Somehow the insert picture featrue isnt working for me, i will post a link to imgur for the pictures in the original post.MartyMcNuts wrote: Thu Mar 07, 2024 11:36 pmThere's no pics. Try "insert image" and select the image saved on your hard drive.bababu wrote: Thu Mar 07, 2024 5:34 pm Hello Guys!
Today I got my Hitachi-LG BU40N Internal UHD Blu-Ray/DVD Drive/Burner. I knew that i had to flash it first, so i can get start to work!
But when i select my Drive and my Firmware to write and press the start button, nothing starts. It is like i haven't even pressed the start button. It happened when i tried to flash to DE_LG_BU40N_1.03_MK and also with DE_LG_BU40N_1.00_MK.
It looks like the first picture in the attachements.
My current version of the drive is in the 2nd attachment pic.
I already read that I have to crossflash to get to 1.00 but my problem is, I can't even flash to 1.03_MK because nothing is happening ....
Are you using the latest version of SDFtool flasher (v1.3.5)?
How is the drive connected to your PC?
Do you have MakeMKV installed in the default directory?
Did you ensure there is no disc in the drive and the tray is closed?
I am using the latest version.
I didnt change anything at the directory at installation.
I have no disc inserted and using the front ports of my pc for the drive.
