Drive spins up but then says no disk.
Proflawdog
I have two drives thats recently stop reading disk. I'm have a problem with one of my dockers on Unraid. The MKV docker by Djoss stopped recognizing Blu-ray & UHD disk across two different drivers & the ubs one won't recognizing disc when plugged in to my laptop. Any insight on the issue would be greatly appreciated. Thank you.
Re: Drive spins up but then says no disk.
Daft suggestion to start... if the drives were working, have you tried cleaning the disk(s)?Proflawdog wrote: ↑Tue Mar 26, 2024 12:36 amI have two drives thats recently stop reading disk. I'm have a problem with one of my dockers on Unraid. The MKV docker by Djoss stopped recognizing Blu-ray & UHD disk across two different drivers & the ubs one won't recognizing disc when plugged in to my laptop. Any insight on the issue would be greatly appreciated. Thank you.
turn them off for 5 mins and see if they come back after that
Proflawdog
I verified that the disk were clean but the drive still won't load blu-ray or UHD disk. I can hear the drive hunting/seaking. Is there any way to verify laser is working? I do have some slim drive I could try.
but did you cut power to them for 5 mins?Proflawdog wrote: ↑Wed Mar 27, 2024 5:58 amI verified that the disk were clean but the drive still won't load blu-ray or UHD disk. I can hear the drive hunting/seaking. Is there any way to verify laser is working? I do have some slim drive I could try.
yeah you can do this https://www.youtube.com/watch?v=jhFotkrBTCU
Proflawdog
Yes, I cut power for 5 minutes. I also verified the lasers are working. I also saw the manufacturer date was 2018. I don't know, it looks like the drive might be dead. How long do drive normally last with moderate use?
If they are LG or ASUS, if you get 12 months out of them these days, you have done well.Proflawdog wrote: ↑Wed Mar 27, 2024 9:43 amYes, I cut power for 5 minutes. I also verified the lasers are working. I also saw the manufacturer date was 2018. I don't know, it looks like the drive might be dead. How long do drive normally last with moderate use?
Wow, really! How long for Pioneer?MartyMcNuts wrote: ↑Wed Mar 27, 2024 9:45 am
put it this way i have gotten in pioneers in from 2009 for repair and flashing from 2009 and all they needed was a laser cleaning and a flash and they can do UHD...
Thanks Billy
