Drive spins up but then says no disk.
Proflawdog
Post by Proflawdog »
I have two drives thats recently stop reading disk. I'm have a problem with one of my dockers on Unraid. The MKV docker by Djoss stopped recognizing Blu-ray & UHD disk across two different drivers & the ubs one won't recognizing disc when plugged in to my laptop. Any insight on the issue would be greatly appreciated. Thank you.
DavoBR
Re: Drive spins up but then says no disk.
Post by DavoBR »
Proflawdog wrote: Tue Mar 26, 2024 12:36 am I have two drives thats recently stop reading disk. I'm have a problem with one of my dockers on Unraid. The MKV docker by Djoss stopped recognizing Blu-ray & UHD disk across two different drivers & the ubs one won't recognizing disc when plugged in to my laptop. Any insight on the issue would be greatly appreciated. Thank you.
Daft suggestion to start... if the drives were working, have you tried cleaning the disk(s)?
turn them off for 5 mins and see if they come back after that
Proflawdog
I verified that the disk were clean but the drive still won't load blu-ray or UHD disk. I can hear the drive hunting/seaking. Is there any way to verify laser is working? I do have some slim drive I could try.
Proflawdog wrote: Wed Mar 27, 2024 5:58 am I verified that the disk were clean but the drive still won't load blu-ray or UHD disk. I can hear the drive hunting/seaking. Is there any way to verify laser is working? I do have some slim drive I could try.
but did you cut power to them for 5 mins?
yeah you can do this https://www.youtube.com/watch?v=jhFotkrBTCU
Proflawdog
Yes, I cut power for 5 minutes. I also verified the lasers are working. I also saw the manufacturer date was 2018. I don't know, it looks like the drive might be dead. How long do drive normally last with moderate use?
Proflawdog wrote: Wed Mar 27, 2024 9:43 am Yes, I cut power for 5 minutes. I also verified the lasers are working. I also saw the manufacturer date was 2018. I don't know, it looks like the drive might be dead. How long do drive normally last with moderate use?
If they are LG or ASUS, if you get 12 months out of them these days, you have done well.
DavoBR
Post by DavoBR »
MartyMcNuts wrote: Wed Mar 27, 2024 9:45 am
Wow, really! How long for Pioneer?
DavoBR wrote: Wed Mar 27, 2024 12:09 pm Wow, really! How long for Pioneer?
put it this way i have gotten in pioneers in from 2009 for repair and flashing from 2009 and all they needed was a laser cleaning and a flash and they can do UHD...
DavoBR
Post by DavoBR »
Thanks Billy
