BDR-XS07S UHD Flash
hydra
BDR-XS07S UHD Flash
Is it possible to flash this drive to read UHD disks? Here are the specs according to MakeMKV:
OS device name: F:
Manufacturer: PIONEER
Product: BD-RW BDR-XS07
Revision: 1.01
Serial number: Removed
Firmware date: 2020-09-03
Bus encryption flags: 13
Highest AACS version: 70
Drive platform: RS8E20
Firmware version: 1.01
OS device name: F:
Revision: 1.01
Re: BDR-XS07S UHD Flash
Check PMhydra wrote: Thu Jan 11, 2024 6:37 pm Is it possible to flash this drive to read UHD disks? Here are the specs according to MakeMKV:
OS device name: F:
Revision: 1.01
hydra
Hi Coopervid, I'm assuming it's because I just registered yesterday, but I'm not seeing an option to respond to your PM.
Can you tell me how the flasher works? Is it physical or software? Sorry if this is a noob question; this is all very new to me.
Software. Check PM.
hydra
It seems to have worked, thank you! I'm ripping a 4k disk now, so we'll see how it turns out.
InfDisco
Hello, I actually picked up this same drive yesterday and it has the same firmware. What was the solution to make it work? Thanks!
qlxel
Hello everyone here,
just as the others here I too recently picked up a BDR-XS07TS recently and would like to know how to get it up to UHD.
I'm aware of Billycar11's Auto flash kit for 25, but it sounds here like there might be another way too.
Just like hydra I can not yet send PMs.
fstchevy
Where did you guys buy your drives from? I just purchased one from BH Photo and unfortunately it has 1.03.hydra wrote: Fri Jan 12, 2024 5:56 pm It seems to have worked, thank you! I'm ripping a 4k disk now, so we'll see how it turns out.
mrcobra92
Hello! I just picked up one of these drives as well and it has firmware 1.01! Can someone please PM me or point me in the direction of how to flash the UHD firmware on this? Thanks!
Check PM.mrcobra92 wrote: Wed Mar 20, 2024 2:05 pm Hello! I just picked up one of these drives as well and it has firmware 1.01! Can someone please PM me or point me in the direction of how to flash the UHD firmware on this? Thanks!
qlxel
Hello Coopervid,
could you please send me the instructions as well?
Check PM.qlxel wrote: Wed Mar 20, 2024 2:21 pm Hello Coopervid,
qlxel
Apparently I can't even answer to PMs yet, so big thanks here to Coopervid, flash worked without a problem with FW 1.01
sense
Hello Coopervid,
could you please send me the instructions to downgrade the XS07U to a libredrive firmware ?
Edward1017
Hello Coopervid,
I also picked up one of these drives recently. Mine is on firmware 1.00.
Can you also PM me with the instructions?
