With regards to the 'Volume Key is Unknown for this disk' error.. and manually sending the AACS dump file
to the specified email address.
When this error happens and as a new feature to the program,
would it not be better for the program to automatically open a small 'Backup Failed' Dialog Box
stating the same error with a 'Would you like to send the AACS dump file' with
Yes or No buttons.
When the User selects the 'Yes' button the AACS dump file is automatically sent off to the
svq@makemkv.com email address.
Just a thought.
Thanks,
Jason V
Small Feature Addition
Re: Small Feature Addition
yes but i believe the creator is very privacy focused and he does not like the idea of makemkv being able to create and send information automatically or from a misclick plus it would give companies another way to snoop on makemkv seeing how and where that stuff is being sent back toJPV119 wrote: Mon Apr 01, 2024 7:21 am Hi,
Yes or No buttons.
Just a thought.
Thanks,
Jason V
JPV119
Understandable.. though I used DVDFab from literally 2005 - 2015 until I moved over to makemkv...Billycar11 wrote: Mon Apr 01, 2024 7:45 am
DVDFab have a ridiculous number of programs in this same category and most of their procedures were automated..
They started in 2003 and are still going strong now, so going off that info I'm not sure how private you would have to be.
I recommend makemkv over DVDFab, it was only an example and I'm sure creator knows what they're doing.
Thanks.
Jason V
