3D Blu-Ray rip solution
Sunoo
Re: 3D Blu-Ray rip solution
Post by Sunoo » Tue Jan 30, 2024 4:34 pm
By default MakeMKV doesn’t rip the MVC track, so things rip as 2D. Did you change that?
ohseb
Post by ohseb » Tue Mar 05, 2024 9:06 am
Yes I do this with my 3D bluray collection to watch in VR and on my 3D TV - albeit not often enough.
Find the STEREO video option in MakeMKV, select this one and RIP it with one of the audio formats of your choice. For conversion later, its usually better to select the audio with less than 7 channels.
Then once RIP'd use an app called BD3D2MK3D which you can find on google. Be careful as some versions are packaged with malware. The official website has it and even that is recognised as having a dodgy code in it by some antivirus/malware detectors unnecessarily.
In this new app, open the MKV file and it will split the single video source to Side by Side video. This can then be watched in 3D with the side by side option selected on the projector/TV/VR headset software.
Sunoo
Post by Sunoo » Tue Mar 05, 2024 11:21 pm
My post was originally a reply to someone else, but the original looks like it got deleted.
Post by Billycar11 » Wed Mar 06, 2024 12:39 am
Sunoo wrote: Tue Mar 05, 2024 11:21 pm My post was originally a reply to someone else, but the original looks like it got deleted.
yeah happens when op account is compromised or just a spammer reposting then going back and editing to put scam junk in there
dmdmmatt4
Post by dmdmmatt4 » Fri Mar 29, 2024 3:19 pm
Sunoo wrote: Tue Jan 30, 2024 4:34 pm By default MakeMKV doesn’t rip the MVC track, so things rip as 2D. Did you change that?
I have to say I would like the option to change this default, too.
Post by d00zah » Fri Mar 29, 2024 3:29 pm
dmdmmatt4 wrote: Fri Mar 29, 2024 3:19 pm I have to say I would like the option to change this default, too.
Enable 'Expert mode' to expose the 'Advanced' tab (Preferences > General tab > check 'Expert mode'
Changing default track selection
-sel:all,+sel:(favlang|nolang),+sel:mvcvideo,=100:all,-10:favlang
or, maybe just remove '-sel:mvcvideo' from the default string? Experiment.
dmdmmatt4
Post by dmdmmatt4 » Mon Apr 01, 2024 4:50 pm
Good call, "use the cli options, Luke"..
Thanks, I'll experiment.
Post by d00zah » Mon Apr 01, 2024 6:23 pm
dmdmmatt4 wrote: Mon Apr 01, 2024 4:50 pm Good call, "use the cli options, Luke"..
But you're modifying the default behavior of the GUI on the 'Advanced' tab > 'Default selection rule' string. Isn't that what you asked for?
dmdmmatt4
Post by dmdmmatt4 » Wed Apr 03, 2024 6:23 pm
Yeah that's fine, I'm just saying that - in a manner of speaking - this is basically editing a conf file ("cli type stuff") that you just happen to do through the gui.
