Bought this drive (LG-BH16NS55 Cross Flashed to LG-WH16NS60 on firmware version 1-00DE) a couple of years ago...then haven't really been buying discs.
Decided to buy a couple this weekend (Wonka and Oppenheimer) and fire up the drive which hasn't been used for a while, but it won't read discs. Just spits the tray open. Have tried with CDs, DVDs and UHD discs.
I'm assuming the drive's borked, but does anyone have any pointers?
I was prompted to downloaded the latest version of MakeMKV (1.17.6) but am hoping the drive not working is coincidence.
LG-BH16NS55 flashed to LG-WH16NS60 (f/w 1-00DE) not reading discs
Re: LG-BH16NS55 flashed to LG-WH16NS60 (f/w 1-00DE) not reading discs
Found a CD/DVD cleaner...that hadn't changed matters. Have also tried it on a different machine and ditto.
Am assuming the drive is hosed. Time to look at buying a new one I suspect. A little disappointing as it's only been used for maybe a dozen discs.
CDs and DVDs use a different laser than blu-rays and UHDs. If the drive won't read either kind of disc, that seems like a bad sign.
Pioneer drives are held in high regard these days, but unfortunately to get one that is LibreDrive compatible, you need to get one from a seller in your region that can get one with old firmware.
Thanks.
Am going to give another LG a go - couldn't readily see any Pioneers.
Will see how long the new one lasts.
We currently get most of our new content through Disney+ or Prime, but with the way streaming services are going I can see us starting to buy discs again - really don't want to purchase through Prime or Google Play and become beholden to them.
i have pioneers ready to go see belowmurph7355 wrote: Mon Apr 01, 2024 8:42 pm Thanks.
I'd seen your link, but unfortunately am UK based.Billycar11 wrote: Tue Apr 02, 2024 1:18 ami have pioneers ready to go see belowmurph7355 wrote: Mon Apr 01, 2024 8:42 pm Thanks.
Ah so go with Asmcommurph7355 wrote: Tue Apr 02, 2024 7:20 amI'd seen your link, but unfortunately am UK based.Billycar11 wrote: Tue Apr 02, 2024 1:18 ami have pioneers ready to go see belowmurph7355 wrote: Mon Apr 01, 2024 8:42 pm Thanks.
viewtopic.php?f=20&t=19387
Out of action until 22/04 according to email.
May look for one the next time the LG breaks
