Ultimate UHD Drives Flashing Guide Updated 2025
kiranmehta
#2236 Post by kiranmehta » Sun Mar 17, 2024 10:08 am
MartyMcNuts wrote:
Wed Mar 13, 2024 9:04 am
kiranmehta wrote:
Wed Mar 13, 2024 8:02 am
MartyMcNuts wrote:
Wed Mar 13, 2024 7:35 am
If you want to enable LibreDrive and/or rip UHD discs, then yes, it must be flashed.
Can you please point to the exact steps, I am searching the forum but not getting anyone who has mentioned the steps with firmware 3.11
Ps. Yes I want to make it uhd friendly.
Go to the SDFtool Flasher thread and follow the first post.
If you don't care about writing discs, flash it directly to WH16NS60 1.02-MK firmware. If you do plan on writing discs occasionally, flash it directly to BW-16D1HT 3.10-MK firmware.
Hi i got my joker 4k bluray and uhd disc today and was able to rip it ootb without flashing, however when flashing to make it uhd friendly i am getting below error
"Command produced error code0x82000000"
PS : My drive enclosure is USB 2.0 only currently
#2237 Post by Coopervid » Sun Mar 17, 2024 10:35 am
Most likely the chipset of that enclosure doesn't support flashing. You will need to attach it to SATA or buy this USB-> SATA adapter.
https://www.amazon.com/BENFEI-Drive-Ada ... r=8-3&th=1
LordMortus
#2238 Post by LordMortus » Sun Mar 17, 2024 9:45 pm
Just bought an external BD drive before reading this and I was wondering if there was a place I can send my firmware dump for checking?
I wanted to ask before just throwing attachments to the forum on my first post.
Drive shows as: HL-DT-ST_BD-RE__WH16NS58 and I
#2239 Post by Coopervid » Mon Mar 18, 2024 11:29 am
There is a MK version for NS58 in the firmware pack but you can also flash it straight to BH16NS60 1.02 which works better for 3-layer discs. I have a NS58 firmware on one of my drives to do disc quality checks for burned media with Vinpower VPTools / qxptools. If you are only interested in ripping discs, flash BH16NS60 firmware.
Stingray
#2240 Post by Stingray » Tue Mar 19, 2024 8:33 pm
if SDFtool does not see my new ASUS BW-16D1HT -will it Motherboard issue? and I need to try another PC or adapter
#2241 Post by MartyMcNuts » Tue Mar 19, 2024 10:31 pm
Do you have MakeMKV installed in the default directory?
How is the drive connected to the PC?
#2242 Post by Coopervid » Tue Mar 19, 2024 10:44 pm
If anything fails, get that SATA-USB adapter I recommended further up.
Stingray
#2243 Post by Stingray » Wed Mar 20, 2024 10:57 am
yes, MakeMkv installed in the default folders
the drive is connected to internal SATA (Z790 MoBo)
#2244 Post by Billycar11 » Wed Mar 20, 2024 11:26 am
just use the command line scary black box good not bad...
Stingray
#2245 Post by Stingray » Wed Mar 20, 2024 8:05 pm
please advice from where VPTools could be downloaded?
#2246 Post by Coopervid » Wed Mar 20, 2024 9:41 pm
Try qpxtool or write a PM to me.
https://qpxtool.sourceforge.io/download.html
bruzzel
#2247 Post by bruzzel » Wed Mar 20, 2024 11:10 pm
Dear experts,
I have bought a new BU40N drive and wasn't able to flash it with the command line or de SDFtool Flasher 1.3.5
The command line throughs an error:
.\makemkvcon64.exe f --all-yes -d G: rawflash enc -i c:\temp\makemkv\HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
No drive tool logic found in SDF.bin
Internal error 0x8d000000
The SFDtool flasher simply does nothing:
It doesn't dump the current firmware and refuses to flash the 1.03 firmware. It recognizes drive still.
OS device name: G:
Product: BD-RE BU40N
Revision: 1.04
Serial number: MOENC6I3954
Firmware date: 2120-05-06 11:42
Highest AACS version: 77
Harware support: Yes
Firmware support: No
Firmware version: 1.04
What is my fault here?
Thanks for any feedback and hints!
#2248 Post by MartyMcNuts » Thu Mar 21, 2024 2:39 am
Dear experts,
OS device name: G:
Revision: 1.04
How is the drive connected to your PC?
kiranmehta
#2249 Post by kiranmehta » Thu Mar 21, 2024 7:29 am
Just got new USB 3.0 adapter and was able to flash my asus bw-16d1ht properly and everything worked out fine.
Thank you to all in the forum who guided me @CooperVid, @MartyMcNuts and @Billycar11.
Additionally can anyone confirm if newegg.com has the Pioneer BDR-XD08UMB-S with 1.01 firmware in the US? My friend is coming next month to india so figured to bank on this (or LG BP60NB10) as well as a backup external drive
bruzzel
#2250 Post by bruzzel » Fri Mar 22, 2024 9:13 am
It is in an external housing connected with a USB 3 cable
