Hey i'm very new to this stuff i'm looking for a 4k region free blu-ray drive that i can get could you help?
Would it also be possible to hook up a Panasonic DMP-BDT280EB to my pc to play it on my computer if there are no drive out there?
Looking for a 4k region free blu-ray drive
Re: Looking for a 4k region free blu-ray drive
Not the assembly - and it would depend on what the actual drive inside the assembly is as to whether it would be useful in your computer.
4K UHDs are not region coded. https://en.wikipedia.org/wiki/Ultra_HD_Blu-ray
If you get an optical drive for your computer that is LibreDrive capable, it will ignore region coding on DVDs and regular blu-rays.On May 12, 2015, the Blu-ray Disc Association revealed completed specifications and the official Ultra HD Blu-ray logo. Unlike conventional DVDs and Blu-rays, the new 4K format does not have region coding.
I'm dislexic and i can't do thosse kinds of technical things and i thank you for your replies.
So 4k isn't coded that's good.
Would you know of a 4k drive that is blu-ray region free?
Any of the drives in the guide with old fw
Or any of the drives I sell with old fw.
