Office Space Special Edition with Flair
poorpilot
Hey, I tried to use Makemkv on this movie but it uses BD+ and it just stalls and never makes a file larger then 4K. I sent in the SVQ file, is there anything else I should try? Thanks
setarip_old
Re: Office Space Special Edition with Flair
Considering that it's a 2009 release, the BD+ should not present a problem.
Clean the disc and examine it carefully for physical damage (scratches, cracks)...
crowfax
I just picked this disc up in Target, it ripped fine.
poorpilot
SO this is weird. I made a backup of the movie to my HD with Makemkv and it copied everything fine. However, when I try to make an mkv file it still stalls at 4.0K copied. The disc is brand new, should I just exchange it and try that?
Romansh
Please check the documentation and provide a debug log.
poorpilot
I got a new copy of the disc and it still doesn't work, it stops at 4.4K and the drive access light is flashing like it is reading but it does not work. I attached a copy of the log
MakeMKV v1.6.13 darwin(x86-release) started
Debug logging enabled, log will be saved as /Users/adamghz/MakeMKV_log.txt
Optical drive "DVD+R-DL OPTIARC DVD RW AD-5680H 3AHB" opened in OS access mode.
It's highly recommended to install DASPI kernel extension to improve performance.
Optical drive "BD-RE HL-DT-ST BD-RE BE12LU38 1.00" opened in OS access mode.
Evaluation version, 25 day(s) out of 30 remaining
Loaded 21 SVQ file(s)
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using generic SVQ from builtin/00002.svq
Saved BD+ dump file as /Users/adamghz/Desktop/Makemkv/dump_Office_Space_DBA4C48A56310550.tgz
BD+ code processed, got 1 FUT(s) for 1 clip(s)
Title #00012.mpls has length of 1622 seconds which is less than minimum title length of 2000 seconds and was therefore skipped
Title #00036.mpls has length of 30 seconds which is less than minimum title length of 2000 seconds and was therefore skipped
File 00040.mpls was added as title #0
Title #00002.mpls has length of 110 seconds which is less than minimum title length of 2000 seconds and was therefore skipped
Title 00001.mpls is equal to title 00040.mpls and was skipped
Title #00037.mpls has length of 50 seconds which is less than minimum title length of 2000 seconds and was therefore skipped
Title #00041.mpls has length of 55 seconds which is less than minimum title length of 2000 seconds and was therefore skipped
Title #00003.mpls has length of 340 seconds which is less than minimum title length of 2000 seconds and was therefore skipped
Title #00003.m2ts has length of 340 seconds which is less than minimum title length of 2000 seconds and was therefore skipped
Title #00004.m2ts has length of 1 seconds which is less than minimum title length of 2000 seconds and was therefore skipped
Title #00007.m2ts has length of 8 seconds which is less than minimum title length of 2000 seconds and was therefore skipped
Title #00013.m2ts has length of 7 seconds which is less than minimum title length of 2000 seconds and was therefore skipped
Title #00009.m2ts has length of 1 seconds which is less than minimum title length of 2000 seconds and was therefore skipped
Title #00010.m2ts has length of 7 seconds which is less than minimum title length of 2000 seconds and was therefore skipped
Title #00017.m2ts has length of 30 seconds which is less than minimum title length of 2000 seconds and was therefore skipped
Title #00014.m2ts has length of 7 seconds which is less than minimum title length of 2000 seconds and was therefore skipped
Title #00018.m2ts has length of 27 seconds which is less than minimum title length of 2000 seconds and was therefore skipped
Title #00002.m2ts has length of 55 seconds which is less than minimum title length of 2000 seconds and was therefore skipped
Title #00005.m2ts has length of 1622 seconds which is less than minimum title length of 2000 seconds and was therefore skipped
Title #00006.m2ts has length of 146 seconds which is less than minimum title length of 2000 seconds and was therefore skipped
Title #00012.m2ts has length of 7 seconds which is less than minimum title length of 2000 seconds and was therefore skipped
Title #00011.m2ts has length of 7 seconds which is less than minimum title length of 2000 seconds and was therefore skipped
Title #00008.m2ts has length of 7 seconds which is less than minimum title length of 2000 seconds and was therefore skipped
Title #00016.m2ts has length of 20 seconds which is less than minimum title length of 2000 seconds and was therefore skipped
Title #00015.m2ts has length of 15 seconds which is less than minimum title length of 2000 seconds and was therefore skipped
Saving 1 titles into directory /Users/adamghz/Desktop/office
Error 'Internal error - Operation was cancelled (104)' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '1055182848'
DEBUG: Code 0 at 2Cu)#%UP8\Iv|\8adY]-:29394298
DEBUG: Code 0 at On;o(!?%cV&\g:8,6";K:121261681
DEBUG: Code 0 at 2Cu)#%UP8\Iv|\8adY]-:29394183
DEBUG: Code 515226 at 2Cu)#%UP8\Iv|\8adY]-:29393309
DEBUG: Code 0 at p;xjK1>kP7~YNWbN8.9:29394183
DEBUG: Code 0 at p;xjK1>kP7~YNWbN8.9:29396506
Failed to save title 0 to file /Users/adamghz/Desktop/office/title00.mkv
0 titles saved, 1 failed
crowfax
Let me dig out my copy and do it again. I'll post back in an hour or so.
crowfax
Weird, it's doing the same thing for me. Here's a screenshot:
Here's the debug log (I canceled after 10 mins):
And the dump file is attached.
Debug log started at Fri Aug 12 21:40:55 2011 , written by MakeMKV v1.6.13 linux(x64-release)
001005:0000 MakeMKV v1.6.13 linux(x64-release) started
001004:0000 Debug logging enabled, log will be saved as /home/matthew/MakeMKV_log.txt
DAFD=PAAAADAAAAEABDQUEAAACAQ==
DCE=6voS4/MMuZiCpiv72L/OhmkfNanP8iBSorZBiqmx2u2dCzjxAQ3x7KqUegf8aaIKpRRIFgojEivX9lJV/AbqdIXas7kBfTyKp0LcSZhAz5Qg49W1a0oHc2n4NzUH5aPFqGym3nvxwlDHrqJWrIFWOyM0UZL5CUlAAA==
003338:0000 Downloading latest SVQ(s) to /home/matthew/.MakeMKV ...
003317:0000 Loaded 21 SVQ file(s)
003326:0000 Processing BD+ code, please be patient - this may take up to few minutes
003324:0000 Processing BD+ code using generic SVQ from builtin/00002.svq
003332:0000 Saved BD+ dump file as /home/matthew/.MakeMKV/dump_Office_Space_DBA4C48A56310550.tgz
003328:0000 BD+ code processed, got 1 FUT(s) for 1 clip(s)
DISCID=DBA4C48A56310550CD3D56D4444B3D975A2A34CE
003307:0000 File 00012.mpls was added as title #0
003025:0000 Title #00036.mpls has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00040.mpls was added as title #1
003025:0000 Title #00002.mpls has length of 110 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003309:0000 Title 00001.mpls is equal to title 00040.mpls and was skipped
003025:0000 Title #00037.mpls has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00041.mpls has length of 55 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00003.mpls was added as title #2
003025:0000 Title #00004.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00007.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00013.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00009.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00010.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00017.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00014.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00018.m2ts has length of 27 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00002.m2ts has length of 55 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00006.m2ts was added as title #3
003025:0000 Title #00012.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00011.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00008.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00016.m2ts has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00015.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005014:0000 Saving 1 titles into directory /opt/MKV/Office_Space
002003:0000 Error 'Internal error - Operation was cancelled (104)' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '2662612992'
001003:0020 DEBUG: Code 0 at MJ"M8B8rr$IBiV|J>_b$:29394298
001003:0020 DEBUG: Code 0 at FZN;SlMwWS*qoH8w2^2]:121261681
001003:0020 DEBUG: Code 0 at MJ"M8B8rr$IBiV|J>_b$:29394183
001003:0020 DEBUG: Code 1300104 at MJ"M8B8rr$IBiV|J>_b$:29393309
001003:0020 DEBUG: Code 0 at =o8*gV}oi4WK<^M2N!t:29394183
001003:0020 DEBUG: Code 0 at =o8*gV}oi4WK<^M2N!t:29396506
005003:0000 Failed to save title 1 to file /opt/MKV/Office_Space/title01.mkv
005004:0080 0 titles saved, 1 failed
Application exited at Fri Aug 12 21:53:13 2011Home Theater PC: Assassin HTPC, XBMCbuntu 12.0 (Frodo), Intel i5 3570k 3.4 GHz Ivy Bridge w/ HD 4000, LG BD-ROM
poorpilot
That is the exact same as what is happening to me
crowfax
So weird, I thought I'd already ripped it but I can't find the file on my TV.
Anyway, I'm sure Mike will know what to do.
dbknightx
I am experiencing the exact same problem.
This disc ripped successfully with an older version of MakeMKV so it is an issue with the latest release.
-David
-David
- Contact:
What happens if you make a full decrypted disc backup with MakeMKV, and then try making MKV file from a backup on HDD?
crowfax
The disc rips fine to the HDD, then when you open the backup and tell it to create an MKV file, it does the same thing again. Just ties up the HDD as the read rate steadily increases then maxes out.mike admin wrote:What happens if you make a full decrypted disc backup with MakeMKV, and then try making MKV file from a backup on HDD?
discoteca
On a related note I have just ran in to problems with ripping Die Hard(s) which also uses BD+, they all ripped fine with an older version either 1.6.10 or 1.6.12 (I can't remember which) Now with 1.6.13 I can't rip any with BD+, it just gets stuck at the already mentioned 4K file size.
crowfax
Someone else has reported a problem with Avatar that sounds related to this one:
http://www.makemkv.com/forum2/viewtopic.php?f=8&t=3951
