LibreDrive for Pioneer drives
I see now the problem. Please check your PM.
Thanks for the help. But I am not authorised to reply you through PM because I am too new here. Please send me the flasher. Thank you so much.
Check new PM
MKUltra2020
Hi, I've just created an account to seek some help, though I've been using MakeMKV for a few years now. Hopefully someone will be able to assist me.
Until just recently, I had been using an LG external blu-ray drive for ripping my BDs and DVDs. It still seems to work fine, but I decided to purchase a new Pioneer external BD Drive. I've noticed that LibreDrive does not automatically enable itself for the Pioneer drive like it does the LG. (EDIT: Upon further inspection, it seems that LibreDrive doesn't actually auto-enable, but it does say that it's available for the LG drive)
I'm hesitant to flash and potentially brick a brand new drive, so I'm hoping there is a simple solution that I'm clearly overlooking.
Here is the drive information MakeMKV gives me for the Pioneer drive:
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-XD08
Revision: 1.00
Serial number: REDACTED
Firmware date: 2022-04-03
Highest AACS version: 81
Drive platform: Pioneer RS9330
Firmware version: GENE
Thank you in advance. I don't know if I'm able to receive PMs yet since I literally only just joined, but I hope someone here can point me in the right direction.
Conversely, since the LG is the older of the two drives I have less attachment to it so I would consider flashing that one for LibreDrive, if someone could help with that.
OS device name: E:
Revision: 1.00
Hello there,
I am a newbie to this forum. There is a lot of good info here, thanks for providing. I recently purchased the BDR-S13U-X as well and was hoping I could obtain the latest flasher? I was going send a PM to Mike but I get an error since I just signed up.
Thanks in advance,
Randman76
Thanks in advance,
Randman76
The ux can't be flashed I recommend you return it and get a ux from a seller with old firmwarerandman76 wrote: Sun Mar 24, 2024 6:31 pm Hello there,
Thanks in advance,
Randman76
I do not see the model number on the list it is a MODEL BD-RW BDR-213M Pioneer RS9200
Current profile: DVD-ROM
Product: BD-RW BDR-213M
Revision: 1.04
Serial number:
Firmware date: 2022-12-12
Highest AACS version: 68
Drive platform: Pioneer RS9200
Firmware version: ID56
Revision: 1.04
Serial number:
sorry man to new return it cant be flashed but i have those crossflashed to s13 ubk old fw if you want onejoserz wrote: Tue Mar 26, 2024 2:26 am I do not see the model number on the list it is a MODEL BD-RW BDR-213M Pioneer RS9200
Revision: 1.04
Serial number:
Hello, total noob here. This is what I've got.
The first bluray I ripped mostly worked fine. The 2nd one I tried failed, and now the discs won't load.
Any advice? Thank you.
Manu: Pioneer
Prod: bd-rw bdr-td04d
Rev: 1.00
S#: lfdl069049wl
Fw date: 2012-02-27
Bef: 1b
H aacs v: 2.0
Status: possible but very unlikely to happen
Drive platform: Pioneer rs1040
Firmware version: id84
Manu: Pioneer
Rev: 1.00
S#: lfdl069049wl
Fw date: 2012-02-27
Bef: 1b
H aacs v: 2.0
Power off the drive for a few minutes before turning it back on and trying again.Lololark wrote: Wed Mar 27, 2024 7:18 am Hello, total noob here. This is what I've got.
Manu: Pioneer
Rev: 1.00
S#: lfdl069049wl
Fw date: 2012-02-27
Bef: 1b
H aacs v: 2.0
Evil Teddy
I have this one:
Laufwerksinformation
OS-Gerätename: G:
Produzent: PIONEER
Produkt: BD-RW BDR-XS07U
Revision: 1.03
Serienummer: CIDL008016WL
Firmware-Datum: 2023-01-06
Markierungen der Bus-Verschlüsselung: 13
Firmware version: ID05
The error is:
ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED
and
OS-Gerätename: G:
Produzent: PIONEER
Revision: 1.03
The error is:
and
Sorry man that drive is to new.Evil Teddy wrote: Wed Mar 27, 2024 7:01 pm I have this one:
OS-Gerätename: G:
Produzent: PIONEER
Revision: 1.03
The error is:
and
If you can I recommend you return it if you want UHD and a pioneer best to get from a seller in your region
Thanks a lot man, that did the trick.MartyMcNuts wrote: Wed Mar 27, 2024 9:44 amPower off the drive for a few minutes before turning it back on and trying again.Lololark wrote: Wed Mar 27, 2024 7:18 am Hello, total noob here. This is what I've got.
Manu: Pioneer
Rev: 1.00
S#: lfdl069049wl
Fw date: 2012-02-27
Bef: 1b
H aacs v: 2.0
That's what I'd been doing, but it didn't work until now. I also changed the settings to more "read retry" attempts, I don't know if that helped make a difference, but I'm back on track.
Evil Teddy
Asmcom seller in this forum said that this drive is compatible with makemkv. Link: viewtopic.php?p=73484#p73484Billycar11 wrote: Wed Mar 27, 2024 10:49 pm Sorry man that drive is to new.
The drive is compatible only when it has older firmware (prior to Dec 2022).Evil Teddy wrote: Thu Mar 28, 2024 6:53 amAsmcom seller in this forum said that this drive is compatible with makemkv. Link: viewtopic.php?p=73484#p73484Billycar11 wrote: Wed Mar 27, 2024 10:49 pm Sorry man that drive is to new.
