gm23o wrote:
Sun Mar 10, 2024 5:20 pm
I'm experiencing raised blacks in DV with some movies.
I'm using an Oppo clone connected to a Nexigo Aurora Pro UST projector.
Full Disc Rip - BDMV
I've noticed this recently when watching :
- Mission Impossible : Dead Reckoning
- True Romance
The letterbox bars and opening credits etc are very raised to a medium grey.
When I switch from TV led to Player led it improves.
Any ideas?
full disc rip?? are you sure because it sounds like your video is cropped which would produce a raised letterbox...
jayper
Post by jayper »
croweyes1121 wrote:
Wed Mar 20, 2024 1:37 pm
PlatypusW wrote:
Sat Dec 05, 2020 7:17 pm
RESET_9999 wrote:
Sat Dec 05, 2020 4:09 pm
I merged mine in a single TS file.
So if FF works for each individual part, that pretty much confirms the issue is related to the length of the movie.
thank you
Yes but that isn't enough for me :P
I still haven't got myself a x700 yet, but I dug out my old x800. It can't do dolby vision, but I had some time today and figured it should be close enough to see whats going on (they should be very similar internal players if not the same).
Started with the second hobbit film. The raw m2ts and the tsmuxer file both wouldn't seek. 'Operation not permitted'.
Tried cutting the file with tsmuxer to 2 hours and 45 minutes. Seek worked.
Then I went for 2 hours 50 minutes. Seek didn't work.
Something in tsmuxer caught my eye: "--cut-end=10200000ms"
To me that seemed like such a specific round number. I have now tested both hobbit 1 and 2...
If the file is 2 hours, 46 minutes and 39 seconds or shorter. The file will allow seeking.
If the file is 2 hours, 46 minutes and 40 seconds or longer. The file will not allow seeking.
Turns out in milliseconds that is:
9999000ms: Seeks
10000000ms: Does not seek
From all this, I believe that if the file is greater than (or equal to) 10 million millisconds then seeking will not work. Anything below seems to work fine.
Does this align with what you have experienced on the x700? Know any titles that might be under this 10 million ms 'limit' that don't allow seeking?
Note: For me, on the latest tsmuxer nightly, the resulting file was always 1 second less than what I put into the 'end'. So if anyone tries this, take this into account if you are trying to be precise.
Why there might be such a limit I'm not sure - maybe someone else might know that :?:
Never seen something related to length in ms, at least 10 million...doesn't really strike me as a number that would normally cause issues in the computing world :?
Has anyone ever figured out a workaround for this issue that doesn't involve splitting the file (which I really would prefer not to have to do)? Surely there's some way to change a setting in tsmuxer that allows the file to be seekable...
If you have an x700 or x800m2, and you're trying to play back a Profile 7 file (ie a UHD with DV), use tsmuxer to create a BDMV folder output. Place the BDMV folder in the root of a USB drive.
To my knowledge, there is no workaround for the seeking issue with TS files. I believe that is a device limitation.
croweyes1121
Post by croweyes1121 »
RESET_9999 wrote:
Wed Mar 20, 2024 2:08 pm
I dont think there's anything you can do about it except using BDMV folder
Oh, if that works, then I'm a happy camper. I'm happy to do it this way, I just want to be able to watch a 3-hr movie without stopping it. I just assumed it still would not be seekable even if I put it on the drive that way. Trying it now! :)
croweyes1121
jayper wrote:
Wed Mar 20, 2024 2:48 pm
This is not working for me.
The standalone m2ts file plays fine (albeit without the ability to seek). When I export to a BDMV folder, the X700 sees it as an AVCHD video file (as I understand it should), but it won't play. In fact, attempting to play it just locks up the player to the point that I have to unplug it. I've tried running the original m2ts file through tsmuxer to a BDMV folder and putting it back on the USB drive multiple times, same result every time. Any suggestions?
i dont know, it worked the last time I tried a long time ago and I don't have to bother with this anymore with the x800m2.
Maybe something changed in tsmuxer?
Hellboy.
Post by Hellboy. »
RESET_9999 wrote:
Wed Mar 20, 2024 7:07 pm
If you no longer use the x800m2, what do you use for DV?
Hellboy. wrote:
Wed Mar 20, 2024 8:06 pm
I meant that I don't have to deal with the TS DV rip bugs(FF/RW on long movies or green screen) because the x800m2 does not have any of those problems.
but...
I will soon stop using my x800m2 though because if you haven't heard, the old UGOOS AM6plus is now stable with FEL, supports CMV4.0, and does true TV-LED.
bbeny123
Post by bbeny123 »
RESET_9999 wrote:
Wed Mar 20, 2024 8:22 pm
Let's assume that Ugoos AM6B Plus is stable with FEL - will it be better in terms of image quality than x800m2?
Does the x800m2 support CMv4.0?
bbeny123 wrote:
Wed Mar 20, 2024 9:30 pm
Since it supports true tv-led, for cmv2.9 content it should be the same quality. I will do a direct comparison with the Shield, AppleTV, and X800m2 once I receive my Ugoos (early April, tracking says)
For cmv4.0 content, on the other hand, the ugoos should be better because cmv2.9 hardware/content have crushed black and cmv4.0 has better tone mapping.
The talk about the stable FEL build is happening here FYI:
https://discourse.coreelec.org/t/dolby- ... /24273/707
JCLG8
Post by JCLG8 »
On a Sony X700 does a DV m2ts or ts file play in dolby vision as it should or does the player just take hdr10 and present it as dolby vision?
jayper
Post by jayper »
but...
When you say the "old UGOOS AM6plus," do you mean this version? https://ugoos.com/ugoos-am6-plus-android-9-4-32-gb
Not the 2021 Version?
I ordered the AM6B+. I think the only difference is the wifi 6
Trackings says it has now arrived in my country, I might get mine sooner than expected :)
jayper wrote:
Thu Mar 21, 2024 3:30 pm
LV8HD
Post by LV8HD »
RESET_9999 wrote:
Thu Mar 21, 2024 4:17 pm
Is this one the only model that can theoretically playback Dolby Vision correctly or the newer models can too?
LV8HD wrote:
Thu Mar 21, 2024 9:07 pm
I don't know but all the tests and development are done with the AM6+
bobbymkV
Post by bobbymkV »
If anyone is interested in a deal on a barely used AM6+ shoot me a message (I'm based in the US). My days of being obsessed with DV playback have long past
