HL-DT-ST_BD-RE__WH16NS60_1.03_212005081010_M68I9IB5756
001011:0000 Using LibreDrive mode (v06.3 id=4083C4CCDB14)
DEBUG: Code 2147483648 at o&Q#{s+fhI7pb-@J:121265499
DISCID=6EE1CE344775A05083BD10010D2E8B987756A426
003307:0000 File 00001.mpls was added as title #0
003307:0000 File 00102.mpls was added as title #1
003025:0000 Title #00604.mpls has length of 16 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00605.mpls has length of 10 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00618.mpls has length of 10 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00619.mpls has length of 16 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00663.mpls has length of 12 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00680.mpls has length of 12 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00687.mpls has length of 12 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00688.mpls has length of 18 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00689.mpls has length of 18 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00690.mpls has length of 18 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00691.mpls has length of 18 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00702.mpls has length of 12 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00703.mpls has length of 19 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00704.mpls has length of 12 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00705.mpls has length of 19 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00706.mpls has length of 12 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00707.mpls has length of 19 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00708.mpls has length of 12 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003309:0000 Title 00711.mpls is equal to title 00102.mpls and was skipped
003025:0000 Title #00720.mpls has length of 16 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00721.mpls has length of 10 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00734.mpls has length of 16 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00735.mpls has length of 10 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00780.mpls has length of 12 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00797.mpls has length of 12 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00811.mpls has length of 12 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00812.mpls has length of 19 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00813.mpls has length of 12 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00814.mpls has length of 19 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00815.mpls has length of 12 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00816.mpls has length of 19 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00817.mpls has length of 12 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00818.mpls has length of 18 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00819.mpls has length of 18 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00820.mpls has length of 18 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00821.mpls has length of 18 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003309:0000 Title 00002.mpls is equal to title 00001.mpls and was skipped
003309:0000 Title 00822.mpls is equal to title 00001.mpls and was skipped
003309:0000 Title 00823.mpls is equal to title 00001.mpls and was skipped
003309:0000 Title 00824.mpls is equal to title 00001.mpls and was skipped
003025:0000 Title #00100.m2ts has length of 14 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00104.m2ts has length of 0 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003307:0000 File 00001.m2ts was added as title #2
003025:0000 Title #00116.m2ts has length of 11 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00208.m2ts has length of 11 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00080.m2ts has length of 13 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00081.m2ts has length of 16 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00099.m2ts has length of 56 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00082.m2ts has length of 10 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00600.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00601.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00602.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00603.m2ts has length of 5 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00604.m2ts has length of 16 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00605.m2ts has length of 10 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00606.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00607.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00608.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00609.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00610.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00611.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00612.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00613.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00614.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00615.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00616.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00617.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00618.m2ts has length of 10 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00619.m2ts has length of 16 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00620.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00621.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00622.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00623.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00624.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00625.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00626.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00627.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00628.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00629.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00630.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00631.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00632.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00633.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00634.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00635.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00636.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00637.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00638.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00639.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00640.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00641.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00642.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00643.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00644.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00645.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00646.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00647.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00648.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00649.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00650.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00651.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00652.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00653.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00654.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00655.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00656.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00657.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00658.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00659.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00660.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00661.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00662.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00663.m2ts has length of 12 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00664.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00665.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00666.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00667.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00668.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00669.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00670.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00671.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00672.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00673.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00674.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00675.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00676.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00677.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00678.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00679.m2ts has length of 7 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00680.m2ts has length of 12 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00681.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00682.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00683.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00684.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00685.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00686.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00687.m2ts has length of 12 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00692.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00693.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00694.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00695.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00696.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00697.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00698.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00699.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00700.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00701.m2ts has length of 10 seconds which is less than minimum title length of 90 seconds and was therefore skipped
005014:0000 Saving 1 titles into directory file:///dead/xcode/mmcdump/sr2
AV sync issues in /dead/xcode/mmcdump/sr2/Jumanji- Welcome To The Jungle.2017.mkv
AV sync in 3 at 0:00:00 (0ms) : 0 frame(s) dropped to reduce audio skew to +8ms
AV sync in 4 at 0:00:00 (0ms) : 0 frame(s) dropped to reduce audio skew to +8ms
AV sync in 5 at 0:00:00 (0ms) : 0 frame(s) dropped to reduce audio skew to +8ms
AV sync in 8 at 0:00:00 (0ms) : 0 frame(s) dropped to reduce audio skew to +8ms
AV sync in 9 at 0:00:00 (0ms) : 0 frame(s) dropped to reduce audio skew to +8ms
AV sync in 10 at 0:00:00 (0ms) : 0 frame(s) dropped to reduce audio skew to +8ms
AV sync in 11 at 0:00:00 (0ms) : 0 frame(s) dropped to reduce audio skew to +8ms
AV sync in 12 at 0:00:00 (0ms) : 0 frame(s) dropped to reduce audio skew to +8ms
AV sync in 3,4,5,8,9,10,11,12 at 0:00:00 (8ms) : encountered overlapping frame, audio skew is +8ms
001003:0020 DEBUG: Code 1073741829 at N]DAZnR|jdbq4LVk:213130559
001003:0020 DEBUG: Code 100864261 at #b[W~AcF~cB0d?gP:121271617
001003:0020 DEBUG: Code 100864261 at N]DAZnR|jdbq4LVk:213130559
001003:0020 DEBUG: Code 100941314 at #b[W~AcF~cB0d?gP:121271617
001003:0020 DEBUG: Code 100941314 at N]DAZnR|jdbq4LVk:213130559
002003:0000 Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '12378568704'
002003:0000 Error 'Posix error - Input/output error' occurred while reading '/dev/sr2' at offset '12378568704'
DEBUG: Code 1073741829 at <mz-%C})09hs`Vw;I^:29394896
001003:0020 DEBUG: Code 1073741829 at <mz-%C})09hs`Vw;I^:213131502
DEBUG: Code 100941314 at <mz-%C})09hs`Vw;I^:29394896
001003:0020 DEBUG: Code 100941314 at <mz-%C})09hs`Vw;I^:213131502
brymer28
#6 Post by brymer28 » Wed Apr 03, 2024 7:47 am
log comment #2
001003:0020 DEBUG: Code 0 at g'i_,^1hF`lAj6ygl'kr:29395471
001003:0020 DEBUG: Code 0 at YMHf%Za'~Mb\_rf1oL*7:29394068
001003:0020 DEBUG: Code 0 at g'i_,^1hF`lAj6ygl'kr:213131157
001003:0020 DEBUG: Code 0 at g'i_,^1hF`lAj6ygl'kr:121262647
001003:0020 DEBUG: Code 6044223 at g'i_,^1hF`lAj6ygl'kr:121261773
001003:0020 DEBUG: Code 0 at Ay!VnHJ"DVdF^7&`C4jH*:213137068
001003:0020 DEBUG: Code 0 at =b>x}Kg}]"4,X)(^C/RD:29394022
001003:0020 DEBUG: Code 0 at =b>x}Kg}]"4,X)(^C/RD:29404878
001003:0020 DEBUG: Code 0 at =b>x}Kg}]"4,X)(^C/RD:29405384
001003:0020 DEBUG: Code 0 at =b>x}Kg}]"4,X)(^C/RD:29403383
001003:0020 DEBUG: Code 0 at dJ#xjuAP^)lYNI+7YCfc:213141208
001003:0020 DEBUG: Code 0 at V4AKLu\uJj.\i2uw:213132537
001003:0020 DEBUG: Code 0 at Gqp4iA(j)9B.`LPDC:29396207
001003:0020 DEBUG: Code 0 at Gqp4iA(j)9B.`LPDC:121264257
001003:0020 DEBUG: Code 0 at Gqp4iA(j)9B.`LPDC:213130490
---- Failed /dead/xcode/mmcdump/sr2/Jumanji- Welcome To The Jungle.2017.mkv
ch_0        1684187505000 0
ch_1        1685133450000 0
ch_2        1686079395000 0
ch_3        1687340655000 0
ch_4        1688286600000 0
ch_5        1689232545000 0
ch_6        1690448760000 0
ch_7        1691394705000 0
mt=0x76bbb59e08b0 n=71
s=0 n=1 o=12378568704
    0 992932 000001  1691394705000       45045000 EAD51881 000000034601100000002040010C01FFFF222000000300900000030000030099350300004E3400075300E8000002A1420101222000000300900000030000030099A001E020021C4D8D35924F841470F1C0903B0E18361A0842F081210088401006E1A306C341085CA0A021044170B02A0AC28035407080E007D02B4180A8200B
s=1 n=1 o=12358785024
    1    490 000001  1691394300000         900000 E73006F1 20F593D8602D607B60A060EF4BC7DDCE35D156985F6521735F484ADD46A01743DC1AAF22CB4E538893DDE71A64B7A077A2B10FCCB2AA1BF5A90AE24D08A0B3F8906E236B237C6D572D206B392F49518CB484F856B3F8E48EE07C78CAB0BA5EBBDB9B3B203F80407195FF8738E17C490D7F8FD2F5472E5D70F465EFE15741CE98
s=2 n=1 o=12370206720
    2   2560 000001  1691400960000       34560000 CD764D7C 0B7789DE2440E1FFCCC03FE7955E1861860EFE153DEAA9BB495E9D18A6D835DEADCC37CF9DA0B895F2B7CADCDA7EF6BA5B0E6156AD5B5C67D5D3A17CFA9429E99D2649C1329B0F2BBDA74DD8DA656CD77DB2BE2E3543B03908C74FA8DAB8962431CF972576969443FBBA397AF76437CA6BBED74A9434CDA6D354AD4D324E2C3E
s=3 n=1 o=12358637568
    3   2560 000001  1691400960000       34560000 21E45A2F 0B77B4ED2440E1FFCCC03FE7955E1861860D72153AD0133B495F56B76CF11FE2D9E5C74F9F4EA682DAB7321AC2A892BA9B70E72A7CF6DBEA5A9FAB4AFAB434CD9EE771D1F26A546BBA7D5DF917E9ACBE7DAA9E54DF6B543292EA8492D44133CBF535AB3E84ED2C2550D4D817597C7A35DED884FA9BA7D1E139AD0ABAAAEB9D3C
s=4 n=1 o=12370182144
    4   2560 000001  1691400960000       34560000 5159C9A9 0B7712152440E1FFCCC03FE7955E1861860D72153AD0133B495F56B76CF11FE2D9E5C74F9F4EA682DAB7321AC2A892BA9B70E72A7CF6DBEA5A9FAB4AFAB434CD9EE771D1F26A546BBA7D5DF917E9ACBE7DAA9E54DF6B543292EA8492D44133CBF535AB3E84ED2C2550D4D817597C7A35DED884FA9BA7D1E139AD0ABAAAEB9D3C
s=5 n=1 o=12370575360
    5   2560 000001  1691400960000       34560000 41B9A2BB 0B773CEC2440E1FFC0C03FE3955E1861860EADF3FAD0DFBB514E9575E8F0B9D6AE6AF7D4934DBA2212B7371CC29DADF8D7D0DEC4415AC2D7EE6BAA864693F6CA73BE4D4A0D37E92A217EF9F267696F3E7DBA7B0E6BAA7CF5F438482CA87CF613E52EAA21AD09F41D30E41FD845FBE7BC52CDB50DFBD83B12BEA5C1242AF0B5BA
s=6 n=1 o=12360585216
    6   3904 000001  1691400960000       11520000 FA070C3A 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF440000000024200002200000000000000240000001541A53BD5922C016358B5114E0F739CD6B58D6B18C5AD6B520E6188410CE2F7356A52949424A528C4208421084210CE2F6B54A5292941CC62946210421084210CE
s=7 n=1 o=12360585216
    7   2012 000001  1691400960000       11520000 65867ED3 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF440000000024200002200000000000000240000001541A53BD5922C016358B5114E0F739CD6B58D6B18C5AD6B520E6188410CE2F7356A52949424A528C4208421084210CE2F6B54A5292941CC62946210421084210CE
s=8 n=1 o=12370575360
    8   2560 000001  1691400960000       34560000 8742621D 0B77C5952440E1FFD8C22FEB9D5E1861860DBEDBF869D33B495E15776CE4B9D6AD4C376E5DA8B89698E9B712D74D0620CB6FDD2E7B5AC2A4CA6BBA8E492BF734ABBA53ADCD6AF46BA74CFA8D42496ED77DD0D24967D24C4A942769B5297C9E953953BF5D014AC4C9DE44735D351C0EABA655005EC6C96B56B4FDF3F4B4AB575E
s=9 n=1 o=12370575360
    9   2560 000001  1691400960000       34560000 DCB11CB7 0B7731342440E1FFC8C03FE6955E1861860DBF75954AA01271012EB76CE4BAA639CC6AF0953CC43298E74AD2D27EE9F2A84FA9AE835A22A4CF9ED78E492C3730ABBA7549CE6AF46BA67EF9F8CB096F3E7DBEC86F61A65CF28BF4B00FD384FD1267D45EC3553953E755A16C490EB5754FABA6A4F755784F9D3AA64932654FA1BA
s=10 n=1 o=12370575360
   10   2560 000001  1691400960000       34560000 88622C1D 0B7750222440E1FFBCC03FDF955E1861860DBEDBFACADFBB48FB63E4EDEEA0E0EDCC6A6F9F3CC42EDA7736DD6A7D5D539B059F2A74A61C022E6B42B8492C371B14D34D49D26AD46196A6AC90CB096ED77DBA07F110D74CF9F44889600C790EBAA256A1AB1096E164AB92BFA5514A0B0F9DC17D49FA97D097257EFD1257D6293D
s=11 n=1 o=12370575360
   11   2560 000001  1691400960000       34560000 0A7276C0 0B77381E2440E1FFC0C03FE19D5E1861860BD2B3F854E1C067AEB6B807E44DD8EA92A7EF933CC0E94B07311056B0D61A588594C34B0A1C2A54D4BEAEEA8D77509F534B4DCBEAEE612774FB3527E9AE5C7DC971C4F3534B0DED7AF0DCEFB71153FB33445361EAC550123F76E5DBCC2E6BBA8549F58215D5A5A4AA156AD7DD4373
s=12 n=1 o=12358643712
   12   2560 000001  1691400960000       34560000 1D94C436 0B77691E2440E1FFDCC03FEE9D5E1861860EADF3FAD015A2514DF6B4E8F120B6EDC58A4F9D3D888692B4CC0E5656FA18D7CFE8C4495AC2D7EF6BAB530D25C4C96B42A5ADD8D7E92D52AF4E8EA86FB6707DB97890C75A7AFE6C3A566943AEE6457C73AEA70E12C4CAAD2B7BAD3B890E782674FDABE7D49F53534D53E7D56BC448
s=13 n=1 o=12378568704
   13     30 000011  1692115425000       22522500 2BFB68AC 16000B0780043810038D0000000017000A0100023F02FF02FE0097800000
s=14 n=0 o=12378568704
s=15 n=1 o=12378568704
   15     30 000011  1692115425000       22522500 FD271B5A 16000B0780043810030F0000000017000A0100023F02FF02FE0097800000
s=16 n=0 o=12378568704
s=17 n=1 o=12378568704
   17     30 000011  1692115425000       22522500 2BFB68AC 16000B0780043810038D0000000017000A0100023F02FF02FE0097800000
s=18 n=0 o=12378568704
s=19 n=1 o=12378568704
   19     30 000011  1692115425000       22522500 4DDBD597 16000B078004381003110000000017000A0100023F02FF02FE0097800000
s=20 n=0 o=12378568704
s=21 n=1 o=12378568704
   21     30 000011  1692115425000       22522500 1935AEE0 16000B078004381003150000000017000A0100029F035002440046800000
s=22 n=0 o=12378568704
s=23 n=1 o=12378568704
   23     30 000011  1691980290000       22522500 02D85433 16000B078004381003110000000017000A0100027E02FE02850099800000
s=24 n=0 o=12378568704
s=25 n=1 o=12378568704
   25     30 000011  1692070380000       22522500 922EEB48 16000B0780043810031D0000000017000A0100022D034403250044800000
s=26 n=0 o=12378568704
s=27 n=1 o=12378568704
   27     30 000011  1692115425000       22522500 55D0F3DF 16000B078004381003310000000017000A010001EB034503AA0042800000
s=28 n=0 o=12378568704
s=29 n=1 o=12378568704
   29     30 000011  1692070380000       22522500 1BC3C789 16000B078004381003130000000017000A01000290034402610044800000
s=30 n=0 o=12378568704
s=31 n=1 o=12378568704
   31     30 000011  1691980290000       22522500 7E1ED71E 16000B078004381003130000000017000A0100021F0359034A003D800000
s=32 n=0 o=12378568704
s=33 n=1 o=12378568704
   33     30 000011  1692070380000       22522500 9C26A2A4 16000B0780043810030D0000000017000A010001DD035903BF003E800000
s=34 n=0 o=12378568704
s=35 n=1 o=12361482240
   35     30 000011  1692115425000       22522500 008C4F3D 16000B078004381002B50000000017000A0100027902FF02880097800000
s=36 n=0 o=12378568704
s=37 n=1 o=12378568704
   37     30 000011  1692115425000       22522500 47C0C7F7 16000B078004381003010000000017000A0100020902FF036D0097800000
s=38 n=0 o=12378568704
s=39 n=1 o=12378568704
   39     30 000011  1692115425000       22522500 1A1BE24F 16000B078004381003210000000017000A01000226035203310041800000
s=40 n=0 o=12378568704
s=41 n=1 o=12378568704
   41     30 000011  1692115425000       22522500 0E430B4C 16000B0780043810032B0000000017000A010001BA03580407003F800000
s=42 n=0 o=12378568704
s=43 n=1 o=12358041600
   43     30 000011  1691980290000       22522500 50272E6C 16000B078004381002F10000000017000A010001EE02FF03A80097800000
s=44 n=0 o=12378568704
s=45 n=1 o=12378568704
   45     30 000011  1691980290000       22522500 18333DE1 16000B078004381003090000000017000A0100023403590314003D800000
s=46 n=0 o=12378568704
s=47 n=1 o=12378568704
   47     30 000011  1692115425000       22522500 CFA27D9D 16000B078004381003210000000017000A010002D702EB01E2009E800000
s=48 n=0 o=12378568704
s=49 n=1 o=12378568704
   49     30 000011  1692115425000       22522500 D14371EC 16000B078004381003250000000017000A0100022203590338003D800000
s=50 n=0 o=12378568704
s=51 n=1 o=12378568704
   51     30 000011  1692115425000       22522500 06BA23E7 16000B078004381003290000000017000A010001CE034E03DB0049800000
s=52 n=0 o=12378568704
s=53 n=1 o=12378568704
   53     30 000011  1692115425000       22522500 0BE6A42D 16000B0780043810032D0000000017000A0100025002FF02DC0097800000
s=54 n=0 o=12378568704
s=55 n=1 o=12378568704
   55     30 000011  1692115425000       22522500 B913F79C 16000B078004381003210000000017000A010001E2035903B8003D800000
s=56 n=0 o=12378568704
s=57 n=1 o=12378568704
   57     30 000011  1691980290000       22522500 0283CB90 16000B078004381003170000000017000A010002B002FF02220097800000
s=58 n=0 o=12378568704
s=59 n=1 o=12378568704
   59     30 000011  1692025335000       22522500 B06A7B02 16000B0780043810031D0000000017000A010002360358030D003F800000
s=60 n=0 o=12378568704
s=61 n=1 o=12378568704
   61     30 000011  1691980290000       22522500 DC24E9DF 16000B0780043810027F0000000017000A0100020F02FE035C0098800000
s=62 n=0 o=12378568704
s=63 n=1 o=12378568704
   63     30 000011  1691980290000       22522500 178A3DBC 16000B0780043810031B0000000017000A010002AA02FE022C0098800000
s=64 n=0 o=12378568704
s=65 n=1 o=12378568704
   65     30 000011  1692115425000       22522500 F68740E0 16000B078004381003310000000017000A010002A7035C022E003A800000
s=66 n=0 o=12378568704
s=67 n=1 o=12378568704
   67     30 000011  1692115425000       22522500 53E43287 16000B0780043810032D0000000017000A0100023602FE03150098800000
s=68 n=0 o=12378568704
s=69 n=1 o=12378568704
   69     30 000011  1692115425000       22522500 6CAE763D 16000B078004381003210000000017000A0100027C02F4028B00A3800000
s=70 n=0 o=12378568704
mt=0x76bbb5905f80 n=71
s=0 n=19 o=12378568704
    0 271617 000008  1691304615000       45045000 B2058E8B 00000003460150000000094401C172438D63B240000000084E01010304004080000000151001E0051677085621308E800000030000030003260000B84B1001478400A2CEE10AC426D01FD0AA2A40B5C0DD991B951FB9B5610CC4E22F09F96049294B408683D173E59973AD69981F000A0B6A0B646D11DFC12EB67BDE7F0763AC
    0 271545 000008  1691349660000       45045000 17AD9846 00000003460150000000094401C172438D63B240000000084E01010304104080000000161001E005224BCEE10AC4268E800000030000030003260000B5F01001478400A44979DC215884C0BED3ABD019442F06D4CF148649275FE2E10D3FF42E6C71E47C382B0BECD8722622CD2FE143207FC83CFEA84C47C56F6C81191120DE
    0 594627 000000  1691529840000       45045000 03CC0E35 00000003460130000000094401C172438D63B240000000084E0101030421C080000000200201D0016CFE43310980A74000000300000300000300000300000300000302420001767302014782002D9FC86621307B00AD83E6F153AF6AE69D217E3935248B13745F00CB03EE95AF059825FD309AF881E43344F675D8DCA7A78A86
    0 274198 000008  1691439750000       45045000 EDA97E1C 00000003460150000000094401C172438D63B240000000084E01010304304080000000150001E0057677085621308E800000030000030003260000B7B50001478400AECEE10AC426BE5F9EB4EB616B1148B5474F251714DFE4B740A78D3A3D387C819F241245169AFDBB7C12B5B3C00D2E72E26198E3609BA2A3FA50ABF176B9
    0 271274 000008  1691484795000       45045000 172741B7 00000003460150000000094401C172438D63B240000000084E01010304404080000000160001E005824BCEE10AC4268E800000030000030003260000B8950001478400B04979DC215884C0CA97441E985B7E218A9C71F65C4C38D3593E80F51511B343D42764E558F803D527347ECA6CD274416D2176FB5FF3A2A1E76EE73B9A
brymer28
#7 Post by brymer28 » Wed Apr 03, 2024 7:51 am
log comment #3
    0 590028 000000  1691664975000       45045000 BE8720F7 00000003460130000000094401C172438D63B240000000084E0101030451C080000000200201D00184FE43310980A7400000030000030000030000030000030000030242000174660201478200309FC866213067DF061DD5A5AF2AAE818BFEB6CD02001D3BB93513BCF1EFDE53B330F730A42DCCFFFD434CEED1D6BBB22BBD38
    0 272165 000008  1691574885000       45045000 CCFCA948 00000003460150000000094401C172438D63B240000000084E01010304604080000000150001E005D677085621308E800000030000030003260000BA5D0001478400BACEE10AC426CF37C32F0EFC27C8D205AC3B0145D898A60AA4822C1A00199832418F2F29FB0DF5EBAE9BF9A16D7DEB575710FE97783A985D835B23938587
    0 271278 000008  1691619930000       45045000 E88594A9 00000003460150000000094401C172438D63B240000000084E01010304704080000000160001E005E24BCEE10AC4268E800000030000030003260000BB4C0001478400BC4979DC215884C0D01FBC86FCF8376C2D7058DC080A152E06B995A9E205E5A0933A7EE0D362E55751C5D0C57935087FD527BE8291C54B5438494A8C97
    0 570925 000000  1691800110000       45045000 40590C3A 00000003460130000000094401C172438D63B240000000084E0101030481C080000000200201D0019CFE43310980A74000000300000300000300000300000300000302420001651F0201478200339FC86621306F231B07DB738E9582E9F1B4D808ED9A713EF557FDDBD641C8B684C8D44857F39CCFF82F2B8C223827ABFEF4DD
    0 267494 000008  1691710020000       45045000 0D6CE464 00000003460150000000094401C172438D63B240000000084E01010304904080000000150001E0063677085621308E800000030000030003260000B6F90001478400C6CEE10AC426D01FCFA2DFDDBF10CF2AEBBD981A7FD8C68B8668B3F85A9CF6920CA3480FD1D5C732FCBE3EE71644E60B2398B819E5DA49D32B8CEC06AB9A
    0 263368 000008  1691755065000       45045000 D3665C22 00000003460150000000094401C172438D63B240000000084E01010304A04080000000160001E006424BCEE10AC4268E800000030000030003260000B3FF0001478400C84979DC215884C0D01E948A902D7110739680D603F9CA202786AC2C86D83EA7BCD3290A2B92FE6ED85A58BA4B8489F5187FCBA83B5B491AE63A63C8B6
    0 567379 000000  1691935245000       45045000 A3A6246B 00000003460130000000094401C172438D63B240000000084E01010304B1C080000000200201D001B4FE43310980A7400000030000030000030000030000030000030242000164350201478200369FC8662130C26C1302BCCF7661F5A60ED502A718555B853976F269FBCF8D9B519162853B176CBE2B8F7C5EB224CA46EAFFEB
    0 260559 000008  1691845155000       45045000 771ADE25 00000003460150000000094401C172438D63B240000000084E01010304C04080000000150001E0069677085621308E800000030000030003260000AB3E0001478400D2CEE10AC426BEECC0CA222A3E0B9920EBD19F7E6778D62535C44255A7FB272B921A24E92A465427762BB39D6C08B9AE48E58AA9A562ED41761717E396D0
    0 259072 000008  1691890200000       45045000 4C54E32B 00000003460150000000094401C172438D63B240000000084E01010304D04080000000160001E006A24BCEE10AC4268E800000030000030003260000AC570001478400D44979DC215884C0BC21B616D7FFAF86F755236A9CC16200DB975E2BC1FC52F236FB7D1023DA494664444736211DCF6C93F0CE141805BD84D08F768CD7
    0 552259 000000  1692070380000       45045000 279FA4A3 00000003460130000000094401C172438D63B240000000084E01010304E1C080000000200201D001CCFE43310980A74000000300000300000300000300000300000302420001608C0201478200399FC866213067E2B6071ED6B80AFBF12C87F43B17EB796377783827F0FF0934E403C3AC45E0CD1EC7842AF0DBF22F6C00D36F
    0 253786 000008  1691980290000       45045000 B58D6169 00000003460150000000094401C172438D63B240000000084E01010304F04080000000150001E006F677085621308E800000030000030003260000AC380001478400DECEE10AC426BC21B616B3A567BDA562C45D3DAF8EACFE26B65CFE631AA010BF46A8FB0B749D443D85511FFF8B30D33D7422923645F82EFA124821C403E2
    0 255548 000008  1692025335000       45045000 603E70DA 00000003460150000000094401C172438D63B240000000084E01010305004080000000160001E007024BCEE10AC4268E800000030000030003260000AF360001478400E04979DC215884C0BEECC0CA219E3D23CB2F61AC62D1CE2C96F9F025D381721F26E4A0047E3172A2F81059E2973214C0E944044B64340091B95787BF18
    0 422008 000000  1692160470000       45045000 65D17861 00000003460130000000094401C172438D63B240000000084E010103051140800000001F0201D001D8ABFC856213E8B000000300000300000300000300000300000A380001145902014782003B157F90AC4260820F5ACF18AB87CFA169B21FF092CC4B8942E3B2E7EB6C0FC53415BE63ECED7F161E51D152ECF07D649E5D8833
    0 305885 000008  1692115425000       45045000 B8FF56E0 00000003460150000000094401C172438D63B240000000084E01010305204080000000180201E007425F3B843310988C0000030000030000030036E00000C8BD0201478400E84BE770866213BD64E951CE80A3524CF7B957CB06F14AA0A72A4CFF02A67208289443B6560DB5B02E962C4BE956A097CB636BEF635373D41553A4
s=1 n=48 o=12358785024
    1    488 000000  1691395200000         900000 115C07E4 C0F49400702C607B609F60EE1B81753DE6797807412038B69F6494FAF9867C5BB49F8DEA3E8A36CD341280451A42FCD5B11134C1A413225249121B8583F3679B61418DD06A2BE9B4886DE1E4FE6673A6E2991E18705408EE23CF9E693603EDC3B7083FD65FDA1860357B384FDDA391807E22803B25B2A183A6834B406D4CCE73
    1    504 000000  1691396100000         900000 165FFC55 70FC94287030608260A760F68111DA8ED0C52CFA1915A52DA7BA8FF7723961C51B2B21F2769030AC7A876FAB6BDFC4913C9C90B1AA17E945F7DE20866D007A57BE3902E0588E0FD0707B69FD95BB3AC624E1DA2A0FE3C56C98CCB2C3E40F71F2B08EB95A969F615E2780EE9C12D6CAEF0EB56B1136EC0DD8FD794B6AE30C55D0
    1    500 000000  1691397000000         900000 D2156DA9 20FA9450702E608060A460F478826727463D644B81F157586BB7CF61A9DEE5CB3D889CFC8EA15A12DDBBB9A3AA74B2F3732EBD371BE318A7F75087699D396CEC6E1D3BA1C0C35DE965A5A4EFF634D872C95957CF29497BD942E65373DFCE5642009D0A0F82D88BFD3684BF7972E419F7B155DBE48B4A382682E52E64F28121F3
    1    506 000000  1691397900000         900000 0863334C C0FD9478602E608260A760F72E95D3FAEB301357F0310C0B637DBE511939F4147013B0EE0E010A2E715A7DCFEFC6D7D065D92837C33D393798E8E2BCA2EF6DF87C3F2B3DA29A5FAE858EF52227BA3BBC598270230ADCF5E3A6A62D3EFABAA6F2FB6AF6BBB4406AE02C70CA45556D0AE62A7BB8B0A7673AD5FE8C0ED14DC0944D
    1    504 000000  1691398800000         900000 898CFCD1 60FC94A06030608260A760F640988CF267852733E5CE0D9BB6A594E05B0B34C0EA94DB2696C1272966BB48946078B1CAC3A1657C661AB3EB772B9A642F9FEDCD3419AC81122C99B22A57EAE3B8E10F2747A52558C0CF0F9C3C44E8BE776A94155189D138B480313FC000380D174F1C632F75B653B70F61A7AE6A928CB72CB1AB
    1    496 000000  1691399700000         900000 425BE1E6 20F894C8702E607D60A360F281099296241113B65A64B496EA6DE07287834224BD4AF8622E5FD5768D77A701F8DB8E4D52A9109039CD885878A226828624C38F3F9BDCC2E72352EAFAF8298158267744F939C003F91B31CDB8BAE03B3B625CFB7E8A1770F6204C3D74EB16ED7086B22B2A90E3FA8CC99FB9DB1B66E73FDB435A
    1    484 000000  1691400600000         900000 99A03F69 70F294F0602D607B609F60EC47AA794EE67DE878AFA580D8753F8D35EFC5A77834447B8318D8DC260C42AAD4079AAE2D781E80EB70E93E9B53EF0A655A7C85FD0ED15CE7AC8093CB03D62D95C2D109FAE2ECC69C9DA0DBDC49706E764849948E9E189A00D8FE50A555C7899DD07859859FA03874175E47E2719299048E8F15BD
    1    488 000000  1691401500000         900000 5F3B6EC1 80F49518602C607A60A060EE14B5DB3EE6AD1CE8C88BFFBC984AC7DF76B3AF33B48B551C90CCE8B772341DA55E52A0B3019E3A4BF89C18ACAB6E85B67A698C668140CC7BBAF97F57122BAFAF4ED1E794641E8507135B69AE9CC39A856F301486D9109FC41E8A70829DBF1B1FDFAFE212A1421A68D30674F8B0CDCDD59EEFA614
    1    494 000000  1691402400000         900000 B051852D 40F79540702D607A609F60F1154CACE71517DD5356A9EF2C71C7DEEF6022EF2B8BE3D8BE892DD4CD25FAEC3C6756141D0200A720EDFD40A73A17C19B3626C3DE2C4968F0469D93FC93A7B8F3829B4258CC66FE8635057F02FFD96509961A6D9A27ED496CF2C848DE6987C487F19CC3858CD962C1C7F93E78E98B375AEB3969D3
    1    494 000000  1691403300000         900000 376CAEB8 40F79568702E607D60A260F1475CC61176E1CB608CC8F701FA63AD9980FE1F490500CA0A49DC933DC52103A93BDC2B20EA483F3905CA25A6F88C960F8B8BA9AC6C0E23E93680E367D6D031DB3DC676AD3432EAAE410F01E39F8987AEFA6E6918C0EC6D348000A5851F4AECC7119BC80B9A6B2F0F80D064A642CB3982A9491A75
    1    502 000000  1691404200000         900000 EA1420F5 F0FB9590702E607E60A560F52479CAA230130E17C2AD0262F49ED9ED0A2C437FEF32876A7FA220B0D915F17A69F5D969B930F6BC33F65884F07B16B1C8FC9C1A502E2112046941FBD410250EC2BFA636BF49535DAC1CB3C1DB6146309A7CCC220D292B49D582C82124989154DC4C576ED0548105CA8A5690C467330F3851FC5D
    1    570 000000  1691405100000         900000 33FF402B 111D95B86030608260A760F78111CC79C67683ACD592C4AD23F85816985A922B3F5056B6604E683F7AE08A9EE979AB6A6F29C76056A9B07F1D9D67D416DF9505D69479E72CB675E0B54BF4692448B86298969786CA3992F6E0B30834F5F02BE3D8490E33E1C346FB22007C513367679E78A49C8D491DDF0BE578B9297C4C3AF6
    1    500 000000  1691406000000         900000 B5500589 80FA95E0602E607E60A460F47E91A3F2A55AFE554ADFDCD2D91BC8097CDC5CBF1E2627647368C13231C9C9E94D2ECDF6DEE4B924E2622CBA093452049B23BA9744CC50356A6D319B60B579D4095898BECF4C37932432D95D8D75A949E2BD9ED9444950F80DA036215625CD4D63099672F703690AF2F01EFF77D65FB5D6C0A0D9
    1    496 000000  1691406900000         900000 EC295111 D0F89608702E607D60A260F28109857F3E363D179A3BCC9DBB405E6126FF365A92F4A1430ACAAE367154C16E699C09285EE8CCD3520D1BA434A6D3D62490C5EB04156E813831B3D09942941C910C7AF73B74563DC4BA007D73C671981B0F04013D0340582B808E678084C178849284CE0CBE8F6FC9BCB3272C769FA891F67BE9
    1    484 000000  1691407800000         900000 BE8C2137 80F29630702C6078609D60EC67EBC8B8C6CDD59779D097C9283ACD961B911A2CEC5D2518ED738560DE1DE6A446754536B026755812CBB4CEC67E66C2F3594E6ECF4951CEE6243536FFE62EF531A31A59B367B8905721E546F9573F62B6B7E19AD90014B38044771F74CDE85DB159BB31AC46847169BF399E5B69CE46F16E044E
    1    484 000000  1691408700000         900000 352A54FD 70F29658602C6078609D60EC515B19622519D1DE7BFAF56E8DE33C97D6E4DB6AE86F9E5C3ED9CC465871322BCEBB76BB5CC8773220E303F2C10E38B94B978C0E0A99F8A44AA2679495A5757ED519B8CCA7ED5BCB8D0A872E358DB32C04B5959EAC00768B56952BB78F0C244EA4ED7B5D63998EF155D47FED8F1F1CEDB9AEFFAC
    1    494 000000  1691409600000         900000 5118BD43 30F79680702E607C60A160F11661ADFB398C4CF6CC8E159113D4BFA475CDF9A171C0C4D6947D6AAA1343D0AC35CE4445649663E19CB20D2C1806F1EBA57318E9DDD0DEEA440FF96A43303E0C8DE0F6FBBCACC61C8DA58CB578D958E4B2B270582E76DBDE80008E940DE6FCF6B2241B1E10CEA2AD0788CCE94B4E5D91A3B2BCB9
    1    492 000000  1691410500000         900000 9DE5FE3C D0F696A8702D607B60A160F00C02A0E36A4728F92AA7E047980872EFF8F25BB76A875E30D5999FA0259DC2F0037C93C8DC78483B65F637EACF406ACD9F6B172FAC113F2B85186D9114E16C4F07A1B23C121E579C083CE536359485135E453C8F8C7E880009EA5B94F81039917035BBCC570249FF8C0F2AF4C0455BA055452A0D
    1    492 000000  1691411400000         900000 4F456A32 40F696D0602E607C60A260F02E4F5A33AAA9387383D987AF7E2D88E86581B06095B395C7C920F0BB20A2552E99F3F59766CA5E32C83C8AE97C0570FD0A3ACEC56A40F5196E9A0712E214C0B63FEC4FEC761B2B642399BF88A332EC824F5F112B3995211BC000D8E17A4352C7B3A61E90B7FE1932E1C23E39C363E0C34138B903
    1    524 000000  1691412300000         900000 C91A435E 610696F87031608960AF61008111C238C95E517752F7A13072E27AE9275EC5DADC500D66E5E8945D22B13B4142EDBC621823568D452F56393E169AFE66203FC53159C0AC18A965A2D34E913EF8984D2A664C5CD165BA78BCAC7E4A8FBC0A1B7C69FECD0156DFC34E06AD397409AC8084F12015CA70AB12A459A87DFF381446E5
    1    508 000000  1691413200000         900000 9CBC5DF6 C0FE9720602F608160A760F84D4F8982F0EB3B2D0FD3AD14229539668D06985E709DCAED26CAC913490A642E3EED3320C5DD5861BB58B549E6B98FBA966A14313938C423125B62825E8A538E6834AABCCD824F6B596E5D0E6B99B2ED80D9708D43AC6E792C8A6000E17415D62F5DAB79D13414EB28844D5EC0F752841D488191
    1    502 000000  1691414100000         900000 A2A821E0 A0FB9748602F608160A760F5810993BB046B80F86156CCB3AF1B16CD63D0EA5C190AC1636E47A45138074FA1C86A26CAADC4125A65910BB1CD23505F1C6485074FF7917019B8D2358BDC317A3926765E9ED184368EBB586A18052CE0DA2097FC7430489502CC28004B32804471DBAF5CA37BBC14D0C56C42A26A70B3036C452D
    1    488 000000  1691415000000         900000 BF42DE94 40F49770702C607B60A060EE02F9B09E53433CFB2CF47B0945F72AC6B647A36F17B470B9DCB5CB29B0F27618CFBA03D10DD67DC9E7EDAA4BA83B0678392F748E0622ECE912ABD0943E586D8BD8CDFFA2AB0E6751B87F2F443BD856AE8641C8C74546769C8084C039913C4747821441D7306C56CB15B7CDE7B31BECB44D83A527
    1    484 000000  1691415900000         900000 4992C0F3 A0F29798602C6078609D60EC6EB2530E22DE777E1E8A3CE59BCB07995F299D3FB4C17164255E2D3E38E722BEFCFC23AAA74E52F0CEA3D14B6FC64B2298A6C6DE622D68589F73BE92C8F6EDD7526B94D4F35A1437294C76C6A425AAA6CDF2E27AF3A4F26278256DFAF351FC612ED98DA8322A4B547A490F7E18D7B39505C56921
    1    480 000000  1691416800000         900000 2D3FF11B D0F097C0702C6077609D60EA66715B5DB337D476F31C25A5C31ABA31E0D0B65ABC6B97A67B0B53AC769610735ECF9328C6365AE097EE1BA09BC6E4ACFF86C07A92EBDC286A9510EAADF0DEC374D249A1BB60D1E6D958E3D7165FB754FD2A169AE0002F6372ABF5B925CD19175E6DC2DC6191DDA7B871378337F7BDA17A25DF20
    1    490 000000  1691417700000         900000 ACC04BFF 50F597E8702C607A60A160EF03B720DC3E8FA5360B430EC0C33A39E8CA70261EDB1A6F18014685688AB9C2FBA0CD30612ADA65BCF9A66BC197D279D1A24360528A09552B4E1D4A78D389DE9221E0D06A15A0CCE00CB3E205988A35427CDEBCAC980058AA0CB4D01EF0EE4A82BB8BF0E5F32A2EDC712B259447A7E173A9760CB9
    1    492 000000  1691418600000         900000 A00922AA 40F69810602C607C60A260F003F77C7C083EAC16F67D131E7BC921E2E2C1E25337BD00571A2D84BC9ADC483CDA1A22155F2E76A6DAAAD0D59CE91AACEFED38D4A6CE737FC4539B17AB2E687B4BF89F83B06E94FE3F9718B16DD6A378D77FFEF18A00E4768088E184BC435728FF56FB4616C5BFEB2F676A82F8F31EFA78EF684C
    1    514 000000  1691419500000         900000 E2F7CEFF C10198387030608660AB60FB8111CB03FBCC9AA8072A350755D5A8E0AE2C703D70050C8FC4CF62D8EFDCD7F14DEA29577B3B9B0DF8D4C61EA9DE1693B77AE22C5FD086593D38D8D094CD30C1961C983156929948AD55CB42B558656991A99C976F2B5121521A751F2000E2BE8044837826996D7709E539FB87578166A6DCDEE6
    1    498 000000  1691420400000         900000 B19AC039 F0F99860702E607E60A360F31C7CBF86DA05AB24C6954B7D093E8C7BF066FDF6534CD10BBA483291E535A2B9D941241E6BF72BF83CDD729261969A307C13161BCBCDB07B5CA80A634A33DCFC9EB5D3DD1DB8D91B0B3E43141AD514017E61B7D99359DA36C0007055804270C4F4470784EBE5F1CA66455845CB4D534192B34FC1
    1    498 000000  1691421300000         900000 689C18E7 90F99888702E607E60A360F31E271568C5ACA9A3692F04B23AAD5818C406516E4E98608FAFEE18350CA8D7165AC22A0C8DA3741ECB388628947F8B21F17DF5E4AEF86CFA5701B928B8363F4D06507967FF0470B81E47DEC5947196794A595766C5BD600DA000408458DF1A931DF14C93ADF4A877AFA5191CAA6A2457D9EA1B41
    1    486 000000  1691422200000         900000 04EBFAFB 20F398B0702D607B60A060ED2D2B67F8D48B308091DC602BD611F3258EBC44191BC5079C18058830E23A73E08474D7C80AF7902FE42CE57B51AB01232EA9868DE2F7A9437767E6C46AD6337568372B8218CA7E63E95877C572421E668C3FF3C085A1D9009B1028413BF9648F590714AB581FD36DF520F7FB644F5503514C4F36
    1    500 000000  1691423100000         900000 55783BE1 E0FA98D8602E607E60A460F436F75200DDA090CADBC511E997FDECEE56E89647D47BE9F692A7DD2541C610F9A9D69ABEE345329ABDE408AD587708F4572A64FF59BEDE4B578BFC91EB256C1302063C9B5FB150BBBD3D8827DE8870FF8831F8B71C7018BF94E018AC39C7C7D64C207DA7DFDD07E7EEE443B9DD2CF7276BCED2ED
    1    502 000000  1691424000000         900000 832257EE B0FB9900702E607E60A460F52D67BA9F0BF8A0948424821F9E1F5BAD6B0B05EA75432F5E547618C12E0CF5B05C5F0EC76156DDAC7C5AA7EC0CE369653B5ED501499876D4591301D461C4B5EC35F75D9EEFD534AFC09E89120962E9D6D8E8D0A6A5C848715400CB9F27D132A9FA53A9B1306C46482A1A69082251461A07A4D7FD
    1    502 000000  1691424900000         900000 DE2BDECE 30FB9928702E608160A660F53531410708F632659FE90ADAD7C9067B15C1A06C2A0BC961A743B0CA3BB115929C6EB58584DD3CC03A42795928DFB79464A1378E4141B5B181F81043FBA7D9FAD1B6D9666F07D84B8F15893E04A1ECD18DD4F2C47A8C9E9DA318F4AB1EACA84602B91360F287BA5001117F8472A995AA2457E977
    1    494 000000  1691425800000         900000 82704FBB 30F79950602E607C60A260F115A4BA551C5F0BB9F0D41A39F484D8D55E74335CB3BB0FFCACFE7B4671E2326212DB9BD3E689A6FA6DF7594375C6A2B0FF3E48A96AC652D7C1CFFDB0AD2648D58EED22D479A566946C5EFFF066ECAC9DEA63330ED603EC4AFC00A7F70A978072EE6D0DEAC331B4535345EA3C3F257DBAE4F1C9E2
    1    522 000000  1691426700000         900000 CEC12DBE 210599787031608960AE60FF7718F64DFBB337FD12C5A22ABAAA5CE30567E8D8D86C548B25E3ED40AC4DB28A6C848A5D22753F232625CCF4DD5D2313B85D1334A294AE47D40FE84B245C85CB56DFE3546B5DF45DBB19541F042495690294B1E5F3A874065466A1321B89240040E9804483065AB43B2E7B334B324A329ABA2795
    1    502 000000  1691427600000         900000 E14EA101 30FB99A0702F608160A760F56078B742ECEDDD7E7D1EB7BD9FDFBD77577AD7E426706E61CBAFD662086E6F86A05387EE4F6FB8E0B3AEADEAF1CE4EECB884A301F26D4D4C95B382A6530EA0E4832709F176B1ADDD4D5E75B56F0666D28C7A3AAD09D9CDCABF9D9200C0A640ED348D610E26409A43B58F7A634D6D727BCEAC889D
    1    502 000000  1691428500000         900000 30CC1F8C D0FB99C8702F608060A660F52712DB652C7A960640F6852A80B755CFBCA570709B878118E32EAEACCF6CF735547ABECB48B561EB9858116DA49D8844026719155C71A2982987211C13F77930D816411A1A9C474D433DA33FF1D09A1F4ECC2A3CC77181DCF432E14000D12AE089529BB31061406325C0A247925B91B897720CD7
    1    490 000000  1691429400000         900000 80D2E640 00F599F0602D607B60A260EF810990DB3362CC276DA198C45A3EEE8365285FCFAAB25EB90D34455656F489B6BD3FA34113DB95D8EF971830EC76312FBAFB347C932F35AE5306ACEEBF13019F445AD350F9ACA90C3CE5E7674786C4B30F87EF32EB9D530014BC8109A1344752DBA7CACF71CDFB16F63FEDA65E4252FE37C5544A
    1    480 000000  1691430300000         900000 CF17203D 40F09A18602C6077609D60EA1E464A4B8C972A16176722666921E97BF90E5DEFCB04257B1EDAE3FB64070A89CF4CA35F977F4FEF578EF2FF0CA5A72AF455B45C96C78AD906348CAC4CD5B7913D484D86DAADD9A7D6DFD5FC073A9C1B3CA707254D92BBB4702AF329D6AB14BFCE1D9FA43137BE840E1F95CDEE2975CCA1738756
    1    486 000000  1691431200000         900000 B17EF146 30F39A40602D607A609F60ED65CEE824BB2816C50828075464885AC38DFBD34C30F19CEB3D4D3E048B71461617E9FA2926C6582ADD7D284ECAC15F309B4C376EF25E21CF81067671E4A46B28BF96DD563F390972AEE3E1DCFCA0496D178618FCD4A22800998031237E38A7F29296119555454F14DA35A823EA18D4992E39BB3F
    1    484 000000  1691432100000         900000 87699538 B0F29A68702C6079609E60EC174A25160402227501108878C205891C422B055FF3309C58EE1F65B7D247C7170B8F13F52D6DA9378A69619C2ACD6026148B833800B994753CBA532F97164F4DE9BEECD53A2786016DD0CE4424A7F9AA1106F1C616CC98C80C7F824F5F7198109AC827E2C2F04907DE745A0C296C7C40F49F463E
    1    488 000000  1691433000000         900000 52FB6514 90F49A90602D6079609F60EE5D5519B3980B14FCD25CFB7DB0B72A8FE67FC107137348739F68231278965221E223A90541355C481524A4C2D95D3EB0C8E479AD0B77B82DC34A6EF66799013E4AE4BF5B07C5B9D3B825D05FC7068827574BEE0A30E6664785D75E83EB63DF3DCA186080E47FB5B0A68499E92B57983ADE6C139C
    1    490 000000  1691433900000         900000 7257EF90 90F59AB8602D607D60A260EF69C95AE2D585A331624B3925A89E37515332A31F7C1C742226DA68B8A85834E74FF499D518C8ACEBF2BFBE38D10F564CFE31DDAE3D686AB22FDFD59B3D02DDDC61DBEDD17283161A5183A619428BE3D254BB3D164501FC9628204274F4D3149EC09451892C853B1CE970F26937F16D2268B20888
    1    496 000000  1691434800000         900000 6C48403C 30F89AE0602D607D60A460F25AF929CA1C5ABA80D2FFC370F806011A16192F4CE903F1FC695C1207EA3EDA62E565B58D1DF3AC25973CD982C53AF3513BA48D3C9A090D7AD344CE99E5F9E2CEE943AFC6E6175EB9C44A6C735B2B12BCA089D336DE081060914F7BBC979A4B05F4477F55B6692EEA772898135764B4D1D3830208
    1    488 000000  1691435700000         900000 FCB4D1ED 60F49B08602D607B60A160EE5D6973BD3778D1F6EF0B806E2B00FA3576DFB6A75F96105C21AE2985DB643CE51F9986E4E77F3F9C4F0F0531CE1B6E92A6A2A8BE4178EC51C0DA4FEB0C37CEE2C4016865671D28F8E9CDFD632AEDB7139CC384B71D076C00B11D0BB66A152D9015325476CD1856DC26395F3C2028A05103A801FD
    1    484 000000  1691436600000         900000 99E2EB14 70F29B30602C6078609E60EC5EDBA9FF7CED838C33B672B70F53AC9D8872FD4DF4229CFB180DF527F7A418957C155C1B13F2656E743F636DF9A82B8FB57B44CC2A4BA605107F96580EF9FF71E90DAE38556247B65B0DFAFACA661509F9FB888CC9009EAF0A2C79C5935770A60ED7DD6BF043607E41D870EABBA96795EC5432DF
    1    484 000000  1691437500000         900000 B33A39B0 B0F29B58602D607A609F60EC72975393F05AB2B9A96ACB99125C6B7BD1AE724884B9A0314FEAA8D222A52835E97F94070E1DDF5566D2B6CF8466AF658645F9346C9E7F51E066FCB4AA68B6D734EDAFEB55171F4A9A5334BE89E884B3B1FAFD4864EB68808E837B72AE269D5C1F207F41EC3EE9F418DCAE6F98C5E7FE785E58EE
s=2 n=25 o=12370206720
    2   2560 002001  1691435520000       34560000 1FA1B319 0B774A712440E1FFCCC03FE7955E1861861056DC07B0DFBB514E7574E8F0CE869D1DD4B69F567E82BC39B7465AAF0A12A855B53FA4F75C2CE96DC1AF5DCC67EF946B7D5DF3A7D4A1537CF9F3B42FE2577DAA4EF4ADC1AEA54C3DA952D94A869574D5AB217B4E13E54BB5BA52FD5267D4A943855D53E7D1E13E4CA61BEAEA68EB
    2   2560 002001  1691470080000       34560000 F14A79F0 0B777B0E2440E1FFCCC03FE7955E1861860EBDFA1EA99D27795DCF11C7E4D1DF0E8B06D092C286D2B43851105D42F6C1D8511A577CF9FA986FA8D77CFD4C37CAD03A4371FA97D69F3F7C96C25ACFA2D77DAA6BAE5FBFBA32B25E292C8D18FB5704CFD2C1850DEBD7D0EDA080AD0BE6CA2BEFD6F6DBB2AFB55444A69AA7CF9FA9
    2   2560 002001  1691504640000       34560000 6B0DF300 0B77B1572440E1FFCCC03FE7955E1861860EBE3B5EC95D18476DD7422F30B5E089CDBA549FA15CE953B71D53425546C1CB521D3E7D0A152AEA76264AFABA974D762A550A13A7CF9FA9A6A9F434B4E2577DB25889A2587CFAB255E96C395E82B6F7EFD3252B4ABA57F4A1214D0B5D2A3B1F3E7E95FA64CE9EEFA54DF3E835DF56
    2   2560 002001  1691539200000       34560000 5200FAA6 0B7709A32440E1FFCCC03FE7955E1861860D82BCEB89C90DA301C7025438B9E04A8EF6CE92AA8746B2FAD2486C24E5D22A4FDB3EAEA61A986ACABF7CE5F95A30AE3E7365052A4FA13F7E92152AEAE2BE7DB2A4D55F6356568B6856D2D87CA9F544CE6B3DA501C3D88994D67BC1F524CE9DBA53B0858535D3A97CBD2D6A8B613F
    2   2560 002001  1691573760000       34560000 166F8ECF 0B7765262440E1FFCCC03FE7955E1861860F21526AEA95AAA185C6F7F33AB6B69B32B734952E7CAA92B7B1F3437B9D2BE88417584309DBA4D09D5816FA3BD61322396B5152A196DF258F0D4AA75470F6ABBB975ADEABE15A10E7EB9CC49D4A1BE730E1BA4AFD25820AD7A5796AE6B495A3D6E70A1428EA695D22F9ED8435DB3E
    2   2560 002001  1691608320000       34560000 63260A76 0B77ADFD2440E1FFCCC03FE79A5E1861860F1E13FD74C73EA34DF584AE24BAACBE9277B0D2BEA8829404B0DB524CE9EC384AD33A54E75AA7D5A9575546C8C7D096EF7695F3F7CE9EC0733302AA4BECD77DBBDE9078BEA50E13F42A70428CFDA527B621A6AD714BEA4FABBE8E9D343804BD6F015AB850A9D44CA6C3986F976B7C
    2   2560 002001  1691642880000       34560000 7D3D349C 0B7703A32440E1FFCCC03FE7955E1861860F0E9585695FA6A2FABEF54E24B5E09A74017BDFA8C0E6B437D5A9BDAAFDF2AB8F9CC35549F3EAE99D2B514DF427D5A9583522C24A8E5F529B11CBE7EFAEC37DCAA7E9693D7B0DED27D9A93EA695F567CE9D42A561F2A4B2152DA4A6D584B5A9BB6AF9F3F74E9F5753612BEB70A143
    2   2560 002001  1691677440000       34560000 10691169 0B772E212440E1FFCCC03FE8955E1861860D71F57870ABAB5309D5755497B9D8B0843434CB2986D37A7A6FC8574911F53734D33E7CA9FA5A54AD4054869A584A61BF3FC2156809693A4AFE93EAD5E2D77DC537E8558C5E8293F42F9D427CF9CD37B0AB542696DA67B5E48C7299E5BAD612EB74E9F4374B9F3E86A95A5AD5A9BE
    2   2560 002001  1691712000000       34560000 280D0F78 0B773CD12440E1FFD0C03FE8955E1861860F5EBBAB89A927495DD5776F304EAE99CEC4B5D0C2854F72EA4FD2C4195D525A6F9F3F534A8F0A35E9575499ED774EDD3A417522A7709ED6550C6C3A6965577DC584AF66CEA695553530DE577EF9F397CFA0D787252A576AD72574A5F3E7CEA13FAE969AE7D49F56A8A69577B4DF3F
    2   2560 002001  1691746560000       34560000 C7D17064 0B7735BE2440E1FFD0C03FE8995E18618612A61BAB749FA2831E76B76DF0BA869A92EA69952988D61267CF5F47AEF69BE7EF6BAA850D2BE7CAAB56AF09FAA7CFD25771B10CE4CAE73EACA75A6B55E2D77DCB9A111742855A1A572FBABEB8E1F3DD7716D72EFD33E75010BEAD0DF3E56FFDD2861A6AEAD591ACFA1574F46226A3
    2   2560 002001  1691781120000       34560000 B96D31EE 0B77D8592440E1FFD0C03FE8995E18618610AAD3EC0F95AA84AA7437EF24A67C996DD18FA13E80961274AA955776835BE86E9ED77D0DCBF4AFD5267D0DCBDB0992D77AF9FA087ADF3E730DF267D5EE707DC183971FAE7CF9FBE734ADBB730DF39AEED12AA4BD73F4B615517D5DED85367CF292E8CE70E1AB733A7BE7EF2EB9A6
    2   2560 002001  1691815680000       34560000 89ADC68C 0B77439B2440E1FFD0C03FE8955E186186114ADA2B6FA0264911AD756E304DDEADEDC52F95BE5496D584B4D4D754A9F8CD8E9F3E7D59FA5AE9952AA4FA9574AFD53E735D53F2495F3F5349F3F72FE2D77DB258519DD8A6F64A5AE869C34E81F5B4E954BE86EA8BE88F5F518CFAC3E24E5FA9855DF4D870DF40495DF2984EDF3E
    2   2560 002001  1691850240000       34560000 F47C1FFB 0B77A8392440E1FFD0C03FE8955E18618611079D6EA99F3F52FA96E813183A8EADCBF535DF29803692B74ACEC2550A1A58709D3B4C99D39B095E6BAEFA13F54A94C2A4F975354F9FA5A6E6956AEE6F577DB2AA3462498891CC2B09933EAF075C2DF5D1D6EA894DAA70953A735CB24ACFE8D7AEA5552AEFDF91B75A14286AA0C2
    2   2560 002001  1691884800000       34560000 0470A11D 0B77A81D2440E1FFD0C03FE9955E18618610FAB3FB6BD32B70FE9BE7EF61BAE045DA5550953986A953F7D5DFBD74F9FA17EAA8D84C992BE8EA6BAA7CF9D3DAECF0AD79D61AA4BCE9915ED5C44AEFA2D77DB3F7C3137686FA98FD8E5FBA86AC642B70B5C27CFD339B6A61BE7C929A9AF0DF3E490EC205EF6C21D5617AA54894BB
    2   2560 002001  1691919360000       34560000 0D7BADFC 0B778D432440E1FFD0C03FE9955E1861860FAE943904933B7AFAB5B55497B9B8E7357A36DF3EAEAA72ACD0DFA886E9F2A7CFDFA64AAA93F7B0DD3EA6E5DBD8681FD741753255CF9FA3B90D1E0AEFAED77DC1582F9CDDB8F6DB9B75A9BB4AFD2A5A74E1BDA835F365685D3E7CF9F3956E938D535DF3F7D0A6BB5BAEBBE7D59FA5
    2   2560 002001  1691953920000       34560000 C84E4A39 0B7725622440E1FFD0C03FE9955E18618610BA957B6AABAA8361DA94ECF0B9E095F477D49F3E7B5EB3EB231F5754FDCAA7B250C772FD2AAAEA9F3EAEE5CEBA6969B9A54AB42556DF4C555DF2BAF015D77DC29A691EE25EF94C39085F5354E70214AEA1C1B709F52851ABD5A6FD042B0A5EBF731E3BAA4A5FC34B1DCDC41C1539
    2   2560 002001  1691988480000       34560000 E82DE1A6 0B7790DF2440E1FFD0C03FE9995E1861861096C3A90455407AE9DDA76CE539AE8933E7549ED68099EAB851DF2986E6DAAA5144A97CBAB42B6A9F3EAE952F054E9CEA9D5DF0D5EFAB2A516E9A6AEFB0D77DC911AAF5C94CA97B4A6E96EC4CA5FD27B508DB7EAC9527CB9EC36D80DE156FFD4EFA3D2E89C8D87B4DED822F97B983
    2   2560 002001  1692023040000       34560000 A55D2C97 0B7733032440E1FFD0C03FE9995E1861860F0E1BDF0F9F486F829701C9244E7CFD3297D5ABBA54FA6C0450DD3D90D5F3E855D2D822EA190B7089A65485D437CE9ED6AEF92D24BC158E17C1FD6AD60BF07DC3E6CFA1A5B9C214DAD126D286E57304EA35D2D7397A4AF6DCD273AF357B10F8CEFAE3AB51092B4E4295B7E92C2673
    2   2560 002001  1692057600000       34560000 CF6EE7C7 0B77A1BD2440E1FFD0C03FE99D5E1861860F5AE26C0992C47AA9F6F4E92439B895D41D75D541A55AD447D0DCD852FA93AA6A9CD3588216AB6F6BBAAE9739588333A67296E3A4D09539A32539184FAED77DC3F6903B22434A7BA7EFE1A9C0F68C995439B8EA1A71B628477D5B629869DD387D4762A7D09B2B54AA9D286E9F3E7E
    2   2560 002001  1692092160000       34560000 6BFCC102 0B773D232440E1FFD4C03FE9975E18618610FA1B9EA492C852F75D8267EDD3D6E92C1A6FA1D24B61F21AD727517F0A9527EF95524D5D4BE84EABBF4A461D2AE6BAA6730DE5B3086B5B4971F526B02C707DCA590EA2126A99F39A55E1A64E81F43749533E7D5DF52A4F9F527D5D6BE7EA9D4673612D7AEF9DA55E95F90E10959A
    2   2560 002001  1692126720000       34560000 7ED7BEDF 0B77C8D72440E1FFD4C03FEA955E18618610F6E89B69DEBFA496E431CDFD358EE5CEF754A1BE730A1BEAD5DFBF4B47625AD514BE86A94BF7B114BEAEE9F3EAEE5752CB5EAC84B5ABA5554DCD2AF3A4707DC2B86FAB4374FA1397EFCB218E99F288EF953A854A1A9AE9934E5499F5354E6BA654A9FAA7CA9F29AF5DF4354F5FBF
    2   2560 002001  1692161280000       34560000 C33A5C88 0B77F6FD2440E1FFD4C03FEA95DE1861860F4DFA1BA3932B794ABDB5CF6425B6F9D3D7EFD32E7B5ABA6AD612C27D0AA117D0DD2986A933F4AA95434C99542A6E6157795EB42A50B5BE83614C27EF64757DC4F4E9693F7EFAC1B7EA9FA57E97556A35D73EAEF96D7A699F2586F92D37CE69C29E9A92A7EAA1A653110BE8509F43
    2   2560 002001  1692195840000       34560000 B05670E3 0B77B4252440E1FFD4C03FEA955E1861860EAEBBAB69B5BF72F9F6F7EDF0BB7485D29CEF9F567CFABBAAD5DF4354E94D7ACFDD3E5CA954DB6AA156851DEEB84AD4D6A54A1BE4CF9D5283ADF53534B8F07DC4454E77AB7EAA8B8B95A95688968D67CFD2C28EFAB567CFAD56ADAD54372FA9536B612BEAD612BE7D0ABBF52F9F56
    2   2560 002001  1692230400000       34560000 E22F2DD6 0B7757612440E1FFD4C03FEB955E1861860EBEC25B6A9FAB515E9BE587D8B58695EC34CFDCC27B5E1AAB51E9C186FA33AAD012BD870A13F5486C25A549ED7CB5E20FDF0D4BF5509FD17EA61A64AFA4757DC43A896D2B8CFABB48EFDF2E5BADF2652E6BD3735DFA9854D33DAEF9F4353997474EB5F56AEFD4C2A71ABAE4D36B48
    2   2560 002001  1692264960000       34560000 144C803C 0B778A0C2440E1FFD4C03FEB955E1861860D72BA7D36158EA30DCEF7EE2E3AAE960C37CAAC24B6997537C99FAA7CF6BBA7EE9D3E7B9E9BA7D0A8D77EB9CD37CFA008735DFAA535DCD3735DF3E4CE7BBE7DCAF7C877BEA8E9ED354E9EC27EA9F3EB6BC924A659F2A86E5ED74CA9F4DAEF9552A6F9F434CF75BDAD6EBC373AE93E
s=3 n=0 o=12358637568
s=4 n=25 o=12370182144
    4   2560 002001  1691435520000       34560000 104A3559 0B7745472440E1FFCCC03FE7955E1861860EBE13AE8ADD27710AB71447E4CEACADCC4730D4C28E82BAEAEAD2C2B095F267EA6B437D097B9850DF427D4DCC354FC45155C21B64CE9F2AA546E25A4FA2707DAA5C4F92DBE2992B5E2A155C4296B575EB958BACAABB574BE1A4AF106527CFD73EA55D53E86A6BBF431C8C37B5D4D6
    4   2560 002001  1691470080000       34560000 8ABBB5AB 0B7767252440E1FFCCC03FE7955E1861860EAEE08E14DD13790DD6C4B430B9E8ADC44434D13A5499CBB79C8447569619CDEFDED6AEFA166B54B5544B4A94356433A24B4E13A7CBDCD684FE12A7CFB6D77DABE90FA259544A0B97EE6E8C4CFA1465EF9FA5434DEBE4B7339F870E155D74D5A27359F3E7D0E8D7835EBBE5699526
    4   2560 002001  1691504640000       34560000 DCFA2C99 0B779C3F2440E1FFCCC03FE7955E1861860EBB8A18EFDF13729DD9126DFAA5E03A8C44CA922AD8820D97D0D5424E92BA1AEAD3267D0ABA9AEE9F3EA6A692A6AEE9427D6DF5352FD33A4CF6BC35B0AED77DB258746261AF0D28C8096BD1AEF6C2B22F9F907D4ABA0A74DD394EEA73F20FAE3A86960DC4D097B97EAA73A7D0D2D7
    4   2560 002001  1691539200000       34560000 150E5CC6 0B771A2D2440E1FFCCC03FE7955E1861860EBE1B9E0ACB9182BE75A807FD1CD84AB2F3900EBD8F395437B114D6AEF9EBF850DD2A4BBABD2AD5A9BE7D5A9BE70FE142A5ADED77CF9FA574FD5A154FE0577DBA47F5C8BFE0FA8BA870D32A7EFA14754F9F3E7D0DCA672AE93D7D4DF3F795E143CCFD3257D5A1BF4B1A356AF1D339
    4   2560 002001  1691573760000       34560000 57E1A595 0B77FF142440E1FFCCC03FE8955E1861860F116D3AEFC953795E9D276CE4CED68A92B52F9F3E7E85F2B76A932A72FA12B7CE91427CF95BA4B5E8DF74A30A0A8E60EE7D61EC1A6FA73DB79A72D86FACE183BBE574AB4D7FAD56AC0F932B7AFE6E5B8E9B2C0581F4283112BEA492BD748BD0AF7F4AB5374A6C41B8968EF80354C2
    4   2560 002001  1691608320000       34560000 0256E46A 0B77A7C62440E1FFCCC03FE8955E18618610BD2D3D898926A2FE96044CF135AEEA12C3F6D5A586ED244731A9BE5101CAAB0A6943A4F9D5286E61BF7A9D4BE7CFABB9712613B24E5F3E730E92B4CBAC707DBD87D4D4BD7CF9F39A891F427D49FCD9CF9EDBA5829267B7EE25510DD268549FAEA4F9FBA737E943A4FA13F5D49FAA
    4   2560 002001  1691642880000       34560000 82F7FBF8 0B77C9052440E1FFCCC03FE8955E1861860EBE158ACF9FBE7B5B3754CCE4B9DEFEB57434976A6082B3B870D2BE7151D26A50D4D7A4F9FA9AEA363EA496E298CE61D1D4FEBBE4CF9F4D7D11CC374AAE707DC3F86821BD74A9CBE74F9ED7ACF9CEB82FA943804A9A0A6EABBE78FD45BAEFA1577AFABD2A6E9F3EA6F9D437CE9DA9
    4   2560 002001  1691677440000       34560000 78CAA29E 0B77BA472440E1FFD0C03FE8955E1861860F0EB53E09A126AD49D568746EA0E0AC8BF4B5D329B032DA77AFA1D17EA6C0E6AF9FCE835DCC44AFA9577B5DF8D7E961BA6911EAA56FA1299D4DB3EA55B8F07DCAA84E68D684F62257D4C8AE7D0763D735DED77F0E13A7B6F82574955527CA9F57A4EA94774FD2C37CBDCC37E835A6
    4   2560 002001  1691712000000       34560000 4A8EB6BF 0B77524A2440E1FFD0C03FE8955E18618610FABBA90E9D0E8311AD376F57BDE89A8C86B5D0D2AEA77AA7D09CDB855D525B0E6196536A95BA4E763DAD612BE7E8695751BE93DAD2273E1CA69B986FA5577DCAF1B4C5AA869C925D30DEEB754DF2552FA93F5572B564CFE13D9CB952A9B61257B0469BE733D5AA7C561D2ACFA9BE
    4   2560 002001  1691746560000       34560000 7BEFA209 0B77EF6D2440E1FFD0C03FE8955E1861860F5EDBAB838922AB5E95756D243AD6A9F2B72F9FB988D5F26A4F5FBF56433BE7EFD4AA854D32A4AFADB9AEFDD288FAD2DB7B0A139B0BA991A1C213B7BAEC707DCD423306C8BF46DD6A6E9D3E7CAA1BD9EDEB95551613E7D4D54DD6953A0AF4962490321AB6CA9FA5750ABD3554A753
    4   2560 002001  1691781120000       34560000 1E9658CD 0B7776782440E1FFD0C03FE99D5E1861861296D3B8EFD3177111CEEB26E43B72ADF2F530A1A9B072BAB72B9F3F7CE6BA65699ED774FD325855A2124C95F3F7B4D54253ADCD2870A15342F9F2754A65577DB96EF39FAA495DF3E86FEDC7AE89EBFBD43DBA83C274CADCBF73BD3BD86F783E6CAD2AA87061D283014D354EA73E85
    4   2560 002001  1691815680000       34560000 CB74ACD1 0B7737562440E1FFD0C03FE9995E18618611ADED390993574ABAB734D9584DE0AE64452FCB3D7EEAAD4CCFD0BD86FA1A58D5DF2B4C95F46AEED2BE7CFD73E4B0A13F74994D77CF9F3EA54D4BF4AFEE707DB299DD92F14D0D4DC70ADF52A4E5FD1A8F6942DB09F4E850DFA6A4F9FAA5503D30E6E8CE0AD32684FAB6F874304F7E
    4   2560 002001  1691850240000       34560000 EACC9229 0B77B5972440E1FFD0C03FE9955E18618610FAB5486A953F49AB63EA6F5838E29693F4B4D2BDA736225D71DD564CFD4BE86F9D3E7D0D32587392D84AE9D3E7D4D4D2A3C12C286F9F3DBA312597CEA2707DB3FA2E1FF288992A4B79A9A6D51DCC3874A93E7646142AE961CE5498652A56E9BD4CFD2C1B13A13E7EAA03D8D49FB9
    4   2560 002001  1691884800000       34560000 E4E106A3 0B77C0252440E1FFD0C03FE99D5E18618610AA13FB84892B710E9D24EA9539C0ADC4849AABC1B8A9ED3A381F52555A9267D5DF3EA50A142AD4D3A65499256BEDEEAA1F8622488F9D292698FC4AF4D8577DBB4F696DD98311F289F0D641532381DC6C29BA96DA77CFDEAAAF5C9248F4E944215DF3E8E86A217CE6BC37D095A554
    4   2560 002001  1691919360000       34560000 29B099BD 0B7760C42440E1FFD0C03FE9955E18618610BAB3FBEB10BAA35EBD2767EEBA84FA74849BDFA57B61EBBA54DD3E84F9F2AACC12C37AAD0D754E9F3F5CA52E853475D771C1F3E56A5D9E92E94C47D0EC577DBD37C31CDDD8F9F26AD5D5427CFA9B8AEFA1E5AEF9FA5A4FE7527E95F915CF9D3E4EFA13EA4F57D4215DF43735DF51
    4   2560 002001  1691953920000       34560000 929E7698 0B77DEA52440E1FFD0C03FE9995E1861860F0DF3FAEA9530A2D6BEF76CEEBEAE9694374F9F2E7D4ABA285006D17D0EB3E84B08604C972C45C99FA5AE9912654F9ED2A54E8A5A8ADCBD5361E97AEFAED77DC911AB3358550E1A07F3A0EC4CE60F07B4705822E6E3DAF0DEBB7519EC82EC3B4F0AE26850092F52AA1D57F36224E9
    4   2560 002001  1691988480000       34560000 A263423C 0B7715AD2440E1FFD0C03FE99D5E1861860F5A43DC0FC8C8795E97044E244DE0361AA4B0AE207EF755775B1CD6AF36DC353610BE4CED2BF7AF86C3B031ED89CFA92A7549CBE4B61F51851B5D85CFD3DC7DC42E29A420875DED6E2B6C264D0E989C73BE90EA33F56AE92673BDFA8B8A693F7CF6BD686A925C84FAB6C74FC8D6B0
    4   2560 002001  1692023040000       34560000 AD81EA7C 0B772A302440E1FFD0C03FEA9D5E1861860F4E1BAB8988DC510E95F5EDFABA7E95FA5755A225734A9447D0A220AEF9F3AA50D33A56994BF7B09543ACE6BBE855A92A7B0AC2486FA93F40FEBD353C21F07DC5274AFCAD8F643D7A8F2CBB530754995439C13A1AB23114484CFC924874DCEA7D497BA8D0A72A7EAD33F52FA9437C
    4   2560 002001  1692057600000       34560000 1D8CD705 0B771CC32440E1FFD4C03FEA955E18618610FA1BE9098AC852F9F584CF57BA8EA90BE555AA1085ADF927B6293E7692C257F3C6D3436A742889573EA486BC27E1B9117311290A8FD7297BD48D337864D77DC3E7F0A2277A22238CF010D27EF37BB794D35374961C1D56DF2A7AFDF3A851D5922AFA33F71D539272BD59487A973F
    4   2560 002001  1692092160000       34560000 9DEDD29F 0B7770E72440E1FFD4C03FEA955E18618610F6E89B69DCC09C42E4256DFABDE895F4254FAB567CEDFA1D50E9AA55478224B0E93ECEE94C28835F3F749383A5AD3B34A3BE941B909FA54E4933DA3C2C707DC4386F6E271AEA1B87D5E93F7AFDF517CF972A873A8C37C99FA4AEA6BD34E45F2986F77D37D4DCBEA899ED286A9534
    4   2560 002001  1692126720000       34560000 666FAF4D 0B77C9402440E1FFD4C03FEA956E1861860F0AE21F0AD2C3ACF38575682E3DAEF953E569C656AD5AC2284FA152A6E6B43A559FBE54994D84AFCB3D8D5E1534CA63A6795F5AA86937C2CEA9D2A5ED22F07DC2A8EFB5A68561EB98D5D5A586E9ED674F61C28EA61BA7E421BDAEFDEAB4B3DED37CAADBE7D0A1A5CD61EC77B0ABC3
    4   2560 002001  1692161280000       34560000 1DBC9277 0B7706AE2440E1FFD4C03FEBB55E186186129A4927F5ADC2D0BA20CD8BB73E855F1F15DFA65CB125BACE37DC7CA61BFA481F42ACF9FAA7E95F3EAD4A024A8988BE4EF695384BA9BE74F9F4422F9F3EAD108D6A699D2674F5FBE869613EA69A2DC7DBC2B8978274D0A8C37D5EBA490E9F257D19F3E8045F2684FE8D7AEFC8C35C
    4   2560 002001  1692195840000       34560000 C3203FAD 0B77D7DB2440E1FFD4C03FEB955E1861860EBE226849ABAB51AEB6F86E22CD8695F3A735DF527D4ABA6AD6DF3F5685FA67B0B3BDB0B5FAE72BA96C42FD111535E13E83BE9A65CFA1B95549FA954FD8C37DBF0869AAC552FD4B8BA994D74EE9CA66AE9F42A74953E9CFD2BEA6F9F3F4AEA93B4B5DFA5AD4E9A4AF5E9AB214D4E7
    4   2560 002001  1692230400000       34560000 4E33F138 0B77751A2440E1FFD4C03FEB9D5E1861860D72DBF84AD53F795DF577E9184EACE9D527D0A953734E73F7BB173D7EFD320B909D3E550DD3A749A0C78EF6B537D4A3427B9E13A5DAD53D855DD3F19AAF577DC7086FDD2DD74AC2590AA23EAE9762295C29BA39EC454FA8D7AD608D382FE8D2AEE5F3EAD6E139BF4B5D7855D55685
    4   2560 002001  1692264960000       34560000 E106D242 0B77162D2440E1FFD4C03FEC955E1861860F5EBA6B6AD33BA34A9D65EE2E51B8990BEA351D42530D7917362156B095F39A8A622574FD4D77CFD2BF2499EC38695721A4FB7BE7CFD2D75509FA1731F0707DC447C9ADA556FE1258846129A6F953E86A9D3DAE56BA9AF4D2567EAA142AE92C3DA5614BF7CF9F3DAEFA1C2850E6D6
s=5 n=26 o=12370575360
    5   2560 002001  1691435520000       34560000 AD9CD532 0B77655B2440E1FFC0C03FE3955E1861860EAEB278EAA009A2B1AEB1CDF13A7CB10306B59F69C092BAA8581D25AEF6DA6AB71F26535DF3E7EE6BC67CFD2D67D4A93E255D7567EE61BA7C96FBAA4FA2D77DBDC8686BBF70EA9AA7C96BBE7CE214416FABBA7D0DABE72975D1DEFABBD86FABA588860D7A4FAB2B74A92BEAD5ABBB
    5   2560 002001  1691470080000       34560000 125FF98F 0B7726032440E1FFC0C03FE3955E1861860D1F7A6C0FD50EA4F9CF04CF2EB9E701BF476A5F3DB8D68D87B6D3528736BA656A9D3F215EBA9AF4D1257EE55A5AD1AB3B430EB527D4A14374A95A9551E2577DCAA7D0A1BE68FE15754F616AA496BA97AFDD3F74A29C6A2AA9527B1173EAE5953DAD0EBA5AEE92537AFDCC2B0F92C2
    5   2560 002001  1691504640000       34560000 3DAEB73E 0B77D4932440E1FFC0C03FE3955E1861860D61ED8B8A5D936F6F5EA7EE2EA1DEEDF2F4B59DA4B08292BAEB9F6B74F6DA1AEB06BF44A5EEBAEA9F3E854A342533E7BE7B5DF3DAF4DF3F4AF953E869D5707DB2AAF0E96A7B62139B6F97424AF9F367CD21DAB8F9D2A4AFDF3E82BB351B8BDB3487008D422352BF730C6AE8F06BE9
    5   2560 002001  1691539200000       34560000 BA871677 0B77C06A2440E1FFC0C03FE4955E1861860D6F5BFAEA9FA74AAA967268FAB8EA9A8C34B4D4BB4CE9FAA9CBA1437CF9F8D7B6EB56AF59ED6B8AD325A4FD4BFA2F6C2A6B5E13E854ABA64AAABA9B096CD77DB8D57AE8BFB095F3DEAE535BB4D9FA62B593437C936267B0DF28ACFADBE7BB12BEA6BDEAF4B0D4BDA71066BA4F9CD2
    5   2560 002001  1691573760000       34560000 CAB0A9E3 0B7702E92440E1FFC0C03FE49D5E1861860EBE8D7DF0D3A77A99F675CE30CEDCADEC37CA63BDE089D267CAD2D35B5DCBF5C989A64AF95A57EAD0577E322208799F397D5DF3D885553D8EFC64354FB6769DBAFEAAA9BA7CED2BF4D5D2BEB4FABAF953C2E2461442CF9ED8435D3A4E14AD974911566534D7A17B512D77B6E946AE
    5   2560 002001  1691608320000       34560000 764271C2 0B770EF02440E1FFC4C03FE4955E1861860F0DF2C7D3C926730ABEC247BD9CE09D45C73AD4BDE0A6B3F7D0DD3D74FA113A559F441B59F65D8AD2AA7CE9F3EA6E93466722BCE7D0ABA59CF9F52A6AA53E7DBA2515D4F186A6BBE73745D67CAA1D4419DF42AD1066B6C85FA9A8954A57F4E13A74AD6C24B0CB39875F33DA34DFBC
    5   2560 002001  1691642880000       34560000 7CB7136F 0B77967B2440E1FFC4C03FE49D5E1861860D71F439039D2A7B510EB4E7E4B9E0ADCD74369741C0E6B2BA55DCBE7CBABB68EE9EC3754D2BE8696B545482BBE868FA3E996F7D7269613E42BEB56859ACF07DB8BF6ED14284ED245525936B4D5B7A694BBF8096B2C2636AD871C13BD5CFEC0D7B71CEA5DAA2357C9DCE74CF69577B
    5   2560 002001  1691677440000       34560000 EA2A8B2C 0B77DA3C2440E1FFC4C03FE4955E1861860D65CBFB6FDD127CAA9BD888249CDF1A1BF71C12C29032BA77455FBE74A6C1154FAB43A4A9ED6B6BDCBF74F61537CE6BD7390E19554FDD514CFC8D844FA2707DBBF869AAECB0B9E57A709D3E7B4A1D352FD129855A011AD0D3264B0933E8559F4257496D7536E9B9A6A224186FD521
    5   2560 002001  1691712000000       34560000 A3CCDF21 0B77B5FE2440E1FFC4C03FE5955E1861860F5EB52E95A98E8645D575708BA5D69DC5849812BDB8ED2AA7B5D3577B0DF274B49F96730CB2EA30DF577B512BE7B9B5BA7BB12AA74FD4D31B004A5B6FAEDC7DCBA84FE73FAEE9EAAA759F425CF6BDB7CF6DBDA6E6C265495FA17E99D25CCFD33A76E86BB26821444CA9F427D09552
    5   2560 002001  1691746560000       34560000 F2A63683 0B77A1632440E1FFC4C22FE59D5E1861861246BA68EF95A6AB5DD481CDF125864733FA4FD3258EE6DA742B62A3DA82BBE569A93D7EFD324DD114C34E45D3E7D0D2D69D4D31156A75BE84AA1427D5E2D77DC5954AD52C434A716A6BAB5C2AFA9AA55C39C0879ABAF0A93F6B5E01FB8FD2AB9BADF4F54F953E4C9DAC27EA9F3E54
    5   2560 002001  1691781120000       34560000 2329EEE7 0B77C04F2440E1FFC4C03FE5955E1861861256B3AC0A9530711E756B07F0BBA43952F4CE886B86E6D3FA4FA9537CE6BAB74E9EC27D6DFBA7B4A1A9AEF9D2A84EB5AA739D33888FA0BF730D4D288AA2707DB1091C5F567495CA77E461D771C59D354AA0DC4BB4AADA4A6DD8A3AABA5AD09F53530DFBCA53D5517E961BDB6F6156
    5   2560 002001  1691815680000       34560000 661855B2 0B778CD42440E1FFC4C03FE5955E186186114D6BEEAA5FBF52FDADC2531835E701C5C4B49F568882B447CF9D3E7CFD521AE9A93E7559F41B8E954E53BDFA65359F427CFA1A9AF0A953430A93F7AFE05C7DB20BD4EBBEA498FCFD6A6226AB7DC707D1DF53750674E8549FC2ACFA3954E32BAA8549F5772AB2B9B0AA93F4CF9CBF
    5   2560 002001  1691850240000       34560000 D584A8B1 0B7771222440E1FFC4C03FE5955E1861861109F3EB9006BF50FE9591B32439C29C5C77BBE9A490D5F3FAB1E9C2750A1534CB9F91850D2AB7C99F3A5539D3EA4F9F3E7BD12EAAEF9F3D9095C5CCD0A4DC7DB3AE34DFBE56828D77CFDD217CFA6D86045F2F42F95AAAAF6DBF7681FBD754DC6FA5AA3C372F538D85720D3730ABBE
    5   2560 002001  1691884800000       34560000 973AB7D7 0B777D7A2440E1FFC4C03FE59D5E1861860F5E13FB6A95A6A2FE8F37F497B9E099EDC49B08BF530DF2749B13529D09726A50DD2E74AD26B854A9C27CF9D527CCF0426B121A586FDCB89149C47E8FDFF07DBB17D1984284F9EC2AEFE3BF837552295C3D9282FB074FE0BEA6FC8D1914A13F535DF3DAEFA16AA4FDF44495D5527C
    5   2560 002001  1691919360000       34560000 81E16C72 0B7721042440E1FFC4C03FE6955E1861860F6DF479096740514E9C24E8224DC0892C442F9F3E7B5EB3EAD14643A4E9F2A7CBE13E84E73C28699F2B7AF9CE77E94BB99B6133E5EF29508AF5FAB7CFB93E7DBA6BAE6DAC4C41CC87B4A13F86A5EEB4E960DC73AE15F4AED53956AC83F7D469BF795E95B7F335A64B0E13E7B59FBE
    5   2560 002001  1691953920000       34560000 007E0832 0B7725322440E1FFC8C03FE6955E1861860EFADCFB6A952C5296A4254E24BEAE85FAA7695F4F4B5AB2F7D09FBE4D36DAA7B11D3E7CFA6D7AD5A96B84F92DF855AB52A3B1ECCE2F9F2A190EAC4AEFA4D77DC0D894B7AB54A5A447CF6B3FB8A9F3974F6BBA7EF6D5B7B5DFD17D5E6A9BEAD2C37C861BFA4F923F7CEA3B94CE9FD2
    5   2560 002001  1691988480000       34560000 3881ED05 0B771FAE2440E1FFC8C03FE6955E1861860F0B5BEC2E5348790E96C23464A0B095F427D4DF517EF6B43A571D517D9ADBF7B1DEBFA4E6BA74344C117E8865884AA8E9E0F9CBDCBD21BE41C1747AEE987073BA5BAEB7BBA4F85C3B8994BFAF0A9424AF953F7CF953E750AD3F7CF94BE7D5DED7729953F7CAA93A54360397549FA0
    5   2560 002001  1692023040000       34560000 43349377 0B77427C2440E1FFC8C03FE6955E18618610FA9BAB895549170DFD67692EB58685F5275506BDA55DED3B0A933DB085FA17CFA9BF2B9D2BA9F05CF052FD27084FDCBF48FDF3A4D5A0D79922BD774FA4D77DBB9C48AB92A50904376D2B2AE2F9F3976A5D52754DED77CBABB97EF9CD274E95A9A4F1FAAB85AC0C4A9A1C440F94D1
    5   2560 002001  1692057600000       34560000 A739C60D 0B7747E52440E1FFC8C03FE6955E186186113AB43BEAD2C3ACF75D84CE23D2DA252BE4BBEB5AA54E916B7110BDAF47624B8A93A47D5E1B9870A9BCAEA6BD374E61557D0DE55BB377BE7CFDFBA39660577DBD3B0E6E26AC95F267CF68C3EAE2BBE7B49FC34CE383DB6AC8BE755A9525549FBDAEE6658A73A1B5531CB5C50FB5A4
    5   2560 002001  1692092160000       34560000 5F4D41CD 0B774D4C2440E1FFC8C03FE7955E1861860FAB7BAE6FE12C794E1C1B0E2EA4E2252C24B61339A50AE0DAD71D3D90E2BA6A51D53E4E95F427CFD3A58446BD28670B53735DF2DA74D55249229AA6F738F07DD15869783A4CAA14D7EF9F3EAEFA9397CA6BAA855A2257E829BDAEA9F3F2B5A1527F495B9D50E1427D4ABB9BF0DF34
    5   2560 002001  1692126720000       34560000 B3259302 0B7793272440E1FFC8C03FE7955E1861860F0E93AB8AC8BF849623A4EDFB38B7492D288961527D1DFA1870A141B896B43A6E5FBE4B0B5AA84FA35779BEB584ABA9A9AD5AA288746236530D2C354F64DC7DC5B869A127515DD4EA55A1CDB0992CE7B59F5B7D5AB4354A954DAD61ED284FC93DACA9FBE7CBABA9A4FA1D686F6B52
    5   2560 002001  1692161280000       34560000 C9B6836F 0B77CF2C2440E1FFC8C03FE7955E1861860DBF8268EAD73B5296BD74E8F0A68021ED6A5714D284FADA6AEF9F3F4B9A0F04CB6E397EA6BAA7D3955286A9F567CFD2BE7D3A9A64AFA1574CF9F427EA70757DCAE56977442A823C2AEFD32A7ABD53F22F9F265EF6BB98E9A13EA6955574AA9F5418B6E25854A1528696B477CF6BCE
    5   2560 002001  1692195840000       34560000 D47CB7C1 0B773DBF2440E1FFC8C03FE7955E1861860D252D3B69AC0E715E96C7396442A685329855ABC27CFABBEA55EBA986F6DBE850D32A54F64294CFAC218CE9351AEE9F42ACFD4D8733A0DBA50D5119D4AC757DC4386D9EBEA4EA356A54D74DE0B5FA74AE9ED37E994D34E468D6DEFD0A5AD0DED852B9DB9A8E69264AB6A41CD6E9A4
    5   2560 002001  1692230400000       34560000 68C462F5 0B77422D2440E1FFC8C03FE8955E1861860D72B3FDEB9FA77A99F6AA8E183AD69925B7CEDF3986D6BAA855133D7EF77BAA696952AF59FB9AD0DF527D4D6D77CFA9529BAE8AF4CFD2BDD89615AA7071437DC437E8A1955299F5BA506D56AF0DC585CF7557AEF9F2AACF6B5286E693E54A9557A50ADAA7CF9EC2A2FABC355AB428
    5   2560 002001  1692264960000       34560000 E9A74589 0B77A4E52440E1FFCCC03FE8955E1861860F0D73FB6A9FCF7C9696F86E2E39D8990AA7B0E1427E99F3E7D6DF52AEF9F3A8706A257655F484A99F3E5E9C646AEF92D6CD11D42749954274FCABF42EA2D77DC967CEABC17C39F3EAD112AA8509DA9AF712A4B74DED39AFD2AEA3AD5399B650AFAB6D53B7C99F274A92A25AD5DF3E
    5   2560 002001  1692299520000       34560000 3E33E26F 0B77F8682440E1FFCCC03FE8955E18618610AA1448C5A1C79C99EDF755704CEAE553DCF5E1564B5B7AAA6FDD298939CBAAEBD2575659F90AEEA0117CF95A4AF09ED6AF5A1BDA6F9D3E5CFDEC2D50183E7DBD8AE96BBD7C373AA9CAE13E7D0D4C78091FA5754D53E84988587445D3E4B5D52B7CAA9B97D0D2BE7B4DF527EA9E74
s=6 n=12 o=12360585216
    6   3876 002001  1691412480000       11520000 04066AB5 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000024000000000000030000000220000002C5BA59B65AD2769A74E0F6B5AD6358C6316C5AD6B524E7288410CE2F7354B5254A49CE52904210421084210CE307356A5252949CC63146310821084210CE0F6B56
    6   3892 002001  1691424000000       11520000 50CD009C 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF40100000002000000200000003600000022000000445502B68373DA9A069821921A54E0F735AC5B18C6318C62D6B5A8E830C410D22F7356B52929418E42086108421084210CE2F7356B4A9293A0C7298A318C2108421
    6   3892 002001  1691435520000       11520000 FDBC03DC 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF420000000230000002000000032000000140000005846A0EB8AD8B6C3747171834C2204CA0F735AD639AD631AB6318B5A92728C410D20F7316A4A94939CA528C4208421084210CE0F7316A4A52939CA5290621042108
    6   3880 002001  1691447040000       11520000 0F414D9F 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4000000002600000000000000300000001200000036BB71983B73C2C4909AE4E307B9AD6B58E6B58D6316B5A527308210CE0F7B16A4A949418E528C4210821084210CE2F6B56A4A54939CC52086208421084210CE2E7
    6   3864 002001  1691458560000       11520000 D769FDD5 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF40000000002000000000000003A0000002D0000003702C7BE62D66B9B772C19AFA5DCE30739AD6358D6B58B62D4A524E6184210D22F7B96B5294939CE52904110821084210D22F7356A4A52841CC5288421042108421
    6   3800 002001  1691470080000       11520000 EEF88EFB 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF42100000026000000000000003E100000290000004383F9A369BE265ADC7180F62111B65BF980AC52565231739AC6358C6318C5A94949CA4104210CE307B56B5294A424E630C4210821084210CE2F7356B4A529398A5
    6   3816 002001  1691481600000       11520000 3C1B1829 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF451000000300000000200000020000000020000005E0DAF445A6CD28B83AC0EAC52517358C6316C6318B5AD4A498C3104210D22F7356A5292949CE528C6310421084210D22F7356A4A54941CC528C4208421084210D2
    6   3808 002001  1691493120000       11520000 1267F494 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF44100000036100000220000000C0000000300000033145B26CC629BBEA14492A61B92A72111B706ED231839AC6358D6B18C5AD4A49CA3104210D20F7B56A4A929421051884208421084210D20F7B14A5292939CA510C
    6   3824 002001  1691504640000       11520000 751E994B 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4400000003200000020000000220200000600000055522E9716B1ABB2CF6A2A729AC6A1563283DAC6BDCE6B58C5AD4A49C85188210D20F7B56B529494A1041904210421084210CE2F7356A4A929398C4208420842108
    6   3860 002001  1691516160000       11520000 8A2C1CFA 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4020000002B10000022000000340000000C100000260A20A56EAC0E14D52AD9A32317E23612A4A024B6DA538C1AC6B9AE6B58D62D4B498A420C210D2106B56A4A94839CE520C4220821084210CE2F7354A4A927398C3
    6   3892 002001  1691527680000       11520000 1DCA2084 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF44040000002120000200000003600000041000000556F236B9C872C7B61263FE5B6FEAFF182D8D2328BDAD6B9CD6B1AE6B14A4A0C6210620D2307356A5254939CC518C4110421084210CE0F7316A4A529318C518C210
    6   3876 002001  1691539200000       11520000 612E2525 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4580000000604000000000000200000004680000034997535A9A09B89D92290CC1AC6A09E75610841AC6358C6318E6B16B51CC5108410D22F7314B4AD49394C528C4210421084210CE306B54A4A92931CC5208610842
s=7 n=15 o=12360585216
    7   2012 002001  1691412480000       11520000 395BC220 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000024000000000000030000000220000002C5BA59B65AD2769A74E0F6B5AD6358C6316C5AD6B524E7288410CE2F7354B5254A49CE52904210421084210CE307356A5252949CC63146310821084210CE0F6B56
    7   2012 002001  1691424000000       11520000 21917C34 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF40100000002000000200000003600000022000000445502B68373DA9A069821921A54E0F735AC5B18C6318C62D6B5A8E830C410D22F7356B52929418E42086108421084210CE2F7356B4A9293A0C7298A318C2108421
    7   2012 002001  1691435520000       11520000 D86B6C53 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF420000000230000002000000032000000140000005846A0EB8AD8B6C3747171834C2204CA0F735AD639AD631AB6318B5A92728C410D20F7316A4A94939CA528C4208421084210CE0F7316A4A52939CA5290621042108
    7   2012 002001  1691447040000       11520000 1B8B0667 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4000000002600000000000000300000001200000036BB71983B73C2C4909AE4E307B9AD6B58E6B58D6316B5A527308210CE0F7B16A4A949418E528C4210821084210CE2F6B56A4A54939CC52086208421084210CE2E7
    7   2012 002001  1691458560000       11520000 564FA55D 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF40000000002000000000000003A0000002D0000003702C7BE62D66B9B772C19AFA5DCE30739AD6358D6B58B62D4A524E6184210D22F7B96B5294939CE52904110821084210D22F7356A4A52841CC5288421042108421
    7   2012 002001  1691470080000       11520000 5173E745 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF42100000026000000000000003E100000290000004383F9A369BE265ADC7180F62111B65BF980AC52565231739AC6358C6318C5A94949CA4104210CE307B56B5294A424E630C4210821084210CE2F7356B4A529398A5
    7   2012 002001  1691481600000       11520000 0040F4A6 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF451000000300000000200000020000000020000005E0DAF445A6CD28B83AC0EAC52517358C6316C6318B5AD4A498C3104210D22F7356A5292949CE528C6310421084210D22F7356A4A54941CC528C4208421084210D2
    7   2012 002001  1691493120000       11520000 6DD5807E 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF44100000036100000220000000C0000000300000033145B26CC629BBEA14492A61B92A72111B706ED231839AC6358D6B18C5AD4A49CA3104210D20F7B56A4A929421051884208421084210D20F7B14A5292939CA510C
    7   2012 002001  1691504640000       11520000 ABA074D9 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4400000003200000020000000220200000600000055522E9716B1ABB2CF6A2A729AC6A1563283DAC6BDCE6B58C5AD4A49C85188210D20F7B56B529494A1041904210421084210CE2F7356A4A929398C4208420842108
    7   2012 002001  1691516160000       11520000 2A24CE6D 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4020000002B10000022000000340000000C100000260A20A56EAC0E14D52AD9A32317E23612A4A024B6DA538C1AC6B9AE6B58D62D4B498A420C210D2106B56A4A94839CE520C4220821084210CE2F7354A4A927398C3
    7   2012 002001  1691527680000       11520000 48EA8703 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF44040000002120000200000003600000041000000556F236B9C872C7B61263FE5B6FEAFF182D8D2328BDAD6B9CD6B1AE6B14A4A0C6210620D2307356A5254939CC518C4110421084210CE0F7316A4A529318C518C210
    7   2012 002001  1691539200000       11520000 EB5C0A25 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4580000000604000000000000200000004680000034997535A9A09B89D92290CC1AC6A09E75610841AC6358C6318E6B16B51CC5108410D22F7314B4AD49394C528C4210421084210CE306B54A4A92931CC5208610842
    7   2012 002001  1691550720000       11520000 C520232B 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF440000000040000000000000026800000370000007FDA06B711A49ADC0924DF089A026E245CE307B5AC5B16B62D6B5AD4A4A4C3108210D2307B18B5AD4949D052904210821084210D2307356A4A94939CC718C610842
    7   2012 002001  1691562240000       11520000 33216210 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF440000000020000000000000022000000140000004B96AEB6BEAD80EAADD22F7B58C6316B5AD6B5A92941883108210D2507B58A5294A4A0E730C4218821084210CE517356B529493A0C730C4108421084210CE2F7316
    7   2012 002001  1691573760000       11520000 9CC667C1 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF460000000020000000000000020000000330000007E626FEADB7422EFE69BF2BC522F7B58C6316B5AD6A52529414A3104210D2507B56B529494A1073146110821084210D2507B58A4A929418C82906210421084210D2
s=8 n=26 o=12370575360
brymer28
Re: Jumanji..original film..won't backup
#8 Post by brymer28 » Wed Apr 03, 2024 7:53 am
log comment #4
    8   2560 002001  1691435520000       34560000 DEF6E095 0B77EA482440E1FFD8C03FEB955E1861860D6F753BF112BBA16F3D724DF0D2DE9DC607509F2A84E78127B71D25A8961227CFDF3A54F9FA1ACFDFB985477EA7CFD2BA23AE3D6854A952A6AA13DAF0A2707DC2C4E2362A7AADEEC430D7427A9A95A56F5F3A750D1267CF9EBF84FA0D784BD2BB410EE257EAD03F7CBA9BE54A5FBD
    8   2560 002001  1691470080000       34560000 3BE8FDA1 0B771FB62440E1FFD8C03FEC955E1861860D13527AEFA1927B5DCF04E7F0A6B55DEC8436C8B9BA81F3AADC08707D375A1AEFD529AD61D8C856DF3E7D4A14F4CF6BA9A4FE1A554FD4C286A95A57D0B0D77DB90A8BD5A9A681526B0F9DBE4B0DF426B512BA74E6BA684FDAADAF5D32B44F9F8B90A9F124C86BAF84FDEB97C990D5
    8   2560 002001  1691504640000       34560000 12B8841E 0B77C7442440E1FFD8C03FEC9D5E1861860EBDF42E8FD3137101CD74E7F0A0E09E6DC43594D68736B92AD6133E74FA321B6ED4C87309EEBAEE9D3DD709FA57C8B3439CF9F52A4FA3BB52F61AB7AFE2577DB4FD5239BA1B6E4297CBB838B6E9354C6BBF569AD2C4C9D4BEA54A29FC0E783F6921DA5530A1BE49627577CED315A5
    8   2560 002001  1691539200000       34560000 1EF9BC4E 0B77845F2440E1FFD8C03FEC9D5E1861860EBEAD486AD3267B5E8F41D33AB67CFE0DB4C994BF4EE60DC73112D775A9F27430A9A986F935286F6BCF7AF9F537483825A55E8ED1AA5FA5AB252B9AEF79577DC08A5B77EAA51E9BE7E4AB6AA496BD8C6BBE90FA32C449AAC3A55D638873E1127BC46BE4AF9F534911F4374FA9527D
    8   2560 002001  1691573760000       34560000 4E691F74 0B77332B2440E1FFD8C03FEC9D5E1861860D75458DEA93A772FA0EFA87E521D4FE8C7A546C257E95F437CFD2D774F92C2AEA6947A4F6C3A531125784A3A905D5DD4176FAB3E2CFC852B749EE6A8D6A7683C2C7162E2D7EF9F29B96122A80A1FD8C7BBF86FD5174CAD2AB435DF55B95B73ED58293D84FAE224AB063F7B5DFA9A4
    8   2560 002001  1691608320000       34560000 775C6227 0B776EB52440E1FFD8C03FEC995E1861860F0D4DC8749DA748FDFBE5867D35C099ED8735D4C1B896B927B7133DAB5DF26B75D2C044F69B9850DF2AA635F957E96BD63F22224AEFA13F19714BE854E2D77DBB4C306BD7A5746C286E9F5772E9FAA190A1C27F0E0DB8895ED742961C47363B2F4E154A30153AA30E9567F5783AAC
    8   2560 002001  1691642880000       34560000 CC81DE9E 0B773AC92440E1FFD8C03FEC995E1861861056BC38EFA3AA535DD5824CE4B5BEAE143435C8C1B896D3B7D1DCD67CFA3B9B235ED384FA7A5A6A6B437C975BF4C7216AA4BE0247EE9FA47CFEB3F4AFD8707DC0CBB45D404D4AB568891FE6AB5E0DB72ADEEF869E12BA899F104B05FAEB567DCF0D7BEB4ADDAAAD4AB6B4D49839D8
    8   2560 002001  1691677440000       34560000 54810946 0B77639E2440E1FFD8C03FEC955E1861860F0E13EC0FD7165B5E96A7EF97B8E90DF2B4B5D321886F7C3A36132A4E856C28EA9F967D49CEB554DCD6CEF61BB4B095BE377553555512B97B5D756AF5E25C7DBC482AAC917B32BA75EE693EDF5D5437AF5FBA4AFA1A7A6D35A9D75A3A57B5AC263F66D6B2C955D28D075D2AD0DCAA
    8   2560 002001  1691712000000       34560000 B9A4956A 0B7714B12440E1FFD8C03FEC955E18618610FA33EEA992A783ADDD276F974DE099EEC6B6D2D1B8E6BA67B606BF72FA9B9D70954040FA1BB4AF9FAA535DF527CEAB3EA35E93A5B7525744A9339B6FB0F07DC3FA55A1A548E5F535699552809553E2355FBA74FAB9674F9F3EAF069BE53395437D0A3BE4CF9D51DD09F53730A3A7
    8   2560 002001  1691746560000       34560000 D49AC57B 0B778B282440E1FFD8C03FEC955E1861860FB20D390455A27CA6BEC1CCFB25A6892C0430065288D2BA674AC9298749D3E4CFDF3E4B6DFA17CAABB9AD9DF3E7D4D4D7715E93988F6BA9CD0AB43A6FD5DC7DCBE7DADD1082F6B3EE0961BEA83172E5696A0874F9FBE53ADF434D0A93D54921C4834DFAA4CA6B53534D2427EF9F57
    8   2560 002001  1691781120000       34560000 EFC8D529 0B7726372440E1FFD8C03FEDA55E186186114A2A15F4B3AB7CAB7BE56F972E8F0623E754A22156921C75349D5B7B5A1C9E1C57753D73A36F2DC8A4EA9BD87092EEA54A1A64C961CE554DF3A7D46B4420EA9606B0DF41D6F9F5778F9F3EA56D5A97D5DF3EB55A1428E99FBA4D4696C57E63CF4AE21E84D32B72FA9C22EE61CDE0
    8   2560 002001  1691815680000       34560000 5905325D 0B772FC62440E1FFD8C03FED995E18618612B693EEA9953E7B6E75B587A4B6AE9E6C34B4A156A6F6B58736105754F9FB654E9CD773BDF3E8EAA72A750AB5676E69B97CFD2D77CFA33E9CFD2AB4C970F07DC6B88DD12C42FE7397CF75BEAF99FA680969434D0DCBEACBD33B24A5FB98713B50F6C88BEBE1A6A4FA96F7EF2E3AD6
    8   2560 002001  1691850240000       34560000 49D50763 0B7796182440E1FFD8C03FED955E18618610FA13FB6FD327495B63B4E817CEA8966EB755D2BDD892D487B713527D4ABB5AD1DF3E7D49F3EACFB6155695ED7AE45F52A3CDF42D6F9F3D8895E4573579707DC838B0AC265532658755DF2A850EB5C74E949242F9CD6CD5DF484AA9CD84D09F3F4B49F3E86F9338BAF86A5AEA9D2F
    8   2560 002001  1691884800000       34560000 F44AA989 0B7749FA2440E1FFDCC03FED9F5E18618610BA13EC09C6D4794EAF44E92E39BF4DCC4716D5A584FDD26750DEEAA759F267D0DF3E7C9A1B9AD4A95774B9D4274DEC5651661BA2EE9D247D5D1DDA6BACD77DC187B6E3D7530A1BE7D4E92EBF0704F95C2FB9217AC410EDD37EF644379791F063CAA729B0171CBDE57AD709B3C277
    8   2560 002001  1691919360000       34560000 14CF3200 0B77DD432440E1FFDCC03FED955E18618610AA13FB6F97A778FE9D31B324B9B895F57737DF3E735E13EA69A143A54A92B52B12BDAEAD06B85012BBA30CEBFAAF6C2A4911CD688F54BD2F4D2C4A50ACD77DC42928612AAEB9E3F5EA9AD774FD0BDAEFAB56AD5DD26A4F9F427CFA95686F6BBFA4E9CD62359FA67EE92437CFDF51
    8   2560 002001  1691953920000       34560000 964F2FAA 0B773A1C2440E1FFDCC03FED955E1861860F5ABBEE8AD12B82D9FC25532EBA8E86BA67509529D8F68D87CF9F5686E6BAA7321D3E82FE6D77D4E73E86E5343535A152751DEBE4EEDEBD7B112ABB6BA2707DCC2888A8AB4D0DE577B0E942AEF9F39A35B7EAAEF9D427D4A1568696BBE54A9F3E7D0A3BEA4FAB5754F9F534CE94D7
    8   2560 002001  1691988480000       34560000 EA0155F6 0B7793D62440E1FFDCC03FEE955E1861860F4ADD3B2348DC715B6571CE2426AE469A97D5DFA3B8A9F2F53BE9BE4D46BBF51B1EC77CA9F91ACE57537E352DD22F9F41A895CBA450DF5271BEBDB86A6CDC7DCBE569AD27850DCB9A749FBB2AF9FA54AF9F3F86992D686A9CD3A4E9F527D59F53535DD3F7C961D15D5132173B173D
    8   2560 002001  1692023040000       34560000 A333AF3C 0B77DE292440E1FFDCC03FEE995E1861861106FBEC441D483F6F5DB56E2E39B0E5F3E750D33E74B9F2688A953DA6F6E2183114C35EE68C04CA912E7CE932E854A93E7B4ABB9870AB3B3F52BD7550AC707DD8956A6BBA7D5E8C1D5C1F42AEF9FB98559FC27D5AC267B5DF3E254944986AFB70E3057ACB08C452B75DB4D49F4384
    8   2560 002001  1692057600000       34560000 F0AD13C6 0B779BB32440E1FFDCC03FEE955E18618610F77D3DEA9F487AEA15824A2425E0D890D7D0A16B4B0ABBA870D53E56D61A0DA829BF12FA1BD8F077D256353568482DD27D0E6BE26F6E2F172215279E6ED77DD11A8E69AAA496BB8D70E1427EA69A57B49FBA7CFAA10D6A9F3F4AF9F4E7D5DD3F2ABA13F79752C37CFD2BE86E9320
    8   2560 002001  1692092160000       34560000 C6A12340 0B77CD512440E1FFDCC03FEE9D5E18618610A6E21B6B12AC7AA75D756DFABDE085DA5736E15674FD52AA5AE95755463BAAD0DF3DB6A9FA5A6A6BBE7E737D7841BB28CDC1325889573E43213299CBBB577DCC4567761C8EFABBEA52172E2D4E0DC63BBFACFB9AB7CBEB3E7F4960BB8FA92DA361ABEAEFD23FD55DF5454F954285
    8   2560 002001  1692126720000       34560000 090E9247 0B77CDEC2440E1FFDCC03FEE995E1861860EFE13AC0AD0C0A14ABD68092E267EF5CBE7F4ABBD550E126CEADCBE84FA93F7CFA9AA834DD3DB6A95C24B4D3A57CF9FA5A4FD53DAD4AFBEAD4D52986F3BC37DCD75CFE13A7CEE1357BAEBADAD114BF4CA61D35E89F3E7EFAB577CFAA215523B6EFADBF8CADF52AEE9D4354F9D3F7C
    8   2560 002001  1692161280000       34560000 B31CCDA4 0B7758262440E1FFDCC03FEF955E186186104ABB9C05A9BEAC96A3E581AECDAEF9F2673AB7BF7496210E0E9EEC6B49F3F54BA1B8B8A9F3DAD0ABBE86A955683612D67D0DEBF4AF9F56851073D855D85C7DC578032FAB4E95EE5B90DEBF535DF21737DDA186F6C24851094DAD09D574AFDD3A9CA9F3F7D59DB9AD0E93F735AB57
    8   2560 002001  1692195840000       34560000 31AA31CA 0B77941E2440E1FFDCC03FEF955E1861860D1F7D7B69A9AB534DDA986DF8BE869213F4B5E9BDA35EBBE7D6E15356957915699DA4AD5D7A97CFD52B4AA94D77CF75D2A695F5686AAB3E7CE9F924C96CDC7DBDD7E8612B7D4A98FB0FD2D754A69A5834A1589CF9ED7754DCD28559FBAACED1214CFA1A57F49F4022B9FB5AEA94EF
    8   2560 002001  1692230400000       34560000 B2628709 0B773D022440E1FFDCC03FEF9D7E1861860EC16BFD6AD33EAB4DF6B5EE183AAE95D5274FA13E7E969BAAD0DFA58095F26A6992D75D09F3F749D2D67D0DEC37B4E9A64B4A125875A9574CF953B4AAA4D77DC5D54AC8AEAEFAB4076961D790937D4C5BBF7EAAB2B7EFD2AA7EEC9367C99CC2ACFD2AB54F9525B747658234ABBDB0
    8   2560 002001  1692264960000       34560000 67A85172 0B77F8812440E1FFE0C03FEF955E1861860F1ABBFB6A9FBB535A1D24EE2C4DD895F2F6AFA1434B0D53F435DD4286A9F39B8F94D754FDCD77AFE13E60354BEB6F9CEB735E95848FAB6B74A6D544AAAED77DBDD848A1474CFAB539D4A0257D36B577645D3A7C961A674F9ED67D4A9C2735DED81C99D3B52FA1574D09F537B710D2
    8   2560 002001  1692299520000       34560000 48200CA4 0B7711422440E1FFE0C03FEF965E1861860F1DF43B511D2F7CE36564D470B5AE955A17B752C2235EB3EB571B3D88F6B918709D26569A8BF7506E25856D73DAEF6DD24D0DEBE884613DAEFD339D4FE2577DCAAB0861BE86994DB7D5C9A4856DF29AF0DF257D45FBE7CED10CAD6DD3E7CA9FA57D4ABD187608AB4C59CD784B9F3E
s=9 n=26 o=12370575360
    9   2560 002001  1691435520000       34560000 7C0D6415 0B772ECF2440E1FFC8C03FE7955E1861860D72AD3F0AD313710E6F02CDF0D2DEAE65D496D73E5CE780E7B8132986F6DA6A54DF3A5CF97B97E96C2652F77D5D79A73D7F11329A54A952AD0D54E7CFA2D77DC2C52EA3C27AE5DA172FD25754F95A57CF9D2A734A13F4CF9EC3AD4DEEF86A9D3F74F9EEB535E1A57B5D6D77D0DF2A
    9   2560 002001  1691470080000       34560000 C931EA1E 0B77582A2440E1FFC8C03FE79D5E1861860D12B26E8ED30EA30DD6B4E8F0A7A4ADC444BA9FA4B8E613F7B710C35695F35D6FD329A759F537695F3A7D4A14E7D5AB3F4B0E1527CFA142AEA953F24AD3D77DC5946AC8B99B6132F5F4ED3A7D6D2D394B57AF4ED3EB2468C47539DA4B8EDEBF7B71AC28546DC3796533E4B5DFB8D8
    9   2560 002001  1691504640000       34560000 3DCB238F 0B7792CC2440E1FFC8C03FE79D5E1861860EBE0D8B8992A7A30E9BF1C7F0A1B839EC87309EBE88D2B937B6DFAA4CF6E08B6FD4C77D49F3AAD4DFA57D09FA59CD75D422F9F427EE61BB515ABBF4AFE2577DC5C734D25C48BA22E836E039AE49F42953BEB09B52F7E99FA0D7AA29FC28362F490DFBA52FA1BE7161D58695DFB9A4
    9   2560 002001  1691539200000       34560000 6FF662FE 0B77EC752440E1FFC8C03FE7955E1861860EBE0D886AD326830E8F02533D1DAE49EC83F6E95280E5F4447829A986FA18E4AFABA97EF9D3A804C6A252FA1537AF6DC2751E8ED1AE5F3E84ADF90DEFACD77DC1188EE18D7431F444D06BA9A6F9FA57BB13A07D99D3A4B5DEBEA6AA95373095D67EA2BD77B4AB5AB6FD72A4B4E0BA
    9   2560 002001  1691573760000       34560000 4ACC1179 0B77A9542440E1FFC8C03FE7955E1861860D754BF86A95BE830E0F04E7E521ACB1A584AB9FA4B6A9FAA73512C352FDCC2850A95BA4FD0BF9B61A6C4A93A90870CA6F4B61EC24CFC852D895D262D070F67DB29A962BAA47AB7D2B94B3AA8D4A1BD875D2BDB0812C022AA7208562143B546BBF7496DD34CAC85352970B4AEA953E
    9   2560 002001  1691608320000       34560000 1DCD2AD3 0B7781F62440E1FFC8C03FE7995E1861860F0D6D8AEFC926A2FABDC2667D39BA39C4449ADF41B896B927D0DF3E4AF9F27854D2BF554DD397E99D91A635DA5A699D3E1712E24870AB3F41D12BECEBACC37DBA4F4AAE11A6FD2C37AFDD0D4B4F9C3415153E86B9FBF676DF2A879B6224B03D4F4E1BF7C5D32B490E956A707826AE
    9   2560 002001  1691642880000       34560000 98F0094C 0B777BDA2440E1FFCCC03FE89D5E1861861056BC4530132682FE6F12CCE4B5DF0126B750CAC1B232D3B7D5DCD284AA3BA8699ED4430953A855ABAE54975BF74523BDCD0EB567F3D3247CFF5427D0E2707DBA1EAC2BD24CF75BD7DB21AB430ECAA813BE90FA32B56EAB9273AD3525EFABA67B71D3E534A153A49A9A6735DF4255
    9   2560 002001  1691677440000       34560000 D51F9F5E 0B7719A72440E1FFCCC03FE8995E1861860F0E13FBEADD2284FA9BD80957B8E90DCD86B4D2D1B8D362B4AFDCD6AEF9725A50DF967CF9529AEBA9AA9CF953A7CF6229730E92A5D4DF39A4B9DBF4B5E25C7DB277F82AC4555D342B5055C372FADC1A375F3EA6D5D3F7361C494C9DC437EAFB50A643F5AB112B72A9F581CF2E3DDF
    9   2560 002001  1691712000000       34560000 FB10935F 0B77DBA62440E1FFCCC03FE8955E18618610FA3A68F49F8E7CA9D6B76F9552B699D957D5A93D90E9F2A7CA95437B0DF36A50A153530D3427CA9FBE7BADF527CF6C39CB712A98561ED324A9ACEB70AF437DB2B589E1A74B1DA2A855E1D656E362E4B5AFE5714EDBAA69D45286FA9527CE1F70A74953D80F694374F6CA57AEA796
    9   2560 002001  1691746560000       34560000 F837E095 0B779BBA2440E1FFCCC03FE8995E1861860FB20D3AE9D31347727581C7FB25A6473AA7CFD32588D2BA654F9552889553A54FDF3E4B612D1AD5DF42B739F3E7B61D299CFD2A8BAF6BA9CEA9F3E85616577DC16B960A4474AD126549614375092D384FDF5753AE953735E1BA44F613EAF67A7282E88DEAEBBE8CFA8F076F2E3EAE
    9   2560 002001  1691781120000       34560000 FF5BAAC8 0B77F8FB2440E1FFCCC03FE89D5E186186114ABA28EAC73B711DD6F56CFB24DEADEC84B99EEAB73ABAA7CF9F5786821A74B612574BADFB9B6A61AA7CF96C37CFD6D7735DD397D5DF43415DCAF7D4A5577DD2AAF4B5D772F9F42AEFEE3E7ED9CBEC7BD2BA239AC4E892C0696CBB986EB54019612CE8D0D53E5B4DFBA7CF6A257C
    9   2560 002001  1691815680000       34560000 5F9F539C 0B777C412440E1FFCCC03FE9955E18618612A6B3EE2969BF4AADCEF56E1839DF0E8DC4B5D4D286F6BAB7B5D33DAF49FB65685CD77509F3EAEE96D37D5AB529E9952583AE9437D0AD3EA509F3ED68A2707DD4E54EDFA5854DCBF7CFCB397B0ADD854A5CDBA36DF95A559F2AA4FD2D2A50A9B98096B3EA5212C27EFD30D54FA021
    9   2560 002001  1691850240000       34560000 142EA91A 0B77FE5A2440E1FFCCC03FE99D5E186186110A13FB6ACB2AA34B63E80817B9E0EDCAE9CFD2BDB092D58AB5E9BDA8E6BA57EB953DAEF9F4286F9F3DB095ED7A50A13F430CABEAEF9F3D909525CB68A4D77DD3E9E455579EAD53A56D222683BDF7395C3DB0EA32B870D4BA7BC1DB98CFB83F72FD4C354E5FB9AD014D6A6F9FBE73
    9   2560 002001  1691884800000       34560000 81587DAA 0B77DD672440E1FFCCC03FE9955E18618610BA13EC0AC6C3834E96F4EA223DB899CDC42F9FAA54E9525D710925550A1267D0DF3E7CF9F428696B57A4B9D3E747EEA63971FBD7F4DD24556D43153B2BF07DB11895F82E40AB851550D2D758829491AA5043D2F762A550DF9F7CFC9BF493A1D35499EBF7D0A1267D608B9D76D2BE
    9   2560 002001  1691919360000       34560000 097DDFA6 0B778BF52440E1FFCCC03FE9955E18618610AA140864912771026EC21964CCE0F9F444AF9F42750A13E851463F535DF2A84B12CDD699D3F4B1ABBAAD5CEBEAE95DB973612D756F54BD2F5CAC07CFE4BE7DB0CB35EC257C8E1DF56E5F587AFADD384E5F29B50ABA62B49F57495E1C4535A1A94B6E93E850EBA5A5CDD565D0D26C
    9   2560 002001  1691953920000       34560000 18ACEB39 0B7790EA2440E1FFCCC03FE9955E1861860EFABBFDEEC8C07C22BDF5532EBEACEA9577BAD4D6B0E68D87B5DFD254975AA7321D3EA4E9F2B7B5DF3E84F934354A96C2A3B1EB980EDEBD731E127AF9AED77DB0CE1B6C124AA5E5B7D0E0257B6E2257CF5EEC4B35F3E7D49FAA4B61CC3869D4B9B24863EAF4CB56A495DC1A4A90D4
    9   2560 002001  1691988480000       34560000 868B1A40 0B7756042440E1FFCCC03FE9955E1861860F5B7D2EAA90DBAB5B4431CE243A8695F574AFD7A3B0A9CC47509FD17F39F2C214DEC384E9F8E4E2D3544C852EC7CF9F29AEEA7207D11F517BCEBC78D9DFF17DAA9ECEA42BA50DC3E80E5FBA54A6B5840F9CD786FC8577CFB3BD850D52A8631F42B7612BEAE86C244D4D3397D0DEBE
    9   2560 002001  1692023040000       34560000 642262FA 0B77375A2440E1FFD0C03FE9955E1861861106DD2C2E92BF7B0DF5F7EDFD348885F3EA3B133E74B9F2A875D34E8546BA6ACAD4C756F613A56F86DB54E5FAF4AFA93A7C56BB98F1AB3A9962C3DA5B53C37DABDEC9A4927B0DEBA7D0DEBF7BAD7427B5DE58A6E92BB52F622954FA36B7D0623E535DD5354A9F3E86A9F3E74A9E57
    9   2560 002001  1692057600000       34560000 6190B462 0B7745AA2440E1FFD0C03FEA955E18618612937D3B69C8C472E9F582492C22B031CEAADBE1BE4B0ADA6D70065756861A57E969D339613298835F3E5675352AC98727177523D80F6E2F18C0B2639224707DABB7EFF8BA7CE9EB8AF5DD2A54FB5577535FBDB55A13E733A0264B0EB3E7EF9D3EA699546A696BBF7CE61BD7B5A143
    9   2560 002001  1692092160000       34560000 1A357FED 0B7718222440E1FFD0C03FEA955E18618610A7821E84A93148E6DDB56DFAB9D882BBE535E9BE42FD52AAD71CC2B746BBAAD5DF51A6ED4C34AF9FBEA6735D7547B0CF6961F25874973E4AFE9536FC6CD77DAB9BAFBA5D1AA61257D5D5A88511FB97C98AD2D8E5510A4FDF5AADB14CF2B4E93E5D5ABD2AD0E93B4AFA1A57CD2DC2
    9   2560 002001  1692126720000       34560000 DD010509 0B77DC3A2440E1FFD0C03FEA956E1861860EFB80DC0AC8BFAE321D6A8E362685995A4870A1BD7D0DF26A6B9FA986E6B437D0B34372FABAA8549FE6230D33E7E9613F734D54E7CE6DBEAD5A9BD86E96707DB258902DAA7E9923E7EE95399D5EBB98546BC28F495A0735D35A875B5A654E6BBEA6A9F57535DFA0ACBA2217B4D2D3
    9   2560 002001  1692161280000       34560000 C5832862 0B7744932440E1FFD0C03FEA955E186186104AB3FB69A1AB7A99D428A1E23AA499D29AF4A1B9AEE6C0DAEAA7474CE613F7CBA1B9AEA9F3B4AE6B6FA6A9EDB7CA9F3F4B3A1A97E95F56850ABD276E965C7DABDB976BA74109243AEBDF3F490E1BDAEA9A537EF943FAB5DC5C5E96E3DAD4ABA69CFDECDAEED2614CE61577CEA9D2
    9   2560 002001  1692195840000       34560000 B8AF302A 0B77761E2440E1FFD0C03FEA995E1861860D1EDD7B6AA9C03F61CD786E223F52E92C67D6AA3DA35EBBE7D514BEAF46E0D5E99DA0855DF527CAD53A5CA9ED77CFA13F5B0DED74E96B3E74F9F3EA6898707DABEF30D0D3AEFD4D74CD1FD280313C35D0CFDD7B61FA95D5C92690AA63F4F63AAD6215784B13A57CA955774F6239D4
    9   2560 002001  1692230400000       34560000 3B029C44 0B77012B2440E1FFD0C03FEA957E1861860D2233FB6AD38EA14E15756E183AB695F3E7B5EB3E56969BA856ABD326D5FA1A6992BE88961B986AA756A699EC37CFAB52A4FD2428FADCD74CED0C2735AF577DB266975F518A59CBF5D6DCBAAF21EC02484EA54BAAC0D86F9F574CFC8B97D0DD3F7CF9ED77D0DF3E72F763EA6A6C29
    9   2560 002001  1692264960000       34560000 1EFA8A76 0B771C3D2440E1FFD0C03FEA955E1861860F0DF2BB04932B7AF9F6B76E2E39D8890BF710E1AA530A1BB4B0DF55B8E61A686F94D34CFD2DB834E9427EE92C35CA94BF54AA95B4B0ABE6730E13E74EA53E7DBA5AF5EE0E7EF9FA749ADF20B94AC2154E9529749A8C3AEE9EBE835E1BDAD0AB584AFDCD3A695FBD854D52AA35E15A
    9   2560 002001  1692299520000       34560000 A4312839 0B773ACD2440E1FFD0C03FEA955E1861860F1DF44AC9D53F7C96A3D4D47AB5B021F3E7B7EBC24B5EB42AF4D2C28A9882686A9D3A74BAB6AADAE142AD6D725AEFA13EA4FDCBEB0494BD8EFD5917B515D77DBBEB2EADAA7EAD2C771713A55509F3D870A1B57CF973EA4E9F3A4E892C1E03600C7D4DF4E4EF9ED79CBD4BF7CA9DA5
s=10 n=26 o=12370575360
   10   2560 002001  1691435520000       34560000 5CA4D080 0B770B0D2440E1FFBCC03FDF9D5E1861860D6EDBABEFE1A76F628F044E24BB795265D69ADED785375AB7B21B3A7D39F2684AE725A89613DB099F3F2306DBE7EE92BA23AE3DA7D4ABA5855D54E7CFA2707DB96B174E6BA35AC2F4B335BF8F46E2B633BE86EADAC5499F43739DB5590EAB277D106BE72FABB9A6AA8EBAEF61BDA5
   10   2560 002001  1691470080000       34560000 208CF437 0B77C0BA2440E1FFC0C03FDF995E1861860D0F80DE0AA12754A9D577D33120E04A6C449C1324C0D5F3B7BB08C37CE6BA27D0A9BA736E93F9E95F3E8546DD286F6BA9A54E93E7D0D2D2850D4D824ED3D77DC1790B97A97F392E6A549F4340FDD397D21DC22499F3F4CE9526749A95BD713D4D5EC21BEADFA6A31EB4356E30A1A4
   10   2560 002001  1691504640000       34560000 40029188 0B7715C42440E1FFC0C03FE0955E1861860EBE008C29C893515B5D65F430A28639EC44359CBE8EE612C737153E5CE9F21B8993427D59FA1D54DF3E7E461A5548A9479CF9F527CFABBE7B5ABBF4AFDFF07DB44B286BAC42594C280429AB4296D57859B556AD5DF267CFC924A6BA6C021608BE7CFD2C35695FB9AF09F52D6E92D8
   10   2560 002001  1691539200000       34560000 B9C46EBA 0B7743E32440E1FFC0C03FE09D5E186186105AB3F869AB3F79727571CE2F0CC036B434B0DCD6A8E2DC3731153E55595267CFE8BF4E95D3E8045F3A84FD2BF9C83839A3B28D84AF9FA64C49F29DEFACD77DB182D1A45F6BAA042AD0DED78EBAB5262BAABA46345129A0D79D4D5CCE8EADA68035B2A49612C01712943750AB5322
   10   2560 002001  1691573760000       34560000 632F68DE 0B77B9462440E1FFC0C03FE0995E1861860F71EBFB69C93F70FDF577CCFBA1D4EB32F74F95B89096B5373712C3734A12E84F957022F953F4B610584C221BA2B5DD3D7EEAB525B5E128E255D8D2D070FB6DB08F4CE258435E4A27CE5EC872FABBEAD5B5BA729A2524CA6142B09892E7B1780EFE1BE8CC1392511E6F04EA57BEBE
   10   2560 002001  1691608320000       34560000 5BE07BF1 0B77155A2440E1FFC0C03FE0955E1861860F0D6F086F93A27AFB3D77E7E4B9B0D9CC84B5D4C2608212C4B0D3257B4E126B0AC64286FDD39A50DD90AE99F3F54969C23F22BC1AEFD5119BCE93F9CBAC707DB20ED11EBE75599F67E81FAA495EEA0555E8EA7B6153EAEA92BE7CB9F95889693E79BF839AEFDCBE7EFDAAB4CF6356
   10   2560 002001  1691642880000       34560000 C9A3DF00 0B77366F2440E1FFC0C03FE0995E1861861049F4386A6C2A7CA9D5B7E7BD4DB7010C3436972DB8E6B3B850DCDAA35E1A1B099ED79CFD2D27D0DF2F4296BAB547216AA4ADFA980455A54AFEBA97E96CF07DBA6BA9337240F622F5345F44194DF2A7CA6BC2A5012C374FDF401A36935E2BFD4EFA425BEADF9284F9D6B4D56C36AE
   10   2560 002001  1691677440000       34560000 18D52D12 0B7774962440E1FFC0C03FE0955E18618610AA13F86ADF2A7D3D2D28882EA1AD0DCDC6BAD338C086B4472FDD2B2492BA985112BED6A9EC37CBA9AA74F94D44B49F57377218E1C9D2B97655DD34B5E0707DC42B086E251B0EDAAA3712BE54A77575E868D77E32BBE74F92C2D8E6129AF0B625A171F434AFDB2956A63AA76961B9
   10   2560 002001  1691712000000       34560000 8C9E6C7C 0B772BE52440E1FFC0C03FE1955E18618610FA13AC0EDD135AA9D568A7EEA1AE39D2A7D59D3D9096BA67B60729A4FD329AEFA7AA4B0D13EACAD33E73AB6264AEA13EA3AE94E4CBDD3E231103AB70AEDC7DCBD86AA6C3110E9DF74F6DBE195F5447495D3E7489EBF4C9693F4B5ADA676A5F26735E1AA9AFD2D77CE635B7D09F3D
   10   2560 002001  1691746560000       34560000 0D32546C 0B771A2C2440E1FFC0C03FE1995E1861860F61F3AB835D9284F9CEF88CEEBDE09A6C44AFD2BDB2821A7410D5BCE0F9EC4430B5BE74ED2BDA5714BF84E9F3E7D4D4DB715F33A554DF257EB9F3E85515F07DCAA7B3A9F04B061D87C22A3D6D06929ACEADDAB896BBE7351AC37CE9FA62B63B70E6E26B4ADFBF7B4A96B8F461D27C
   10   2560 002001  1691781120000       34560000 B4091EE0 0B77B9122440E1FFC0C03FE1955E186186129638E8E995A76F71F577E7FAB9E6EAB444AF9ED77E96DAB4AADCC37E929AA56F9ED27EA960CAE961AA74F6B57A4FDDA54B6A15590B9F4342A9CAB7D4A5577DC2540FDF2A7CE6ED8B519F3F2B01057A6F9FA57CEAB21B709D3EAE95F3B230A3BDDDBE1CDAEAA1B8BA7153DADADF27
   10   2560 002001  1691815680000       34560000 CB4B11FA 0B7752102440E1FFC4C03FE1955E186186111B3B9EA39D667B61AD74D46439B84D2C2A5AA155B8E7558A3606568A321ADAD0E6D6A8A5F4373508BE7D1A1A584FA93EA835FA98EE5F6A83814C2ACEE2707DBBD7171F2A734EC5CA7461A97EF9CC2AF1EBBE5292C12A4F9F437E51FA9ACADFAA4B5DF42A30E92A5F3924022E9FC1
   10   2560 002001  1691850240000       34560000 F9C47D0A 0B77E86C2440E1FFC4C03FE1955E18618610FA13BB6B08BB4A975D77EE2239EA99A6F9D5D2BDB8960C87B0E1D25CFDF2653110D2A35DED854F9F3E7CF9F2AACF9F52A3BABC286F9FA490E51F58E8A4D77DC2986E94AF7CBAE2A86E92AA7D61524894AB3F4495FCE52B9F57734DF267CF9F3A7509F579B0974386E54DC54F61BF
   10   2560 002001  1691884800000       34560000 800ABABF 0B77BF062440E1FFC4C03FE19D5E1861861245F3EC04D13B511B7752356E3DB6EDCC442FA13F52FDD8D750D53E7D09F267B71F3E7CAD4BF7CE5FBE7E4886B74DEC5A517953A2EE9EC2250943153B2BF07DC314D095577D0C6BE9BC1FA5A70EBB5E5C258A4632C54FDE56E15953DBAE5F434B0ABBDB6A6C3E7ABD54774A61BE7C
   10   2560 002001  1691919360000       34560000 9402C8BE 0B77FD7F2440E1FFC4C03FE2955E1861860F0DF4FB6AC8C3D30B843247F05384E9F58415DF3E754A13E84FE12F4CF6BAB4B0B5BEA685ED84CA9F3EAD49AC47AF6C297B0E95690E52BC89697407CFA4D77DC0B8773A2A869D252AF05D57850A939B096BE5B081CD440FB76A5771F2671AE956AE99552AF0DC52BFAA143736DCC2
   10   2560 002001  1691953920000       34560000 CA771310 0B77302C2440E1FFC4C03FE2955E1861860DAF5BAC09DCB07A973DB76CBD65E039ED77CF933DB0F693B7CADD3D8E99EC38311D3E84E9F3F7CF6BBDDEF9366855A1527371EA58761EBD531EB27AF3AED77DB9F7F8ED2B9CBD238B0F8943A4FE8A684A9F56A535634750294DB8A952086BA9A5AEA9F4384FC647AF45743A4FA0C3
   10   2560 002001  1691988480000       34560000 4E8C700F 0B770A152440E1FFC4C03FE2955E1861860F4B7D2E8ACB2EA30E96F4D438CDDEF9F427D00B0FB0A9D2B4BBDFAA56837BEAD0D2D7534E1A24E2D3544AE94D9234A9557EF92BE6BBEA247CBDF478F39FF17DB9F9DDE3AAD5714A074E5356E0EE13E836DD437ECEC56830106BAEE93427CF61BEA546958A536EA44CFDEBA7D0DF41
   10   2560 002001  1692023040000       34560000 727DFE1F 0B77F4EC2440E1FFC4C03FE2955E1861860F0B025C0AD2DC490DFC722E5839E08533E74FD33E530D726870D53A7682C20AD61F267D5A1398F5C6D754957BE84FA8D37B4ABB9AF4DEAA9ABEC29A5B20437DC0B53ABE2E7BC26BD4CA543F80FDFA48899ED7A4E24B9B6E5F675D0ADBDA55ABBE9E35CD77EB69BF4B5D5A04B0EDBE
   10   2560 002001  1692057600000       34560000 4446EB95 0B7764362440E1FFC4C03FE2956E18618610FABBAB699540510DDBF24E243AAE95329ADBDF574B0B5BA870DD3D8095F3EAD19FBE435E9B98A21FA55CE622984823D27D0E6AD60AD4C36ABD5A639224707DC867B6DDDC7EFAB267CE68BA5562E287F092D37E318267C82D5D73613357D608BE7B5DD3A7CFDEC44A955BA4AED351
   10   2560 002001  1692092160000       34560000 18ABA215 0B779AA32440E1FFC4C03FE2955E1861861136E21DEB12C8994E16B55361E6E2221A57B5E9BE434A211A5AF35686E9F8D7CFDF4274EDCC27CFD352A6235C2AE1B928CDB12BE6095FA4A4FE96B6FC6CD77DC3448ADB43AF5D6C072F88BE871559FA6F9FB9A5439D6AE95FBFA50AC3956D5F3A7B5DF6B730DEF07B45FA4874A1BD
   10   2560 002001  1692126720000       34560000 2738D363 0B779B312440E1FFC4C03FE1955E1861860EFAE0DBEAE143CCE6BD755463D6B0852D67EFABA97D4E12ACEADAAEA4FDD26759A93F76333AA8549DD2230DD3E7CFA9A5A50D33DAD5AC21A6A735686E96707DC0F7AC5EA7535A9721725CAFCD4E8BF9B59FD284F9EAAB6E1F5CD0994BF8CB553EA6997397CFA1BB2E973419D01520
   10   2560 002001  1692161280000       34560000 8BDAFD26 0B77905A2440E1FFC4C03FE1995E186186104A20CB84A011AB6ABEF55430A6A499F3A4D46DE6AEE620CE0E9F427D56C257D5EB3E855DF274AF6B6FA6A9F3E835DF55B059CD2A4F9F42A6A6BBE9EE965C7DC0E7B1A1C8B0992528EAD2D422FA9534CB9FA67355FDB7D5E424A6F9F2EAD13DCD5FA2684ADFAA79D215B5692BBE7E
   10   2560 002001  1692195840000       34560000 4076EE0B 0B7763402440E1FFC4C03FE1995E1861860D0EF0C86962274AAA0F086DF0CEAE35EBE7D6AA257B6E1BE7D714D2809613A7D0D33986B75D2564953A84F6BBE7CF75D27E95F56B50E13E74FA13EA68985C7DBBEAD6EC3FAEE693E754EAD36F75726A50A9BD86EA9D74096C397D626C072FFDAD6155B84B13274AB5FC34CF61D37A
   10   2560 002001  1692230400000       34560000 E636C4BF 0B77CAA22440E1FFC4C03FE2957E1861860D221BAAEF95BAA31B5EF7E8FCD286829C1AD5E13E56A69BAAD0E9437692DA67E992C04AFD5398EAA9567E96B6B7C9A9A6715E9257F5A16A7F39D3E735BB577DB29D901D257E979D85E99F919A9E788DA8466C514DF3EAB0AC3D7F45F8CABC533E7B5DF3F531103F7D49CC92C32A2A
   10   2560 002001  1692264960000       34560000 4F36B477 0B77EC622440E1FFC4C03FE2955E1861860F0A23AB849F277AF76568732451D74D326710E1AA530A1AA755DD5686A9F268855D3E54FA9437CEA994B0E94C37CF9D4E7361CD74B0DD3A7B5E13E7CEA53E7DBDD7E2614354EABA9AF49FBE74E93298D9ABAA52F9FBA74F9ED6853D53E74F9D527D0A9BA8031FA9855E9A5ADC12D6
   10   2560 002001  1692299520000       34560000 FFDA7FF6 0B778CD22440E1FFC4C03FE2955E1861860F0ADDCA2B13437CA94EC1CF6424E8955A5537EBC2430E13E8D71B3D889698D8560A434CFAB42A5ADF4286FCABDB092BD2750AB5286FA1A4875DF29ACFE0577DCAAB086BAA7E99D43435CB39D6E9EC35D0D5257CF9342A4ED10CAEF9D3E7B4DFA57EA7620A8F9ED6AEBA96A8F0A13E
s=11 n=26 o=12370575360
   11   2560 002001  1691435520000       34560000 04D67827 0B77462B2440E1FFC0C03FE1955E1861860B72D538E99FBB795F36C24CE4CF8301C48735D4D68EE61AA7D5DED77D47811AE9A93E84FA3B9A73A220854D4D6AF49EBE55AE1BE5D49ED77D0A1A9A55AE757DB8C5FC1F3E447E9AA8759EDCE6F9F5C174E1BE4AE9FBE7B0E1D2417232ACF5D4BD7B621BE9D5D4D6AD752575549FBA
   11   2560 002001  1691470080000       34560000 2D1F3E8D 0B7774CE2440E1FFC0C03FE19D5E1861860B72B3FAF0AA117B610EB4F330B4DF71C584BCD529BA21CC44B0DB3E8695F8DA70A93E7D5DF527EF6156CEF934DA759F4273A1D3D86AA0D6B84933A4B0EE5C7D3C09B0B8537CEB5EC23115A988A9551F9357AF3E191A899A44A549FBD8EFAE12716275284E6E2252A9FD674FD33A7B
   11   2560 002001  1691504640000       34560000 4C2DDFAD 0B7785C82440E1FFC0C03FE1955E1861860CBEB43B6FDF16CB11D3E76D2439E04D2C34BADCBA8CFA0C4A6A953F4C96B9DAEA9D56ADADF267CFAB537CEA93DCE875C27D0D4D2A55ADD37CE61A9869A2707DBC285C692B7C9699674F9742AE92BD6AF3AB41AEFA94422A5FA17D0E7224B108537B0D33E888553D88961BF52F9F3F
   11   2560 002001  1691539200000       34560000 26DCA5E3 0B778B932440E1FFC4C03FE2955E1861860CBEB53B70DF92715F56F4D46EA0E0FAADB735DD51B0A735872C13297D0D5257D0E93E7E95F537EA9F29D6F6B677CE6FBE7BB1CC442F61BE7B112D27E96CF07DBC3869DCBF8031F5685610AE8CE9F437EE5FBE4AF6BE771B1C5BA746B3F54E952A54FA93F5E46B4EA6F932B4AFC942
   11   2560 002001  1691573760000       34560000 7E8D0222 0B77A2FC2440E1FFC4C03FE2955E1861860D716C3DF09FBF7AFAD6C24D24A5D69AB42A6A933CC0E6D5854AD2BE84F9EC37CB5FD75499D3A9D1D52A72B7028875D2C3234B7572AFD4B9B79A0EAD1376E253C082A96AF1E2F94A47EFA3DC74A9CD67B4EDBD850E1BD7D0ABD571AE251A6995A64AAA9BE7EFDF2D86E735354F6C3B
   11   2560 002001  1691608320000       34560000 1139BC1C 0B77F1C12440E1FFC4C03FE2995E1861860D214D8A50A01272A9FC3266A521B0892D8496D2D1E41F7589B712C24B0A98EAEF9EC7854DDA0BEBA15354E938D7CEB36A4722E3DA50DF2B190D6D77CFD8707DC0B538B5117FD52BC92F2E52A691FD77EA6142DF5E952AF0E8C37AAACB57D03A8D4E3D37CAA1BF715EB5B7EF6425E6
   11   2560 002001  1691642880000       34560000 C370126F 0B772B3B2440E1FFC4C03FE29D5E1861860EAA157B5BEDBF495E9582CCF0D1C09DCD76CF8B2654E9F279D0D066AD0E13E86FA93ECD5D53A536DF3EA6D9ED77C92DD6A31532554FD52974AE93A74ED7F57DC26EAAA1CE55595417F4A46BAB8946C95B575F4B5404E9A8BF73B1350BAE9FAA69B50D654F6E2584C133A433A1AA54
   11   2560 002001  1691677440000       34560000 DB439E5A 0B7721C42440E1FFC4C03FE2955E1861860EBA3BAAD71F925B5ABD724F63B9E0AD27073BD2EABA1F811A50DD527D0AB2A7D01243A6A94C2A55E93E7D5A142A6A624D6921FA124FD4D1A55CADBA6FA460AFB918F11D57AEE68C474F93434CA363E5500841AF5953F7E886B9855DF3D854DF3E7D4DF29AD5EB43A35DF42851A210
   11   2560 002001  1691712000000       34560000 C4C6E717 0B774B6E2440E1FFC4C03FE2955E18618610F6DBAAF4DF36AD0A9D67F56E3DB889CC37B6DCE688E6B3F5309FBE7B61CBAB6E9D427B210C2ACFDD527D01256AD5ABA679B1CD285212D244F933E86AA4F07DBA5929C92B7B00FD854F94EFAF46B52AF4D7397D0D4D37CF9F257EF69C2A4FD525A8951258135D437CF9FB97D5A157
   11   2560 002001  1691746560000       34560000 298F8538 0B7758252440E1FFC4C03FE2955E1861860DC213ABEFD327791E9704CE30B9AE9A8C4535D52990961275309FBD88F61434CFAB434B4D53DACBDF91A509F577B0DF3F48FB5B5870ABA9A35E13F75613757DBA0E31D5927CF69584B0A1D67CFA1A274F9FB8A6B9F52AD59FA986E92D27EE6DAA54E69C37D59FBE54F755B7E99F3B
   11   2560 002001  1691781120000       34560000 68B65335 0B779CA12440E1FFC4C03FE3A55E1861860F5D83990E7626B046156D8A953A86969D6CD59FD1E8A5F43839DD477AF61DDEBBA58A9A14474A9CC34B5A97074D6B2E7739FA97311CAE7D45FBE84F6E264B6AB3EB56E1B9869CB25A6FD2D27CFD2D774FA143995A02675091262B4DD42B3D5FEF4AC21B6B1326A2FE9572D49FB9D8
   11   2560 002001  1691815680000       34560000 98A2EB6A 0B77B2502440E1FFC4C03FE3955E18618611075BDF2995BA530E6EF807BB9BEA39CDB5549F525686B3F851D2BE7EE9F3DAF0A9574509F29AEFA9A64B608BE7695F3A74F9F427D5A342A6ED0A74ABA4DC7DBA0874D049B2952399086068534A13EB2952D67BC1CC37CF5F274B0D53A53512AB4B5A9BF6921CD74D5A940195DFB8
   11   2560 002001  1691850240000       34560000 6EC9CB48 0B771DE62440E1FFC4C03FE3955E18618610A9F3AE0E9DA671AB83F56DF0B8EC366C2A6FD256AEEA72C4111D297EFABA5A55A956D6E9D29BEFAB434B4D4C37CB6BCF67CE1C1D896B5286F9C447B5B9707DB8CB4FD258B95D2398896242D6A9F527CFE12A4B5E1584C454D3A4FA7A674F9CD7736DED77D112C27CAA15276FDEC2
   11   2560 002001  1691884800000       34560000 BA61176A 0B7758C82440E1FFC4C03FE39D5E18618610A94C3AEAD33FAAEDEEF4EE38A654AD0C43AE620D84FB3B67B712D67D5D5125B612C37C99F4284FA95774F912A4C6E2B883155BA2CED30F7F0C7DD8056C707DBA09247CD75559FADADC21C254C1F8994C2188E61407CFEB3A8559FA588969BF1AFAB56850A22D84EA9BE7E45FBD86
   11   2560 002001  1691919360000       34560000 F7D99EE3 0B7747132440E1FFC4C03FE3955E1861860F0D53EAD615277AE9F58234623AAE99D3F735DED67CFB7A77B11257855A9A7410B839CE99CD84B4B352B8450D3AC95FBE797294288A54BD2D5D4C97AFEC707DBA582F6D48915DCA4A50E0437D09D3DA4FABEF4CF93A9AD9E92E554DF26A34DED84C95F534D5A12F431D326735D53E
   11   2560 002001  1691953920000       34560000 819FCE95 0B77A1A32440E1FFC4C03FE3955E1861860D5E1A5DF5DDAB7AE956B5ECFAD37C96DBE854A14356992A6B50DF534C9752F530DF4354E92C37D4D4BF54F92DB7D0A13E7361C3E574DEBD7B71EB08D0A4DC7DC0C8496AD7BCF908CAE9A2BE84F9F2E4AFE1BE4B0DF3F7CE9F8C86F9F2E7D0D5257E99F92534DF3E7EF5FAB233A156
   11   2560 002001  1691988480000       34560000 9BE45A7B 0B77F14C2440E1FFC4C03FE3955E1861860EFADB9B8FC943795B63E5733B1BE8A61BE4CFD5A0750D2587D106EA7EE6953A4B9F3E853D3127B3893F7C9676BA6A6955A8E5F3A43714D69BBE9D7803226155BA4B6A6B3EECF9C3EAEF604484F9EBE5CF9F56AD8133E8509F3E731D32B7AFD4C3556A939870AC2524A61BE7BC5F29
   11   2560 002001  1692023040000       34560000 549DB921 0B779B5A2440E1FFC4C03FE3955E18618610A63BE850E949170E156D945825D69952A735DF4283B12D3855DFB9855A00D72FDFA64D46B3B4CF8AD7A4F9D437CFA6BF7AE9FA0B76EABF494EC5286AA05C7DB90C2F6BEC7B712AA554A9437EF9F21735E6D77D5DCC354AAB527E961A6535A9BDCEA61BF24F61BA86AA952750A152
   11   2560 002001  1692057600000       34560000 B0293E3E 0B7749F42440E1FFC4C03FE3955E1861861096BBF7CAD4C87B4AB577D5A3A6B8886A9ADADFA9754AB3F7EAD2D256E6BB9AD6AC3A430DFA490E6DB9A645FBAAC329BE5311CAA26A6C16211EBD26FEA05C7DBA0E34B5615B0A1A47DB29518719CD37B46C3E74E63BEAE96BAA7D5A990AEFA1437B4DF429D5DF3F73B126786E5FE5
   11   2560 002001  1692092160000       34560000 69051F97 0B771A5B2440E1FFC8C03FE4955E1861861096E08E711EC484975BE58DE4CDC0355A07D5E93E7CFA1B5D70E93EAF369A673612D67D4DEC374F9FBE7C5383F4A7F12599C213D8A854C27321D429B0ECF07DC129089F8E434A9BD754A1AAA6A9F2954992D2D6F75D374A5FA67AFA1BE54EA1A556F61BE84FABAA550DF29B096938
   11   2560 002001  1692126720000       34560000 ECB3DF54 0B7721842440E1FFC8C03FE4995E1861860EAABA2B6AE72C7282E427746439AEF88C256AA141855E00CAF0DF29AF36D447549F3F4AAAB435CA9DA97BAD552AEE9F39AD0DF42AD4AB52DD608BE7D46F5C7DC705CADF25AE9A1A47D5EB527EDA33E76F55BEB0469BA7EA75C75311CD34EAFB6D0E3BB5B0153B7C961477EA932686
   11   2560 002001  1692161280000       34560000 9D86A5CD 0B77BF7E2440E1FFC8C03FE4B95E18618612898177D5EC0E754D3434B82129B0A71F1612B07CD9F3EA5063AAA6961A5CEFD2C374ADCD7851E9BF7CF9CC2D8F9543EFB57BEFA32C555DC4473AF5A58709F3A4B4D2BE90A9CAAAEEA9BE7E961BE7D4D2AF74A6C3976E612AA1C5F2A74F61BEA746156873620E4AF6C217D09FB9BD
   11   2560 002001  1692195840000       34560000 0CC7BEBA 0B7767E02440E1FFC8C03FE4955E1861860D0EBBFACADFAB514E952B08F0BDAE95F3E7D1AA257B5D7AB4AFDF3E7EF6BB9A5112D27CFA1567EADCC2A699CD2AD4A15AB045F56850DF2674969A64CE6F5B87BD87EEA0AC74F952488FD26C2495F3DA6A2BDB84FAB42855DF2A7D49F3F72FA1A9A50D33E850DF42A6F9F3A7E96156
   11   2560 002001  1692230400000       34560000 B91D60AA 0B779AB22440E1FFC8C03FE49D7E1861860D12127AE4D2C2DD5126F56F3052B0829BD7CFE93D8EED4BED6F9FD324E6BB57EF9F3E7EF9FA4AEFABBF215DF2E7D4ABBE535DEBA555DD3F230953F4C96CDC7DBF586AC8A9D6FDF3F58461C0301F56CC7BA686FE1267F0D4BF7D5D5A588252BA7CA9326AD09F3AD8461BEAEEA024B0
   11   2560 002001  1692264960000       34560000 8C48EB43 0B77F2372440E1FFC8C03FE5955E1861860D1E140850A1C0495ABD3768EEB9D739D267161F3E830B691737133DB09613B56A67A64CF9F57515EB532E990BE86A9C6B7D5126C710ABE67CFA15352FAEF07DBDCAE86BAE7D0DF3F735E9BE4CD92BE854A1AA4AF9F5376D5CBE834E1BD7CFA9BE736DFA67CF9FA57D10ABF731D2E6
   11   2560 002001  1692299520000       34560000 7A8B0E2C 0B7785102440E1FFC8C03FE5955E1861860D6E15CACADFAAA4E744243AA424E0A5FB9856E9C19B5F5AAA6E953E60F69368510A3F4CAA1529D5ABBF2B0ABA5A6A6B534B1E0D77EA6BBD854D551B0962707DC2FA835FAA54FD4C37B6DFA5854DEC354BD2BA74E61AA84E92BE7EE94D6AD4A1BE56969BA4EF6156AEFD2BE86A9F91
s=12 n=0 o=12358643712
s=13 n=0 o=12378568704
s=14 n=0 o=12378568704
s=15 n=0 o=12378568704
s=16 n=0 o=12378568704
s=17 n=0 o=12378568704
s=18 n=0 o=12378568704
s=19 n=0 o=12378568704
s=20 n=0 o=12378568704
s=21 n=0 o=12378568704
s=22 n=0 o=12378568704
s=23 n=0 o=12378568704
s=24 n=0 o=12378568704
s=25 n=0 o=12378568704
s=26 n=0 o=12378568704
s=27 n=0 o=12378568704
s=28 n=0 o=12378568704
s=29 n=0 o=12378568704
s=30 n=0 o=12378568704
s=31 n=0 o=12378568704
s=32 n=0 o=12378568704
s=33 n=0 o=12378568704
s=34 n=0 o=12378568704
s=35 n=0 o=12361482240
s=36 n=0 o=12378568704
s=37 n=0 o=12378568704
s=38 n=0 o=12378568704
s=39 n=0 o=12378568704
s=40 n=0 o=12378568704
s=41 n=0 o=12378568704
s=42 n=0 o=12378568704
s=43 n=0 o=12358041600
s=44 n=0 o=12378568704
s=45 n=0 o=12378568704
s=46 n=0 o=12378568704
s=47 n=0 o=12378568704
s=48 n=0 o=12378568704
s=49 n=0 o=12378568704
s=50 n=0 o=12378568704
s=51 n=0 o=12378568704
s=52 n=0 o=12378568704
s=53 n=0 o=12378568704
s=54 n=0 o=12378568704
s=55 n=0 o=12378568704
s=56 n=0 o=12378568704
s=57 n=0 o=12378568704
s=58 n=0 o=12378568704
s=59 n=0 o=12378568704
s=60 n=0 o=12378568704
s=61 n=0 o=12378568704
s=62 n=0 o=12378568704
s=63 n=0 o=12378568704
s=64 n=0 o=12378568704
s=65 n=0 o=12378568704
s=66 n=0 o=12378568704
s=67 n=0 o=12378568704
s=68 n=0 o=12378568704
s=69 n=0 o=12378568704
s=70 n=0 o=12378568704
mt=0x76bbb591d580 n=71
s=0 n=1 o=12378568704
    0 1195573 000001  1692205515000       45045000 9BDD8DFB 000000034601100000002040010C01FFFF222000000300900000030000030099350300004E3400075300E8000002A1420101222000000300900000030000030099A001E020021C4D8D35924F841470F1C0903B0E18361A0842F081210088401006E1A306C341085CA0A021044170B02A0AC28035407080E007D02B4180A8200B
s=1 n=27 o=12358785024
    1    482 000000  1691437860000         900000 232968B2 40F19B80602C6077609D60EB579539BD90070FFB8611D65F679D70E0D97432BFBD4558F22AF35C98D919F29356312CD96652DCCCF87D21CCB6996223360E24C1EEC271557827D1C0B00F2B6F243D0A4E20978FDAC975AB6AC80DC8019767A526AC00F7436FDE445F0F66D1E7EBF8ADAEE62667BDF4CA7C3A3D0BEFE8CC56FA81
    1    478 000000  1691438760000         900000 4B41E528 F0EF9BA8702C6079609E60E94BAF575B661144C3E0B66227480F3564EE03DA8AA17CF98DE73C7B33B8E50986595D037551405A50278BC2A5D9A7453A09697707C23DF6206F89223FBDAB8DD960FDE9AA56E351E1F4572E306C64DFB3B008E2682CA8764B0D5FB3DF50E178713E4488202BB0F83A22A8A80D0BE1B108A9747862
    1    546 000000  1691439660000         900000 42197DB8 F1119BD0702C6076609C60EB16A936A883C57C55106525FC1B11D49A51543EE5AC3F70B1F86A1DE4D5B7D9992E737B69089437AF5CC0FE7BC9C45D1F840D0D1B9B7F1C1232F755E9D927F0C796DC9159982D7BB3FE4387937FA0A98583431126B5C0351B3031F946983C295EE5F27CC733EB6AE8ABE45E8C1AD27BC36C9F9BA1
    1    482 000000  1691440560000         900000 E488C1B6 70F19BF8702C6079609E60EB2436151AD63FD56D9531FC55AF380E3C46F5316A20B02C4C0C6388148C2C14B8C9636981FE19059A5CCE1C2EFB53815CD8D79F97E33FE7C43C06B3E3C3458D629F6CA8913F5D87DC174B776E766C1B4DBB7E5B6B8D82BEA425406351A49345CDE0D608EBD8E323AA7021A44D1BC9DCCF90302B1B
    1    488 000000  1691441460000         900000 3FE07DBA 60F49C20602C607A609F60EE5307B4B19DC08D4DA2B24E45E184F28F8835F8B2AD546DB949506F8D6FD5E3852282C93C51D690AE3C35265D1131CA3500C70156927D49C9C2BF7167866417E848867E6CB5D8C8CDFC241497CACA397A8A85F94D6EC5EF2019586762B5D994CF4E028AA30A0AD2A4CB7434A003F27169CA40EEDA
    1    494 000000  1691442360000         900000 93306CC5 C0F79C48702D607D60A260F102909AC16879396D6047499608CAE0BBF5D3BA73DC958662CD0E3EDFB955E5F3A6312EB4D080AF48DCBFE244A3521D49DC57266D7E1E276424D6D9AE56A5683211F31BDE8A3503553A402D1486FB41BB3E212E484F75AE507C9D03BA3A052FBB5C602447909AA248FCBDA83080C2BB3A5E7EEA8B
    1    484 000000  1691443260000         900000 34E5B39C E0F29C70E02CE4F06078609E60EB70B9C149B311955ADF5BF99AD733D68E194C58BCA6E3BAF3CD6F69B2D7A5459CEE6D2D1BFADEED9D4ED11C977D311EAA9FE68A5289D60903E508BC4236388362CF4E77C88AA8F5A45375233E97911F6DE2D0BDA3E180FB5B7FF7BE59D5C657F0FC49855D32762CDA8D2F5EE2175E6E12CFFE
    1    482 000000  1691444160000         900000 874D92BF A0F19C98602C6077609D60EB0F900A27BAF1BE61E3A024E0779962A3961225D3DD67D5758C583C180369C8DAF42DF4D25524AE1FE27C96BEC59794D691D71D95767B5B4D44EF484F8B3E1F63A24AFA4D7FE2C3220AA8D1CFE716AB312EC7B383E9BC968504A4B67842FA740BBD571FF1CEF9D05ED68FF7D8B3F9E4CD854888AA
    1    474 000000  1691445060000         900000 2AAD856C 50ED9CC0602B6074609A60E753C73303D6B1916DA6BD7650ABC8D0B44B1FE248A652EACAB35BB79D08FF722A737F6D56BE1917F6B3EF253C95B4AB2E0F450B7F3F34F16228EDEC75886DF878E4BC28FFD288EC8F07D64A96A5B7EBA28F518B4E1F5B41B1878F6F83847D042F8ABDD02EF47F41CEB9E9A40CAECEB2D94BAAD33A
    1    480 000000  1691445960000         900000 95A81D0F C0F09CE8702C6076609C60EA722E5624DF716099367F0D04344EC5622E21B5436D605E593C8E85B2932AD94531FE0AC7674A30689E99F06A529072F415E22EFDFF7175DA3C19128C7879A3744FC747D768B651A66022E1AF990EED2A1C93499EF6D4CF143BF3F4B9B14E101D1FD222A8F48CAE574741C619859CECEA2D3147E0
    1    484 000000  1691446860000         900000 6F3B1D44 30F29D10602C6079609F60EC5A0FB52B18940E2A2831A4E66EC293415F857F507239580DB14DD8B1291B16A8C74AA3EFD839CA3ACFB13C52BE9DADC5DF7D048B32497F396E9BD3593D455F17DEAD0F873D13561BE7DF1C3469EDC097DA38E336234CCA38703638F9AB336AD4FF95A97F18D54FED4D2C14D7499C1AD2E1DB0FAA
    1    476 000000  1691447760000         900000 7724D6D7 C0EE9D38602B6076609B60E81FA2E9A5F49D291D8911B2EC1D0E15FB1539EC0BDAF85CE7F1EC97A77C70BEDAF215983FF949897F071D2DBAC35EC1FF0DAA007D86D9078AF179EC367EF338BDF62FBC8C9CB87A219E6292118DFFBB5D3067F4E06DD07BB8A395983F33348D1F653933FEDB2944618DED87A57272E0BB7BD95DAB
    1    476 000000  1691448660000         900000 A5FF8537 00EE9D60602D6077609D60E831964E654FD92C5FD55C6624ADF2853BB31F07A3FEC9DD2EE0D66C3963582E5FF499A94F13D390F30EAE476329281A96869568572B32C702E2EA5DA85D4B425EF12D523443CE9F857D93C16626D4569D20D4751A7DDBA000E9EC350AF9DEAA88A78AD86D70B743DAD828A2F7FFA5165766E54A95
    1    498 000000  1691449560000         900000 726263FF A0F99D88602E608060A560F349F042F6096F0FC70FE3FEB24AED5D55E95A1FE7E829CDA83D262077B5A7112555F2525ED7FC4945BB0DCF6E3563CB49C40EBEF1A78CD9036B1A63303BF0DB55BB92FE80600DADC7A821235439A57FB38180BAB61FF0B93072C0FB7B8088E7130F9E02BFD8E38C0EAC67A61CC985EE9E8AD35B37
    1    496 000000  1691450460000         900000 DBFEAAF5 20F89DB0602D607E60A460F252EED0AB5C39311BE755F8FE944604B8B7411AF2DA931E315A0DD0908878458F8711EEB3C5A9B2A0CEC371BE3BE0D3CD5BAFAB2243204BC3BC79D30A322D106D5F4C2A0E503735197BFDDD35E7542FD281554FAC86D4E3A48A065AE5C7F75FC0CE6EC6C6DEB69B8BDF779954ED0B0B034BC30D58
    1    488 000000  1691451360000         900000 A86D7CF2 C0F49DD8602D607B60A060EE0E5493EE6446DC45371944F58C68434956649EF2D2381D38517505895B451A769AF396B60592DC82A598866673BC15300657C34140F49788A9F306DECC738FCEA910612DDEB05A47E2C4B8BF9A445AE7E19C780AE92C0A3C84190F3BB8852A89C4F4A3D84BA2D62C3EE2040E8A4C1A6D9F38FFA4
    1    486 000000  1691452260000         900000 9D458B30 70F39E00602CE079F470E09FF47060EB5D689FB2DC06429D33F57A62AED9967ED2606B860F0F7C5E2D53CD97DC9522AF6194C6012C8284B34A03DF9E2DB562C860ACBBDB8B9AAA8E5EBB69A52061483F68E1DD4CE74ED8F64748B97AB0D2F83C758D43E63C806BA58084C0A3BEE76BFB096458EB480405C85641CDD5325C3C13
    1    478 000000  1691453160000         900000 ED01845D 80EF9E28702C6076609B60E911C763E0B24B02EF9699F624EB95DB36B9566428F71C33D658C3342B09A15DBC611FC18767B7AA866AD3C162C4D186C3DC712FE51AC0874A59B560D18A33DF6BC34EB8E659D24D229EF984EFEFC3B73EB0D648DA7880FA49123F441E2BD42935CEB19B68145ACE9BD839FD0C0FB3D4D28DFF42F3
    1    478 000000  1691454060000         900000 39138A79 70EF9E50702C6076609B60E95CCFDBB3E7F51B236B96EE287BC959D588EA8DF60F923D16FE92630D6D20EA2D6061C3E6C14D33D2D11D4060170F47D2327502E8BE3B4CF958F7266E7639DA299B961DC7D2A14DD2B4590DE06337C256BA79AEF880005A2B4FA7DB0EAFC368CBAD158F4BDF04D3E7E7CF2FDE8F7367FA7E0CEF3C
    1    480 000000  1691454960000         900000 00343910 00F09E78602B6077609C60EA64F569996E35AD64F3631A4D3B9E397C9675FFCD3B616D06CFDEAD8F1EB30686F795CD60A5EF82B7D3601D58875421BF9A1B731C368B80246438E0887EF6ADD91169F31FF3C05269828D1D2E4CCC2A93E2F70E182DD73EFAB35C92CAE319EC53EC3BF1727DC3A4D28ADC1CC7C3DDB0C54ED71291
    1    470 000000  1691455860000         900000 722F7F87 10EB9EA0702C6076609A60E5320D6E1171F4225CD4D682B96508DCF21076E15103F97C26B18EA7D356018A2DD5B2D9E98AA22E99DE9A344C9ABB10D6A971EE66EB5AFCCC28D98A37B43571CD92AE91DAEED94F8A35F894E4835F20D3E4832B3D8000F0037E6164C9EF605078275C346F8C43ADC29B6D654E42A8642EF8F1392C
    1    476 000000  1691456760000         900000 D82BB1F0 70EE9EC8602C6076609B60E876786530E8AD6BB46C1A5ACBDA1C4C2CB94E6605C1C149B50EA29DFCB63727D0FD13917B03B59CC04987252BDED9AEDB3810E61F71A6862260630BA913607E2AD3C58AF2B8B727EA2364C391A1BE7EF941C9DF7C800008A74CE99CDFCB3BC9D87254DE9BB195EF265E4F728EA5B3DE49B9BAEF33
    1    484 000000  1691457660000         900000 6A6AE1DB E0F29EF0602C6078609E60EC4BCD4EE2CBCC6EE3252A7E5E75DFC737D5C2841B04F70A3BAC54A58C129A8EE5BEDBDF3D9DF66F99AA0940A618F06F5ACEBE1C2F3AFFBC2C7CFB0FF7C91869A7B1F314D16ECEBB706256949B3F727DDB6E2C54458C00133218D73161332DA3A751F34EBD6B46DD27EED3F78C162174E063BBC96B
    1    494 000000  1691458560000         900000 25A124B0 D0F79F18602E607E60A460F1235BFD5EA5C47C2FDD42DB62F0842924FAF03854892EE27A80D301451F92D67CDC0E5AF90DD46AA62EFA4CFFBE4CCC8D6C630709C62612E9F2D4BFBED0F6374F28587EEFFAB50BC135CFB1F02AC6F507F1C74756116E88EB2800779E21B018520ECA24BC2ACB547932D78E110570614C8A08001B
    1    490 000000  1691459460000         900000 EC75D211 E0F59F40602D607B60A160EF80849A48EA898BD5610437A5FCA437448436469CA7DCBC78AC0ECC951FDB9FAAFC91E6C6908C2D6CF572DCA93FCF37723A37D08DEDBF9296261B16C5789E4BE7AAF0EDA376A165258ED23727257E4032B6CFBE0B8A35A670F5668088E79CE6722CD87A94DA3892687C49509411BED06A1C06FAFF
    1    476 000000  1691460360000         900000 BE019FB5 50EE9F68702C6078609D60E81337C0AC14178D2E87C9646B233EB1E58CB35C090992B88E34E8CD6160DC82F01740F1B4A8F9BDDEDE31BEC3D6F8BB29597F2113D62F6A524A9054FE195E508DE19DE5E6E3B6F8B8D2B94FDF6DA3DC15B686FCB5E0000E374B5FB3C54ED0552437A69DBF7FAB605F5504BEDAF397503B2B536E59
    1    480 000000  1691461260000         900000 8CCA2125 E0F09F8F602C6077609C60EA4781B51398F811C18ED6FDCD4575CA05B39108FB9CD3F7F7B7F0A02E7EA15ED819B8C62C10B4B95B87965681D2158D3B983F7B0A477BAAE49CB5942A9DE4F380AABB71FBD09C142360C77886F1BAA5AD4501E4AED60041284C6EA43D5D35DC99DB4026F43B66EDF133AA33DD8B6C5BC9CF9CC99C
s=2 n=1 o=12370206720
    2   2560 002001  1692299520000       34560000 4301E0BA 0B7725AA2440E1FFD4C03FEB955E1861860F1EB3FE099FB6A49697024E304DB89693F7961ED6A50E12A7B729AA4CA6BA5B0E6954230A1BDAEFA13EAEFA92A84E9539869A753730D539AEAA9A184FE2577DCAEB68A3A64CFABA6564693EA6935BE8759FA4B55DF3DAEF9F41A709F52A50A9BD8899CC384BA94354EDAC354AD0BE
s=3 n=1 o=12358637568
    3   2560 002001  1691426880000       34560000 6EC41641 0B77A8052440E1FFCCC03FE7955E1861860EBE13AE8ADD27710AB71447E4CEACADCC4730D4C28E82BAEAEAD2C2B095F267EA6B437D097B9850DF427D4DCC354FC45155C21B64CE9F2AA546E25A4FA2707DAA5C4F92DBE2992B5E2A155C4296B575EB958BACAABB574BE1A4AF106527CFD73EA55D53E86A6BBF431C8C37B5D4D6
s=4 n=1 o=12370182144
    4   2560 002001  1692290880000       34560000 B1514C76 0B774B4B2440E1FFD4C03FEC995E1861860F0B02BACFD7A67CE696F4F43AB4B885F3E7B7153E2B5EB4285B12EAAEFDCBAAD5D33D86FDD3E4CEAB435D09F3EA6E2BC2755A1577EE553E7D5DF3E7C9A2577DD16809A3B97EB61BAAD49F3DE8F69BD855D7582CFD742ACB12C374E9AD75D13AEF0AE8DB4B1D54515ABEB5536DA6AE
s=5 n=1 o=12370575360
    5   2560 002001  1692325440000       34560000 2DD7D3EB 0B7721002440E1FFCCC03FE8995E186186104A3447CAD3A67AF69DC4D3243A7EE5F527EFA0D2D7477587CFA952A6F73AE7B61D2AACFD2C286F6E3973B1338AEFDF4E9C96156B8FA92E9EA75A64CAA4577DC5B86E8B4756E6DBE750623A697123FACFDFA65B46DD2D6A28C3B0E9FC27DCB6F086421DEAE02B710AB6F7EF6BC2AE
s=6 n=1 o=12360585216
    6   3820 002001  1691550720000       11520000 396A20B9 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF440000000040000000000000026800000370000007FDA06B711A49ADC0924DF089A026E245CE307B5AC5B16B62D6B5AD4A4A4C3108210D2307B18B5AD4949D052904210821084210D2307356A4A94939CC718C610842
s=7 n=1 o=12360585216
    7   2012 002001  1691585280000       11520000 4FA63A8F 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF43000000002000000220000002C0000002A00000019CCFA26E37EA756BB36B9AD272AA336FD20F7358C5B16C5AD6B5A52941482104210D24F7396B529494A52839CC7318A4188410CE2F7B56A4A54839CC620C410842
s=8 n=1 o=12370575360
    8   2560 002001  1692325440000       34560000 172F0BE9 0B7705C02440E1FFE0C03FEF95DE1861860D71F43B6AD3A2A2F9D6B7EE22BCB6F9FA5870A13AA6B613FACFA9B9AEF776B9B61FA17E96B5686F9FB8A5AEB42A3B2927510ABC27F4D2BEA50A1A58EAD63E7DC484C9AD925839C3EB5BE1C254EABA0AF5A1A5ACA953E7509F3F72A9FA97D5D38D4B5DF5354E9F2E850E93F72A9FBD
s=9 n=1 o=12370575360
    9   2560 002001  1692325440000       34560000 31A2AB15 0B770C302440E1FFD0C03FEA955E1861860D71F4484AD3A6AAA6A567EE22A4AF5DCC34CF9539D0F618E86461568709F429D0DF8DA54A1537B5DFB8ADAEB41DDB5EA69B3D4D77EFD25774FA13F735E2577DBA686EADC4569DA3F7D49FC17E9363E7CF9F3E229A15774A953B49A9F4384F9F3E7CFD2D34CADE43855DFA98CFA1A6
s=10 n=1 o=12370575360
   10   2560 002001  1692325440000       34560000 A4DE7D35 0B770E682440E1FFC4C03FE2955E1861860D721587AC138DB4A9EF124E2439AF008567EF954DD0B613EDE9A9B9B895EEC2161529AF0D53E7CA9F3DAD5F5527BB292683077DB7EFA13B42FA14F734E2577DC444E23A13263945776F5FBE535DF3E7CFA1CDAD09F3A7509ED86AAA95A7BC1CD34CADAAEA6A9F3F4CA9F3F4C45FB9
s=11 n=1 o=12370575360
   11   2560 002001  1692325440000       34560000 A2D41576 0B7783592440E1FFC8C03FE595DE1861860D6EB57DEFD60E790A7D74EDEECDAEFC8BE7D5A1B9A749F2AAD514C2855A0115310B29855E13A7CFD7417D0DF2DDDA1F2652B6BC356E9EBEA50D73E83616437DBDC7E36FA74E49CAAADAD5AA2496DBA535DF5284F6C0D5B0DD2B494DEEF7B6E13F430DD2A7E96B437EE6BBE7B4ABD2
s=12 n=1 o=12358643712
   12   2560 002001  1691426880000       34560000 6C81B4D7 0B7771AD2440E1FFDCC03FEE9D6E1861860D12927850DF9348FE757262B0D2E049C5D716DDA55D36DAA7D6133986F63BA837152585ADFA4AF4ABBE7D49F3E5559EDB235EC3D7D5ABBA535DF3E7CFA2707DB8D62A62C2712066080877E07D0E9C2C6BC286FEB2B8511257A55D541B94ABA67BC4647834ABBA4AFE93EAF45FC1A6
brymer28
#9 Post by brymer28 » Wed Apr 03, 2024 7:54 am
log comment #5
005003:0000 Failed to save title 0 to file /dead/xcode/mmcdump/sr2/Jumanji- Welcome To The Jungle.2017.mkv
002023:0000 Encountered 41 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
error=0x06031105 count=3 name=Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR
error=0x06043E02 count=38 name=Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT
Encountered 27 unclassified errors
error=0x40000005 count=27 name=Posix error - Input/output error
005004:0080 0 titles saved, 1 failed
DEBUG: Code 4279607298 at r_@L.-a9'5>uU$kP-:121265246
DEBUG: Code 0 at r_@L.-a9'5>uU$kP-:213133388
DEBUG: Code 1 at r_@L.-a9'5>uU$kP-:213133388
DEBUG: Code 2 at r_@L.-a9'5>uU$kP-:213133388
DEBUG: Code 3 at r_@L.-a9'5>uU$kP-:213133388
DEBUG: Code 4 at r_@L.-a9'5>uU$kP-:213133388
DEBUG: Code 5 at r_@L.-a9'5>uU$kP-:213133388
DEBUG: Code 4279607298 at r_@L.-a9'5>uU$kP-:29396943
DEBUG: Code 0 at #b[W~AcF~cB0d?gP:29401750
001003:0020 DEBUG: Code 100941314 at #b[W~AcF~cB0d?gP:121271617
001003:0020 DEBUG: Code 100941314 at N]DAZnR|jdbq4LVk:213130559
001003:0020 DEBUG: Code 100941314 at <mz-%C})09hs`Vw;I^:121263429
001003:0020 DEBUG: Code 100941314 at <mz-%C})09hs`Vw;I^:121262302
002003:0000 Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading 'BD-RE HL-DT-ST BD-RE  WH16NS60 1.03 M68I9IB5756' at offset '524288'
002003:0000 Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading 'BD-RE HL-DT-ST BD-RE  WH16NS60 1.03 M68I9IB5756' at offset '1048576'
002003:0000 Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading 'BD-RE HL-DT-ST BD-RE  WH16NS60 1.03 M68I9IB5756' at offset '32768'
001003:0020 DEBUG: Code 0 at >ktoW_gY2kQVc0_@a>e:213129777
SDF  v098: HL-DT-ST_BD-RE__WH16NS60_1.03_212005081010_M68I9IB5756
001003:0020 DEBUG: Code 100999428 at #b[W~AcF~cB0d?gP:121271617
001003:0020 DEBUG: Code 100999428 at N]DAZnR|jdbq4LVk:213130559
001003:0020 DEBUG: Code 100941312 at #b[W~AcF~cB0d?gP:121271617
001003:0020 DEBUG: Code 100941312 at N]DAZnR|jdbq4LVk:213130559
brymer28
#10 Post by brymer28 » Wed Apr 03, 2024 7:55 am
log comment #6
001003:0020 DEBUG: Code 101000192 at #b[W~AcF~cB0d?gP:121271617
001003:0020 DEBUG: Code 101000192 at N]DAZnR|jdbq4LVk:213130559
001003:0020 DEBUG: Code 101000192 at <mz-%C})09hs`Vw;I^:121263429
001003:0020 DEBUG: Code 101000192 at <mz-%C})09hs`Vw;I^:121262302
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading 'BD-RE HL-DT-ST BD-RE  WH16NS60 1.03 M68I9IB5756' at offset '524288'
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading 'BD-RE HL-DT-ST BD-RE  WH16NS60 1.03 M68I9IB5756' at offset '1048576'
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading 'BD-RE HL-DT-ST BD-RE  WH16NS60 1.03 M68I9IB5756' at offset '32768'
Application exited at Wed Apr  3 05:14:39 2024
#11 Post by dcoke22 » Wed Apr 03, 2024 8:27 pm
Here's the first error that I see in brymer28's first log post.
002003:0000 Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '12378568704'
001003:0020 DEBUG: Code 1073741829 at N]DAZnR|jdbq4LVk:213130559
002003:0000 Error 'Posix error - Input/output error' occurred while reading '/dev/sr2' at offset '12378568704'
DEBUG: Code 1073741829 at <mz-%C})09hs`Vw;I^:29394896
001003:0020 DEBUG: Code 1073741829 at <mz-%C})09hs`Vw;I^:213131502
What ever is at that spot on the disc (offset 12378568704) the optical drive failed to read it. That the drive took a hardware timeout is probably why MakeMKV hangs. I wouldn't be surprised if the optical drive had to be power cycled to work properly again.
In any case, the standard advice is to gently clean the disc and try again.
brymer28
#12 Post by brymer28 » Thu Apr 04, 2024 2:36 pm
I have 5 optical drives. It's been cleaned and placed in every one. It's either a manufactured defect in disk or software bug.
#13 Post by dcoke22 » Thu Apr 04, 2024 2:44 pm
My copy of Jumanji (1995) ripped okay, so I don't think there's a software bug.
