The Abyss 4K
Re: The Abyss 4K
I'm lucky to rip all 3 discs (The Abyss/Aliens/True Lies) from my Target purchase successfully without any issues. I used the Pioneer BDR-S13UBK that I purchased from Billy Carlson (viewtopic.php?f=20&t=17831) and this drive has been working flawlessly for me.
						Re: The Abyss 4K
Billy is the man.  He sells very high quality drives so I'm not surprised at all on that one.
						Re: The Abyss 4K
@Chris01992 Thank you for confirming!
Hi @Mozey, sure - I have the BDR-S13EBK with BDR-S13JX firmware 1-03 (purchased in a Vantek enclosure recently from @asmcom on this forum)
				Gillietalls
Re: The Abyss 4K
Do these drives have to be installed inside a computer, or can they work as external drives via USB?
						Re: The Abyss 4K
Got my copy from Amazon today. Tried it on my LG WH16NS60 and it just stopped halfway through ripping. No errors or anything. The disc itself stopped spinning in the drive. Also the drive seemed to be locked up for the whole computer and thought it still had the disc in it after I ejected and removed it. Had to power cycle it to get it back to responding. Tried it on my Pioneer BDR-XD08U afterwards and everything just worked (albeit slower ripping), so put me down as another user having issues on LG/Asus drives but none on Pioneer.
The disc itself had very minor circular scratches on it near the center but the behavior of the drive (stopping halfway through, no errors, not responding to anything afterwards) makes me think this is some deeper issue with the discs/drive firmware than the scratches causing the issues.
Re: The Abyss 4K
All of mine are in external vantec cases over USB 3.  They work great.
						Re: The Abyss 4K
I have a WH16NS60 in a Mercury external case and was able to backup The Abyss no problems. My copy came from Disney Movie Club. It was apparently a later shipment as they only got the discs the day before the release date. Perhaps a different batch?
				mainecooncat1
Re: The Abyss 4K
Hi jmos1277. I still can't reply to your PM as I have a new account on the MakeMKV forums.mainecooncat1 wrote: ↑Wed Mar 20, 2024 12:58 pmMessage for jmos1277
As I just signed up for a MakeMKV forum account, I can receive your PM, but I cannot reply. My full backup of the 4k The Abyss UHD didn't run to completion (failed about 50-55% through). I received Witness on 4K UHD yesterday and it ripped without a single problem, so I'm still thinking the 4k Abyss disc has a manufacturing/packaging problem.
I'll try the disc backup again in the next few days to see if I can get it to run to completion. If not, returning it to Amazon for a refund seems to be the only option as they are not offering exchanges, that I've seen.
I cleaned the 4k Abyss disc and tried to run a disc backup again. It ran to conclusion but failed with 46 files failing hash check. Using a WH16NS60 drive that has always been a bit picky about reading UHD discs.
Using LibreDrive mode (v06.3 id=7FA2657C7667)
Backing up disc into folder "E:/THE_ABYSS"
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00700.m2ts' at offset '278458368'
Failed to save title /BDMV/STREAM/00700.m2ts to file E:/THE_ABYSS/BDMV/STREAM/00700.m2ts
DEBUG: Code 0 at 5G?+18,nyu$d?]5Bu:121267063
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00689.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00689.m2ts to file E:/THE_ABYSS/BDMV/STREAM/00689.m2ts
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00723.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00723.m2ts to file E:/THE_ABYSS/BDMV/STREAM/00723.m2ts
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00720.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00720.m2ts to file E:/THE_ABYSS/BDMV/STREAM/00720.m2ts
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00702.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00702.m2ts to file E:/THE_ABYSS/BDMV/STREAM/00702.m2ts
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00683.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00683.m2ts to file E:/THE_ABYSS/BDMV/STREAM/00683.m2ts
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00717.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00717.m2ts to file E:/THE_ABYSS/BDMV/STREAM/00717.m2ts
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00719.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00719.m2ts to file E:/THE_ABYSS/BDMV/STREAM/00719.m2ts
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00725.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00725.m2ts to file E:/THE_ABYSS/BDMV/STREAM/00725.m2ts
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00704.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00704.m2ts to file E:/THE_ABYSS/BDMV/STREAM/00704.m2ts
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00690.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00690.m2ts to file E:/THE_ABYSS/BDMV/STREAM/00690.m2ts
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00686.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00686.m2ts to file E:/THE_ABYSS/BDMV/STREAM/00686.m2ts
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00718.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00718.m2ts to file E:/THE_ABYSS/BDMV/STREAM/00718.m2ts
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00721.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00721.m2ts to file E:/THE_ABYSS/BDMV/STREAM/00721.m2ts
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00703.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00703.m2ts to file E:/THE_ABYSS/BDMV/STREAM/00703.m2ts
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00678.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00678.m2ts to file E:/THE_ABYSS/BDMV/STREAM/00678.m2ts
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00701.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00701.m2ts to file E:/THE_ABYSS/BDMV/STREAM/00701.m2ts
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00714.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00714.m2ts to file E:/THE_ABYSS/BDMV/STREAM/00714.m2ts
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00709.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00709.m2ts to file E:/THE_ABYSS/BDMV/STREAM/00709.m2ts
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00696.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00696.m2ts to file E:/THE_ABYSS/BDMV/STREAM/00696.m2ts
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00711.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00711.m2ts to file E:/THE_ABYSS/BDMV/STREAM/00711.m2ts
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00705.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00705.m2ts to file E:/THE_ABYSS/BDMV/STREAM/00705.m2ts
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00691.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00691.m2ts to file E:/THE_ABYSS/BDMV/STREAM/00691.m2ts
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00692.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00692.m2ts to file E:/THE_ABYSS/BDMV/STREAM/00692.m2ts
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00715.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00715.m2ts to file E:/THE_ABYSS/BDMV/STREAM/00715.m2ts
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00712.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00712.m2ts to file E:/THE_ABYSS/BDMV/STREAM/00712.m2ts
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00710.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00710.m2ts to file E:/THE_ABYSS/BDMV/STREAM/00710.m2ts
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00706.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00706.m2ts to file E:/THE_ABYSS/BDMV/STREAM/00706.m2ts
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00684.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00684.m2ts to file E:/THE_ABYSS/BDMV/STREAM/00684.m2ts
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00687.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00687.m2ts to file E:/THE_ABYSS/BDMV/STREAM/00687.m2ts
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00688.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00688.m2ts to file E:/THE_ABYSS/BDMV/STREAM/00688.m2ts
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00697.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00697.m2ts to file E:/THE_ABYSS/BDMV/STREAM/00697.m2ts
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00679.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00679.m2ts to file E:/THE_ABYSS/BDMV/STREAM/00679.m2ts
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00713.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00713.m2ts to file E:/THE_ABYSS/BDMV/STREAM/00713.m2ts
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00685.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00685.m2ts to file E:/THE_ABYSS/BDMV/STREAM/00685.m2ts
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00693.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00693.m2ts to file E:/THE_ABYSS/BDMV/STREAM/00693.m2ts
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00677.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00677.m2ts to file E:/THE_ABYSS/BDMV/STREAM/00677.m2ts
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00724.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00724.m2ts to file E:/THE_ABYSS/BDMV/STREAM/00724.m2ts
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00707.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00707.m2ts to file E:/THE_ABYSS/BDMV/STREAM/00707.m2ts
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00695.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00695.m2ts to file E:/THE_ABYSS/BDMV/STREAM/00695.m2ts
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00698.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00698.m2ts to file E:/THE_ABYSS/BDMV/STREAM/00698.m2ts
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00694.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00694.m2ts to file E:/THE_ABYSS/BDMV/STREAM/00694.m2ts
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00726.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00726.m2ts to file E:/THE_ABYSS/BDMV/STREAM/00726.m2ts
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00722.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00722.m2ts to file E:/THE_ABYSS/BDMV/STREAM/00722.m2ts
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00727.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00727.m2ts to file E:/THE_ABYSS/BDMV/STREAM/00727.m2ts
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00716.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00716.m2ts to file E:/THE_ABYSS/BDMV/STREAM/00716.m2ts
Encountered 6 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
Backup done but 46 files failed hash check-
				Roadwarrior980
Re: The Abyss 4K
Has anyone had success on the Asus BW-16D1HT or LGBU40N?
						Re: The Abyss 4K
I just completed a full disk backup with ASUS BW-16H1T.Roadwarrior980 wrote: ↑Sat Mar 23, 2024 11:32 amHas anyone had success on the Asus BW-16D1HT or LGBU40N?
Re: The Abyss 4K
What firmware are you on your Asus. I have the same and I cannot get The Abyss extended to rip. 3-4 tries but still not working. Thanks.niteflyr wrote: ↑Sat Mar 23, 2024 7:55 pmI just completed a full disk backup with ASUS BW-16H1T.Roadwarrior980 wrote: ↑Sat Mar 23, 2024 11:32 amHas anyone had success on the Asus BW-16D1HT or LGBU40N?
Re: The Abyss 4K
3.10argo44 wrote: ↑Sat Mar 23, 2024 9:12 pmWhat firmware are you on your Asus. I have the same and I cannot get The Abyss extended to rip. 3-4 tries but still not working. Thanks.niteflyr wrote: ↑Sat Mar 23, 2024 7:55 pmI just completed a full disk backup with ASUS BW-16H1T.Roadwarrior980 wrote: ↑Sat Mar 23, 2024 11:32 amHas anyone had success on the Asus BW-16D1HT or LGBU40N?
Re: The Abyss 4K
Re: The Abyss 4K
Is it possible that MakeMKV just needs an update to make this disc work properly?
						Re: The Abyss 4K
No.  It's a problem with the discs and/or drives.
And I was afraid of my problem happening....my replacement hasn't been shipped because it's "backordered". FFS
