LordMortus
Just bought an external BD drive before reading this and I was wondering if there was a place I can send my firmware dump for checking?
I wanted to ask before just throwing attachments to the forum on my first post.
Drive shows as: HL-DT-ST_BD-RE__WH16NS58 and I
There is a MK version for NS58 in the firmware pack but you can also flash it straight to BH16NS60 1.02 which works better for 3-layer discs. I have a NS58 firmware on one of my drives to do disc quality checks for burned media with Vinpower VPTools / qxptools. If you are only interested in ripping discs, flash BH16NS60 firmware.LordMortus wrote: ↑Sun Mar 17, 2024 9:45 pmJust bought an external BD drive before reading this and I was wondering if there was a place I can send my firmware dump for checking?
if SDFtool does not see my new ASUS BW-16D1HT -will it Motherboard issue? and I need to try another PC or adapterMartyMcNuts wrote: ↑Wed Mar 13, 2024 9:04 amGo to the SDFtool Flasher thread and follow the first post.
Do you have MakeMKV installed in the default directory?Stingray wrote: ↑Tue Mar 19, 2024 8:33 pmif SDFtool does not see my new ASUS BW-16D1HT -will it Motherboard issue? and I need to try another PC or adapterMartyMcNuts wrote: ↑Wed Mar 13, 2024 9:04 amGo to the SDFtool Flasher thread and follow the first post.
How is the drive connected to the PC?
If anything fails, get that SATA-USB adapter I recommended further up.Stingray wrote: ↑Tue Mar 19, 2024 8:33 pmif SDFtool does not see my new ASUS BW-16D1HT -will it Motherboard issue? and I need to try another PC or adapterMartyMcNuts wrote: ↑Wed Mar 13, 2024 9:04 amGo to the SDFtool Flasher thread and follow the first post.
yes, MakeMkv installed in the default foldersMartyMcNuts wrote: ↑Tue Mar 19, 2024 10:31 pmDo you have MakeMKV installed in the default directory?
the drive is connected to internal SATA (Z790 MoBo)
just use the command line scary black box good not bad...
Dear experts,
I have bought a new BU40N drive and wasn't able to flash it with the command line or de SDFtool Flasher 1.3.5
The command line throughs an error:
.\makemkvcon64.exe f --all-yes -d G: rawflash enc -i c:\temp\makemkv\HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
No drive tool logic found in SDF.bin
Internal error 0x8d000000
The SFDtool flasher simply does nothing:
It doesn't dump the current firmware and refuses to flash the 1.03 firmware. It recognizes drive still.
OS device name: G:
Product: BD-RE BU40N
Revision: 1.04
Serial number: MOENC6I3954
Firmware date: 2120-05-06 11:42
Highest AACS version: 77
Harware support: Yes
Firmware support: No
Firmware version: 1.04
What is my fault here?
Thanks for any feedback and hints!
OS device name: G:
Revision: 1.04
How is the drive connected to your PC?bruzzel wrote: ↑Wed Mar 20, 2024 11:10 pmDear experts,
OS device name: G:
Revision: 1.04
kiranmehta
Just got new USB 3.0 adapter and was able to flash my asus bw-16d1ht properly and everything worked out fine.Coopervid wrote: ↑Sun Mar 17, 2024 10:35 amMost likely the chipset of that enclosure doesn't support flashing. You will need to attach it to SATA or buy this USB-> SATA adapter.
https://www.amazon.com/BENFEI-Drive-Ada ... r=8-3&th=1
Thank you to all in the forum who guided me @CooperVid, @MartyMcNuts and @Billycar11.
Additionally can anyone confirm if newegg.com has the Pioneer BDR-XD08UMB-S with 1.01 firmware in the US? My friend is coming next month to india so figured to bank on this (or LG BP60NB10) as well as a backup external drive
It is in an external housing connected with a USB 3 cable
To the GODs of MakeMKV, to my understanding, I'm pretty sure I cannot flash my LG WH16NS40 SVC Code:NS40 manufactured Feb 2015, using the OWC Mercury Pro. Am I correct from reading everything before doing so?
Product: BD-RE WH16NS40
Revision: 1.02
Serial number:
Firmware date: 2114-05-07 10:26
Highest AACS version: 78
Drive platform: MT1939
Firmware version: 1.02
BD raw metadata read: Partial
Revision: 1.02
Serial number:
