The Abyss 4K
Bradd
The Abyss 4K
Post by Bradd » Wed Mar 20, 2024 4:21 am
I get this error when i rip this disc.
MakeMKV v1.17.6 win(x64-release) started
Using LibreDrive mode (v06.3 id=4FBA32AEC678)
Using Java runtime from C:\Program Files (x86)\Java\jre-1.8\bin\java.exe
Saving 8 titles into directory C:/Video/The Abyss
AV sync issue in stream 7 at 0:00:00 : Forced subtitles track #7 turned out to be empty and was removed from output file
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00727.m2ts' at offset '1159569408'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '1159569408'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00727.m2ts' at offset '1159698432'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00727.m2ts' at offset '1159827456'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '1159827456'
Failed to save title 2 to file C:/Video/The Abyss/THE ABYSS-SEG_MainFeature_35_EXT_t02.mkv
AV sync issue in stream 5 at 0:06:27.680 with duration of 64ms : 2 frame(s) dropped to reduce audio skew to -0.005ms
AV sync issue in stream 5 at 0:17:52.160 with duration of 64ms : 2 frame(s) dropped to reduce audio skew to +4.658ms
AV sync issue in stream 5 at 0:28:58.912 with duration of 64ms : 2 frame(s) dropped to reduce audio skew to +14.33ms
AV sync issue in stream 5 at 0:46:18.400 with duration of 64ms : 2 frame(s) dropped to reduce audio skew to -0.005ms
AV sync issue in stream 5 at 0:50:22.304 with duration of 64ms : 2 frame(s) dropped to reduce audio skew to -0.005ms
AV sync issue in stream 5 at 0:06:35.872 with duration of 64ms : 2 frame(s) dropped to reduce audio skew to -0.005ms
AV sync issue in stream 5 at 0:12:17.632 with duration of 64ms : 2 frame(s) dropped to reduce audio skew to +0ms
AV sync issue in stream 5 at 0:19:18.592 with duration of 64ms : 2 frame(s) dropped to reduce audio skew to -0.008ms
AV sync issue in stream 5 at 0:24:33.184 with duration of 64ms : 2 frame(s) dropped to reduce audio skew to +0ms
AV sync issue in stream 5 at 0:30:40.384 with duration of 64ms : 2 frame(s) dropped to reduce audio skew to +0ms
AV sync issue in stream 5 at 0:46:11.264 with duration of 64ms : 2 frame(s) dropped to reduce audio skew to -0.002ms
AV sync issue in stream 5 at 0:58:07.584 with duration of 64ms : 2 frame(s) dropped to reduce audio skew to -0.008ms
AV sync issue in stream 5 at 1:01:25.760 with duration of 64ms : 2 frame(s) dropped to reduce audio skew to -0.008ms
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00706.m2ts' at offset '137048064'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '137048064'
Failed to save title 4 to file C:/Video/The Abyss/THE ABYSS-FPL_MainFeature_EXT_t04.mkv
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00716.m2ts' at offset '0'
Failed to save title 5 to file C:/Video/The Abyss/THE ABYSS_t05.mkv
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00726.m2ts' at offset '0'
Failed to save title 6 to file C:/Video/The Abyss/THE ABYSS_t06.mkv
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00727.m2ts' at offset '0'
Failed to save title 7 to file C:/Video/The Abyss/THE ABYSS_t07.mkv
Encountered 31 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
3 titles saved, 5 failed
Bradd
Re: The Abyss 4K
Post by Woodstock » Wed Mar 20, 2024 2:06 pm
You're encountering errors in reading. Two possibilities - dirty disk, or drive trying to read faster than it has power to do.
Is this a USB-powered drive?
Bradd
Re: The Abyss 4K
Post by Bradd » Wed Mar 20, 2024 3:57 pm
It's an LG internal Ultra HD Blu Ray M-Disc
I did clean the disc.
herbgo
Re: The Abyss 4K
Post by herbgo » Fri Mar 22, 2024 8:35 pm
I'm having the same issues with this blu-ray. Tried two different 4K Blu-Ray drives ... same problem. Massive A/V Sync issues.
Also, cleaned the disc AND the drives to no avail.
