The Force Awakens - SCSI/Medium/Uncorrectable Errors
Re: The Force Awakens - SCSI/Medium/Uncorrectable Errors
It is often the case that the same disc in a different drive produces different results. I have four different drives, so I can make that statement from first hand experience.
Lololark
Post by Lololark »
Lololark wrote: Sat Mar 30, 2024 9:32 pm Yes, but I'll try again.
I just think it's odd that both discs stop at same identical spot every time. At the 17601.1 M spot, both discs. From reading around, it sounds like the driver could be having difficulty moving to another layer, but that difficulty could be because of blemishes on the discs too.
Also, these discs were in storage for 4 years. I read that can contribute to these problems. But with that said, the other 4 Star Wars discs worked.
Ah, the adventures of learning something new!
Hello, does anyone have a recommended disc cleaning procedure? I've tried cleaning my bluray discs because they keep stopping at the same identical spot every time, but nothing has changed after multiple attempts. Thanks.
