See from your pervious post you have a HDFury Vertex
In the Vertex Utility - you can grab the AVI InfoFrame (as per page 34 here: https://www.hdfury.com/docs/HDfuryVertex.pdf)
(Which I am sure you know)
Could you please ping over the values in the captured AVI InfoFrame for when setting the flag to Y and for N i.e.:
echo Y > /sys/module/hdmitx20/parameters/dovi_tv_led_bt2020
echo N > /sys/module/hdmitx20/parameters/dovi_tv_led_bt2020
thanks.
thanks.
Yes, all the tests I did were with the hdfury vertex in the chain and the ugoos reports the same RGB 8bit DV signal as all my devices.
I don't know from a code perspective and maybe it doesn't matter for the newer TVs but in the tests I did years ago on my LG C8, a RGB signal without FLAG matched the colors of the TV's internal app while the signal with bt2020 introduced some slight color shift in RED and Yellow.
This is on CE-21 connected to the LG C2:
And this is CE-20.5 connected to the 2023 Hisense u8 TV. I suspect this TV(and some others) is just guessing REC709 on its OSD because there's no information on the actual signal it's receiving:
EDIT. last pics on is actually the atv, shield or x800m2, I don't remember...
this is on ugoos + Hisense:
There is one more difference between the signal from x800m2 and Ugoos, at least according to the Sony A95L OSD.
The signal from the x800m2 shows neither color space nor color depth - with the signal from Ugoos OSD shows 8bit.
yep, there's a difference in the signal...
see: https://discourse.coreelec.org/t/dolby- ... /24273/960
You could try:
ffmpeg -f concat -i "filelist.txt" -c copy -strict -2 test.mp4
file 1.mp4
file 2.mp4
Your command is redundant btw. To include all tracks and keep DV just use:Trees wrote: ↑Fri Mar 29, 2024 8:17 pmEdit: Bonus question; does MP4 only support one subtitle track? I've remuxed numerous files however ffmpeg only seems to be copying over one subtitle track; is the subtitle part of the command incorrect or does MP4 just not support more than one subtitle track?
ffmpeg -i dv.mkv -map 0 -c copy -c:s mov_text -strict -2 dv.mp4
Backward compatibility for Dolby RGB tunneling is really a mess.
Hi I have DV remux mkv, I want to test it on my lg c6 (old i know), what's the simplest way to do it? Thank you.RESET_9999 wrote:yep, there's a difference in the signal...
Sent from my SM-F946B using Tapatalk
AFIAK, 2016-2017 TVs only support profile 5 and 7 so for an mkv remux , you want to convert it to dual-track dual-layer MP4. You can do that with my script workflow 4-3.
I think the C6 internal player also have green screen issues with certain files, P3 MDL IIRC. It was discussed in this thread years ago.
Thanks buddy.RESET_9999 wrote:AFIAK, 2016-2017 TVs only support profile 5 and 7 so for an mkv remux , you want to convert it to dual-track dual-layer MP4. You can do that with my script workflow 4-3.
Btw what are the steps and installs I need to do to use your scripts? Thanks I'm on Windows.
If you just want to make DT-DL MP4, the installation is very easy... Create a folder without space or special characters and put it on a non-OS drive preferably.
Download the tools pack and MP4 bat file and put them in the folder you just created. Run the bat file, select 4-3, drag and drop input and that's it
Mrmorrison
Good evening everyone.
I'm going crazy trying to limit the brightness of the subtitles, as my x800m2 can't handle them well. (Any video app on my TV doesn't have this problem)
I'm trying to use the script but I'm getting this error.
What I did:
- Source file: mkv
- Mux in ts with tsmuxer which turns srt into pgs
- Demux the pgs file (either with tsmuxer or with subtilteEdit)
- DoviScript 8-7
Can someone help me?
What I did:
- Source file: mkv
- DoviScript 8-7
ThanksRESET_9999 wrote:If you just want to make DT-DL MP4, the installation is very easy... Create a folder without space or special characters and put it on a non-OS drive preferably.
try to put the sup file in a folder and input that folder...Mrmorrison wrote: ↑Mon Apr 01, 2024 5:55 pmGood evening everyone.
Mrmorrison
It worked! You are the best!RESET_9999 wrote: ↑Mon Apr 01, 2024 6:10 pm
Hi it took 3.3hrs for 69gb mkv remux, is that right?Donpoku wrote:ThanksRESET_9999 wrote:If you just want to make DT-DL MP4, the installation is very easy... Create a folder without space or special characters and put it on a non-OS drive preferably.
Download the tools pack and MP4 bat file and put them in the folder you just created. Run the bat file, select 4-3, drag and drop input and that's it![]()
Yeah, the speed depends on your HDD/SSD. Regular HDD can be very slow.
I use two NVME pci-e gen4 drives and it takes less than 15 minutes.
