Starting with just the .m2ts file, I can't find a way to get it into an MKV.MakeMKV v1.4.6 beta win(x86-release) started
Opening files on harddrive at M:/video/
AACS directory not present, assuming unencrypted disc
File 00000.mpls was added as title #0
Operation sucessfully completed
Saving 1 titles into directory C:/Video/UNNAMED_DISC
Failed to save title 0 to file C:/Video/UNNAMED_DISC/title00.mkv
0 titles saved, 1 failed
Use .m2ts but no index.bdmv?
I'm wondering if there is any way to use a .m2ts file by itself without the rest of the disc structure. I tried using tsMuxeR GUI to create a Blu-ray disk, but when I try to use it with MakeMKV, it says
Re: Use .m2ts but no index.bdmv?
Looks like to tried to just striaght copy the m2ts file with out decoding the bluray 1st. You need to decode the bluray first
I don't have the Blu-ray, just the .m2ts file. Is there anything I can do with that?
So is it normal for MakeMKV to fail with an ISO created by tsMuxeR?
1. tsMuxeR does not create ISO files only the sturcture of a bluray.
2. tsMuxeR does not decrypt the Bluray. So you can NOT directly use tsMuxeR on Bluray without something in between them decrypting the bluray, for example "AnyDVD HD". Because if you try too you will end up with a very large USELESS file with nothing but garbage in, as it has nothing but scrambled video,audio and etc stuff in it. And no you can not fix it with out "re-ripping" the m2ts file the right way.
3. Why are you trying to use MakeMKV on this file, I'm assuming it is be of #2. meaning you have the large m2ts and it will not play in or on anything ?
I have the .m2ts file, decrypted, and it will play fine, but I want to mux some other subtitles with it. I use it as input with tsMuxeR to create the Blu-ray structure, and it will play fine from there too. But MakeMKV fails to read it.
- Contact:
MakeMKV needs at least M2TS and corresponding CLPI file. All other files are optional - index.bdmv must be present but its contents does not matter.
I've been doing some testing with other ISOs, and it always fails. It seems to show >100MB for the Output size, but then fails. There isn't any file in the output directory.
Just to clarify, yes the ISO and other files to have the 0001.clpi, index.bdmv, and 00001.m2ts but MakeMKV still fails. I can always plan the .m2ts directly, and there is no encryption, but I haven't been able to get MakeMKV to work on a single .m2ts file yet.
This is still my problem, and there doesn't seem to be any changes with MakeMKV for almost a year.
I have a directory structure for an unencrypted Blu-Ray, and I can play it fine, but I would like to mux it into MKV to add subtitles. Unfortunately it always fails with the above mentioned error.
This is the directory structure I have:
Directory of C:\bluray
11/21/2009 08:04 AM <DIR> .
11/21/2009 08:04 AM <DIR> ..
11/21/2009 08:04 AM <DIR> BDMV
11/21/2009 08:04 AM <DIR> CERTIFICATE
0 File(s) 0 bytes
Directory of C:\bluray\BDMV
11/21/2009 08:04 AM <DIR> AUXDATA
11/21/2009 08:04 AM <DIR> BACKUP
11/21/2009 08:04 AM <DIR> BDJO
11/21/2009 08:10 AM <DIR> CLIPINF
11/21/2009 08:04 AM 528 index.bdmv
11/21/2009 08:04 AM <DIR> JAR
11/21/2009 08:04 AM <DIR> META
11/21/2009 08:04 AM 290 MovieObject.bdmv
11/21/2009 08:10 AM <DIR> PLAYLIST
11/21/2009 08:04 AM <DIR> STREAM
2 File(s) 818 bytes
Directory of C:\bluray\BDMV\AUXDATA
0 File(s) 0 bytes
Directory of C:\bluray\BDMV\BACKUP
2 File(s) 818 bytes
Directory of C:\bluray\BDMV\BACKUP\BDJO
0 File(s) 0 bytes
Directory of C:\bluray\BDMV\BACKUP\CLIPINF
11/21/2009 08:10 AM <DIR> .
11/21/2009 08:10 AM <DIR> ..
11/21/2009 08:10 AM 46,668 00000.clpi
1 File(s) 46,668 bytes
Directory of C:\bluray\BDMV\BACKUP\PLAYLIST
11/21/2009 08:10 AM 412 00000.mpls
1 File(s) 412 bytes
Directory of C:\bluray\BDMV\BDJO
0 File(s) 0 bytes
Directory of C:\bluray\BDMV\CLIPINF
Directory of C:\bluray\BDMV\JAR
0 File(s) 0 bytes
Directory of C:\bluray\BDMV\META
0 File(s) 0 bytes
Directory of C:\bluray\BDMV\PLAYLIST
1 File(s) 412 bytes
Directory of C:\bluray\BDMV\STREAM
11/21/2009 08:10 AM 8,358,469,632 00000.m2ts
1 File(s) 8,358,469,632 bytes
Directory of C:\bluray\CERTIFICATE
0 File(s) 0 bytes
Directory of C:\bluray\CERTIFICATE\BACKUP
0 File(s) 0 bytes
- Contact:
Please enable "log debug messages" in preferneces and post the log here - this will help pinpoint the error.Atamido wrote:This is still my problem, and there doesn't seem to be any changes with MakeMKV for almost a year.![]()
