I'd like to upgrade the following drive but have not clue. I'd also like to backup the existing firmware if possible first.
Product: BD-RE BP60NB10
Revision: 1.02
Firmware date: 2121-07-08 15:56
Highest AACS version: 72
Harware support: Yes
Firmware support: No
Firmware version: 1.02
New to this - How do I upgrade this drive?
Re: New to this - How do I upgrade this drive?
You can't backup the complete existing firmware, only the important bits. Use SDFtool Flasher to READ the firmware (important bits) to a 70kb tar file. Then WRITE firmware BP60NB10-NB12 1.02-MK to the drive and you will then be able to rip UHD discs.EricR wrote: Tue Mar 19, 2024 8:29 pm I'd like to upgrade the following drive but have not clue. I'd also like to backup the existing firmware if possible first.
Revision: 1.02
EricR
Ok, sounds good. Where can I locate the MK file to download?
This one?
mk-firmware-pack-20200720.zip\mk-firmware-pack-20200720\MK\HL-DT-ST\BP60NB10 - ZIP archive
HL-DT-ST-BD-RE_BP60NB10-1.02-NM00800-212005070935.bin
This one?
No. Go to the SDFtool flasher thread and download my "All you need firmware pack (martyMcNuts)". It has the BP60NB10-NB12 1.02-MK file in it.EricR wrote: Tue Mar 19, 2024 11:50 pm Ok, sounds good. Where can I locate the MK file to download?
This one?
EricR
after I put a disc in it shows:
OS device name: E:
Revision: 1.02
OS device name: E:
Revision: 1.02
Yep, all good.EricR wrote: Wed Mar 20, 2024 12:19 pm after I put a disc in it shows:
OS device name: E:
Revision: 1.02
