LibreDrive for Pioneer drives
Post by Coopervid » Mon Mar 18, 2024 4:11 pm
I see now the problem. Please check your PM.
chikinov
Post by chikinov » Mon Mar 18, 2024 4:26 pm
Coopervid wrote: Mon Mar 18, 2024 4:11 pm I see now the problem. Please check your PM.
Thanks for the help. But I am not authorised to reply you through PM because I am too new here. Please send me the flasher. Thank you so much.
Post by Coopervid » Tue Mar 19, 2024 10:16 am
Check new PM
MKUltra2020
Post by MKUltra2020 » Sun Mar 24, 2024 4:54 pm
Hi, I've just created an account to seek some help, though I've been using MakeMKV for a few years now. Hopefully someone will be able to assist me.
Until just recently, I had been using an LG external blu-ray drive for ripping my BDs and DVDs. It still seems to work fine, but I decided to purchase a new Pioneer external BD Drive. I've noticed that LibreDrive does not automatically enable itself for the Pioneer drive like it does the LG. (EDIT: Upon further inspection, it seems that LibreDrive doesn't actually auto-enable, but it does say that it's available for the LG drive)
I'm hesitant to flash and potentially brick a brand new drive, so I'm hoping there is a simple solution that I'm clearly overlooking.
Here is the drive information MakeMKV gives me for the Pioneer drive:
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-XD08
Revision: 1.00
Serial number: REDACTED
Firmware date: 2022-04-03
Highest AACS version: 81
Drive platform: Pioneer RS9330
Firmware version: GENE
Thank you in advance. I don't know if I'm able to receive PMs yet since I literally only just joined, but I hope someone here can point me in the right direction.
Conversely, since the LG is the older of the two drives I have less attachment to it so I would consider flashing that one for LibreDrive, if someone could help with that.
randman76
Post by randman76 » Sun Mar 24, 2024 6:31 pm
Hello there,
I am a newbie to this forum. There is a lot of good info here, thanks for providing. I recently purchased the BDR-S13U-X as well and was hoping I could obtain the latest flasher? I was going send a PM to Mike but I get an error since I just signed up.
Thanks in advance,
Randman76
Post by Billycar11 » Sun Mar 24, 2024 11:07 pm
randman76 wrote: Sun Mar 24, 2024 6:31 pm Hello there,
Thanks in advance,
Randman76
The ux can't be flashed I recommend you return it and get a ux from a seller with old firmware
joserz
Post by joserz » Tue Mar 26, 2024 2:26 am
I do not see the model number on the list it is a MODEL BD-RW BDR-213M Pioneer RS9200
Current profile: DVD-ROM
Product: BD-RW BDR-213M
Revision: 1.04
Serial number:
Firmware date: 2022-12-12
Highest AACS version: 68
Drive platform: Pioneer RS9200
Firmware version: ID56
Post by Billycar11 » Tue Mar 26, 2024 4:23 am
joserz wrote: Tue Mar 26, 2024 2:26 am I do not see the model number on the list it is a MODEL BD-RW BDR-213M Pioneer RS9200
Revision: 1.04
Serial number:
sorry man to new return it cant be flashed but i have those crossflashed to s13 ubk old fw if you want one
Lololark
Post by Lololark » Wed Mar 27, 2024 7:18 am
Hello, total noob here. This is what I've got.
The first bluray I ripped mostly worked fine. The 2nd one I tried failed, and now the discs won't load.
Any advice? Thank you.
Manu: Pioneer
Prod: bd-rw bdr-td04d
Rev: 1.00
S#: lfdl069049wl
Fw date: 2012-02-27
Bef: 1b
H aacs v: 2.0
Status: possible but very unlikely to happen
Drive platform: Pioneer rs1040
Firmware version: id84
Post by MartyMcNuts » Wed Mar 27, 2024 9:44 am
Lololark wrote: Wed Mar 27, 2024 7:18 am Hello, total noob here. This is what I've got.
Manu: Pioneer
Rev: 1.00
S#: lfdl069049wl
Fw date: 2012-02-27
Bef: 1b
H aacs v: 2.0
Power off the drive for a few minutes before turning it back on and trying again.
Evil Teddy
Post by Evil Teddy » Wed Mar 27, 2024 7:01 pm
I have this one:
Laufwerksinformation
OS-Gerätename: G:
Produzent: PIONEER
Produkt: BD-RW BDR-XS07U
Revision: 1.03
Serienummer: CIDL008016WL
Firmware-Datum: 2023-01-06
Markierungen der Bus-Verschlüsselung: 13
Firmware version: ID05
The error is:
ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED
and
Post by Billycar11 » Wed Mar 27, 2024 10:49 pm
Evil Teddy wrote: Wed Mar 27, 2024 7:01 pm I have this one:
OS-Gerätename: G:
Produzent: PIONEER
Revision: 1.03
The error is:
and
Sorry man that drive is to new.
If you can I recommend you return it if you want UHD and a pioneer best to get from a seller in your region
Lololark
Post by Lololark » Thu Mar 28, 2024 5:59 am
MartyMcNuts wrote: Wed Mar 27, 2024 9:44 am
Manu: Pioneer
Rev: 1.00
S#: lfdl069049wl
Fw date: 2012-02-27
Bef: 1b
H aacs v: 2.0
Thanks a lot man, that did the trick.
That's what I'd been doing, but it didn't work until now. I also changed the settings to more "read retry" attempts, I don't know if that helped make a difference, but I'm back on track.
Evil Teddy
Post by Evil Teddy » Thu Mar 28, 2024 6:53 am
Billycar11 wrote: Wed Mar 27, 2024 10:49 pm Sorry man that drive is to new.
Asmcom seller in this forum said that this drive is compatible with makemkv. Link: viewtopic.php?p=73484#p73484
Post by MartyMcNuts » Thu Mar 28, 2024 7:03 am
Evil Teddy wrote: Thu Mar 28, 2024 6:53 am
The drive is compatible only when it has older firmware (prior to Dec 2022).
