BRUHD-PU3-BK drive flash LibreDrive confirmation
ellenia
Post by ellenia »
I've bought BRUHD-PU3-BK and I flashed it with LibreDrive. I want to confirm if I succeeded but I do not have any UHD-BD currently.
The original firmware seemed to be BU14, and I used the SDFTools with All You Need Firmware Pack (MartyMcNuts) to flash
1. first flashed it with DE_Buffalo_BRUHD-PU3_BU12-MK.bin, succeed.
2. then flashed it with DE_Buffalo_BRUHD-PU3_BU10.bin, succeed.
Now The information in MakeMKV shows:
OS device name: F:
Manufacturer: BUFFALO
Product: Optical Drive
Revision: BU10
Serial number: XXXXXXXXXX
Firmware date: 2117-05-30 17:28
Bus encryption flags: 1F
Firmware version: 0.BU10O
Does this mean that I succeeded?
Re: BRUHD-PU3-BK drive flash LibreDrive confirmation
Should be fine
