Drive spins up but then says no disk.
Proflawdog
Post by Proflawdog »
I have two drives thats recently stop reading disk. I'm have a problem with one of my dockers on Unraid. The MKV docker by Djoss stopped recognizing Blu-ray & UHD disk across two different drivers & the ubs one won't recognizing disc when plugged in to my laptop. Any insight on the issue would be greatly appreciated. Thank you.
DavoBR
Re: Drive spins up but then says no disk.
Post by DavoBR »
Proflawdog wrote:
Tue Mar 26, 2024 12:36 am
Daft suggestion to start... if the drives were working, have you tried cleaning the disk(s)?
turn them off for 5 mins and see if they come back after that
Proflawdog
I verified that the disk were clean but the drive still won't load blu-ray or UHD disk. I can hear the drive hunting/seaking. Is there any way to verify laser is working? I do have some slim drive I could try.
Proflawdog wrote:
Wed Mar 27, 2024 5:58 am
but did you cut power to them for 5 mins?
yeah you can do this https://www.youtube.com/watch?v=jhFotkrBTCU
Proflawdog
Yes, I cut power for 5 minutes. I also verified the lasers are working. I also saw the manufacturer date was 2018. I don't know, it looks like the drive might be dead. How long do drive normally last with moderate use?
Proflawdog wrote:
Wed Mar 27, 2024 9:43 am
If they are LG or ASUS, if you get 12 months out of them these days, you have done well.
DavoBR
Post by DavoBR »
MartyMcNuts wrote:
Wed Mar 27, 2024 9:45 am
Wow, really! How long for Pioneer?
DavoBR wrote:
Wed Mar 27, 2024 12:09 pm
put it this way i have gotten in pioneers in from 2009 for repair and flashing from 2009 and all they needed was a laser cleaning and a flash and they can do UHD...
DavoBR
Post by DavoBR »
Thanks Billy
