Thank you for quick reply and resolution.MartyMcNuts wrote: ↑Wed Mar 13, 2024 9:04 amGo to the SDFtool Flasher thread and follow the first post.kiranmehta wrote: ↑Wed Mar 13, 2024 8:02 amMartyMcNuts wrote: ↑Wed Mar 13, 2024 7:35 am
If you want to enable LibreDrive and/or rip UHD discs, then yes, it must be flashed.
Can you please point to the exact steps, I am searching the forum but not getting anyone who has mentioned the steps with firmware 3.11
Ps. Yes I want to make it uhd friendly.
If you don't care about writing discs, flash it directly to WH16NS60 1.02-MK firmware. If you do plan on writing discs occasionally, flash it directly to BW-16D1HT 3.10-MK firmware.
My drive arrived today and I'll be getting my first 4k uhd disc in 2-3 days will flash it then and will keep updated
Thank you!
