Debug log started at Tue Apr 12 19:23:11 2011 , written by MakeMKV v1.6.7 darwin(x86-release)
001005:0000 MakeMKV v1.6.7 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/htpc/MakeMKV_log.txt
002014:0000 Optical drive "DVD+R-DL PIONEER DVD-RW DVR-K06 Q617" opened in DASPI v1.2 mode.
002014:0000 Optical drive "BD-RE PIONEER BD-ROM BDC-202 1.07" opened in DASPI v1.2 mode.
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:INVALID COMMAND OPERATION CODE' occurred while issuing SCSI command 46020..00140 to device 'DASPI:IODASPIService:15beed6a0c55a4fa:'
001003:0020 DEBUG: Code 0 at 39c]U=R!S2$5#W}<:213137183
002014:0000 Optical drive "BD-ROM WD Virtual CD 070A 1032" opened in DASPI v1.2 mode.
Can anybody tell me what the SCSI errors mean?
TIA
It means that your cd-rom emulator "BD-ROM WD Virtual CD 070A 1032" in fact doesn't emulate a BD-ROM device properly. Are you running you Mac in a VM? What is this emulator?
If you need to open ISO files, MakeMKV can open them directly, from File menu.
Hi, no I'm running MakeMKV on a Mac Mini and the BD-ROM is connected via USB, just as it has always been.
I'm doing nothing differently than I used to do, the only change I have made is to update MakeMKV to the latest version and connect a WD external hard drive which has a WD Smart Drive thing on it. I wonder if it is that which is causing the error.
I'll try unplugging that and see if I get the same error.
Strangely it doesn't seem to stop me from backing up my blu-ray discs, but if MakeMKV is reporting an error I would like to understand it.
Yes that is entirely right the WD drive software upsets things. If you temporarily disconnect the drive NOT just eject then all works fine. Reconnect when done.
