Just bought an external BD drive before reading this and I was wondering if there was a place I can send my firmware dump for checking?
I wanted to ask before just throwing attachments to the forum on my first post.
Drive shows as: HL-DT-ST_BD-RE__WH16NS58 and I
Ultimate UHD Drives Flashing Guide Updated New Pioneer Flashing 2026
LordMortus
There is a MK version for NS58 in the firmware pack but you can also flash it straight to BH16NS60 1.02 which works better for 3-layer discs. I have a NS58 firmware on one of my drives to do disc quality checks for burned media with Vinpower VPTools / qxptools. If you are only interested in ripping discs, flash BH16NS60 firmware.LordMortus wrote: Sun Mar 17, 2024 9:45 pm Just bought an external BD drive before reading this and I was wondering if there was a place I can send my firmware dump for checking?
Stingray
if SDFtool does not see my new ASUS BW-16D1HT -will it Motherboard issue? and I need to try another PC or adapterMartyMcNuts wrote: Wed Mar 13, 2024 9:04 am Go to the SDFtool Flasher thread and follow the first post.
Do you have MakeMKV installed in the default directory?Stingray wrote: Tue Mar 19, 2024 8:33 pmif SDFtool does not see my new ASUS BW-16D1HT -will it Motherboard issue? and I need to try another PC or adapterMartyMcNuts wrote: Wed Mar 13, 2024 9:04 am Go to the SDFtool Flasher thread and follow the first post.
How is the drive connected to the PC?
If anything fails, get that SATA-USB adapter I recommended further up.Stingray wrote: Tue Mar 19, 2024 8:33 pmif SDFtool does not see my new ASUS BW-16D1HT -will it Motherboard issue? and I need to try another PC or adapterMartyMcNuts wrote: Wed Mar 13, 2024 9:04 am Go to the SDFtool Flasher thread and follow the first post.
Stingray
yes, MakeMkv installed in the default foldersMartyMcNuts wrote: Tue Mar 19, 2024 10:31 pm Do you have MakeMKV installed in the default directory?
the drive is connected to internal SATA (Z790 MoBo)
just use the command line scary black box good not bad...Stingray wrote: Wed Mar 20, 2024 10:57 am
Stingray
please advice from where VPTools could be downloaded?Coopervid wrote: Mon Mar 18, 2024 11:29 am disc quality checks for burned media with Vinpower VPTools
bruzzel
Dear experts,
I have bought a new BU40N drive and wasn't able to flash it with the command line or de SDFtool Flasher 1.3.5
The command line throughs an error:
.\makemkvcon64.exe f --all-yes -d G: rawflash enc -i c:\temp\makemkv\HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
No drive tool logic found in SDF.bin
Internal error 0x8d000000
The SFDtool flasher simply does nothing:
It doesn't dump the current firmware and refuses to flash the 1.03 firmware. It recognizes drive still.
OS device name: G:
Product: BD-RE BU40N
Revision: 1.04
Serial number: MOENC6I3954
Firmware date: 2120-05-06 11:42
Highest AACS version: 77
Harware support: Yes
Firmware support: No
Firmware version: 1.04
What is my fault here?
Thanks for any feedback and hints!
OS device name: G:
Revision: 1.04
How is the drive connected to your PC?bruzzel wrote: Wed Mar 20, 2024 11:10 pm Dear experts,
OS device name: G:
Revision: 1.04
kiranmehta
Just got new USB 3.0 adapter and was able to flash my asus bw-16d1ht properly and everything worked out fine.Coopervid wrote: Sun Mar 17, 2024 10:35 am Most likely the chipset of that enclosure doesn't support flashing. You will need to attach it to SATA or buy this USB-> SATA adapter.
https://www.amazon.com/BENFEI-Drive-Ada ... r=8-3&th=1
Thank you to all in the forum who guided me @CooperVid, @MartyMcNuts and @Billycar11.
Additionally can anyone confirm if newegg.com has the Pioneer BDR-XD08UMB-S with 1.01 firmware in the US? My friend is coming next month to india so figured to bank on this (or LG BP60NB10) as well as a backup external drive
bruzzel
It is in an external housing connected with a USB 3 cable
Attach it directly to SATA. Not all enclosures support flashing. If you only have a laptop then buy the adapter I recommended further up.
sm0r3s
To the GODs of MakeMKV, to my understanding, I'm pretty sure I cannot flash my LG WH16NS40 SVC Code:NS40 manufactured Feb 2015, using the OWC Mercury Pro. Am I correct from reading everything before doing so?
Product: BD-RE WH16NS40
Revision: 1.02
Serial number:
Firmware date: 2114-05-07 10:26
Highest AACS version: 78
Drive platform: MT1939
Firmware version: 1.02
BD raw metadata read: Partial
Revision: 1.02
Serial number:
