Post by Coopervid » Mon Mar 18, 2024 11:29 am
LordMortus wrote: Sun Mar 17, 2024 9:45 pm Just bought an external BD drive before reading this and I was wondering if there was a place I can send my firmware dump for checking?
I wanted to ask before just throwing attachments to the forum on my first post.
Drive shows as: HL-DT-ST_BD-RE__WH16NS58 and I
There is a MK version for NS58 in the firmware pack but you can also flash it straight to BH16NS60 1.02 which works better for 3-layer discs. I have a NS58 firmware on one of my drives to do disc quality checks for burned media with Vinpower VPTools / qxptools. If you are only interested in ripping discs, flash BH16NS60 firmware.
Stingray
Post by Stingray » Tue Mar 19, 2024 8:33 pm
MartyMcNuts wrote: Wed Mar 13, 2024 9:04 am Go to the SDFtool Flasher thread and follow the first post.
if SDFtool does not see my new ASUS BW-16D1HT -will it Motherboard issue? and I need to try another PC or adapter
Post by MartyMcNuts » Tue Mar 19, 2024 10:31 pm
Stingray wrote: Tue Mar 19, 2024 8:33 pm
Do you have MakeMKV installed in the default directory?
How is the drive connected to the PC?
Post by Coopervid » Tue Mar 19, 2024 10:44 pm
If anything fails, get that SATA-USB adapter I recommended further up.
Stingray
Post by Stingray » Wed Mar 20, 2024 10:57 am
MartyMcNuts wrote: Tue Mar 19, 2024 10:31 pm Do you have MakeMKV installed in the default directory?
yes, MakeMkv installed in the default folders
the drive is connected to internal SATA (Z790 MoBo)
Post by Billycar11 » Wed Mar 20, 2024 11:26 am
Stingray wrote: Wed Mar 20, 2024 10:57 am
just use the command line scary black box good not bad...
Stingray
Post by Stingray » Wed Mar 20, 2024 8:05 pm
Coopervid wrote: Mon Mar 18, 2024 11:29 am disc quality checks for burned media with Vinpower VPTools
please advice from where VPTools could be downloaded?
Post by Coopervid » Wed Mar 20, 2024 9:41 pm
Stingray wrote: Wed Mar 20, 2024 8:05 pm
Try qpxtool or write a PM to me.
https://qpxtool.sourceforge.io/download.html
bruzzel
Post by bruzzel » Wed Mar 20, 2024 11:10 pm
Dear experts,
I have bought a new BU40N drive and wasn't able to flash it with the command line or de SDFtool Flasher 1.3.5
The command line throughs an error:
.\makemkvcon64.exe f --all-yes -d G: rawflash enc -i c:\temp\makemkv\HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
No drive tool logic found in SDF.bin
Internal error 0x8d000000
The SFDtool flasher simply does nothing:
It doesn't dump the current firmware and refuses to flash the 1.03 firmware. It recognizes drive still.
OS device name: G:
Product: BD-RE BU40N
Revision: 1.04
Serial number: MOENC6I3954
Firmware date: 2120-05-06 11:42
Highest AACS version: 77
Harware support: Yes
Firmware support: No
Firmware version: 1.04
What is my fault here?
Thanks for any feedback and hints!
Post by MartyMcNuts » Thu Mar 21, 2024 2:39 am
bruzzel wrote: Wed Mar 20, 2024 11:10 pm Dear experts,
OS device name: G:
Revision: 1.04
How is the drive connected to your PC?
kiranmehta
Post by kiranmehta » Thu Mar 21, 2024 7:29 am
Coopervid wrote: Sun Mar 17, 2024 10:35 am Most likely the chipset of that enclosure doesn't support flashing. You will need to attach it to SATA or buy this USB-> SATA adapter.
https://www.amazon.com/BENFEI-Drive-Ada ... r=8-3&th=1
Just got new USB 3.0 adapter and was able to flash my asus bw-16d1ht properly and everything worked out fine.
Thank you to all in the forum who guided me @CooperVid, @MartyMcNuts and @Billycar11.
Additionally can anyone confirm if newegg.com has the Pioneer BDR-XD08UMB-S with 1.01 firmware in the US? My friend is coming next month to india so figured to bank on this (or LG BP60NB10) as well as a backup external drive
bruzzel
Post by bruzzel » Fri Mar 22, 2024 9:13 am
MartyMcNuts wrote: Thu Mar 21, 2024 2:39 am How is the drive connected to your PC?
It is in an external housing connected with a USB 3 cable
Post by Coopervid » Fri Mar 22, 2024 12:53 pm
bruzzel wrote: Fri Mar 22, 2024 9:13 am
Attach it directly to SATA. Not all enclosures support flashing. If you only have a laptop then buy the adapter I recommended further up.
sm0r3s
Post by sm0r3s » Sat Mar 23, 2024 3:29 pm
To the GODs of MakeMKV, to my understanding, I'm pretty sure I cannot flash my LG WH16NS40 SVC Code:NS40 manufactured Feb 2015, using the OWC Mercury Pro. Am I correct from reading everything before doing so?
Product: BD-RE WH16NS40
Revision: 1.02
Serial number:
Firmware date: 2114-05-07 10:26
Highest AACS version: 78
Drive platform: MT1939
Firmware version: 1.02
BD raw metadata read: Partial
Post by Woodstock » Sat Mar 23, 2024 3:39 pm
The question is really, why would you need to flash it?
UHD didn't start shipping until almost two years after this drive was built, so it doesn't add anything to your capabilities.
