"AACS host certificate is revoked by your drive" Issue
hitekalex
Re: "AACS host certificate is revoked by your drive" Issue
Post by hitekalex » Thu Aug 11, 2011 12:41 am
mike admin wrote:This should be fixed in 1.6.13
I am still having this issue with 1.6.13 (although just on 1 disk out of 4 I have tried so far, so there is some improvement).
Debug log attached.
Post by mike admin » Fri Aug 19, 2011 2:17 pm
Please do the following test (it sounds silly). Power off your computer (and the bd drive if it's external). It's important that drive should be powered off, not just reset. Then turn on your mac and try to convert the disc that failed again. Please post result here.
Fardilha
Post by Fardilha » Thu Oct 20, 2011 6:24 pm
Hello there.
I'm new to the world of "MakeMKV" so my apologies if I'm making some dumb mistake.
Right now, what I tried was:
Instal both MakeMKV 1.6.15 and DASPI 1.3 under Lion 10.7.2.
Restarted.
Tried to open 2 Blu-ray discs getting the same error: Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive
Tried the "power off, power on" tip on the previous post without any luck.
Tried to add the key file to the "AACS keys directory", but there's no option to do this on the Mac version of MakeMKV (at least that I could find)
The drive info is:
Manufacturer: MATSHITA
Product: BD-CMB UJ-120
Revision: 1.00
Serial number: HD28 030906
Can anyone, please, try to give me some help regarding this?
Thank you!
Pedro Fardilha
Fardilha
Post by Fardilha » Mon Oct 24, 2011 9:22 am
I decided to try a good old re-install of makemkv and (mainly) DASPI.
So, this time, I was already with the drive plugged in and with a disc in it when I re-installed DASPI.
I could hear the drive being accessed during DASPI installation and lo and behold: MakeMKV can now properly decrypt my test disc.
I still need to properly test with a few more discs, but assuming a similar success I'll happily hit that "buy" button
Thank you for making their great software!
Pedro Fardilha
Update:
Aaaand I spoke to soon.
Around 1/3 of the way I'm always getting this type of errors:
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/BDMV/STREAM/00201.m2ts' at offset '8503031808'
Error 'Scsi error - MEDIUM ERROR:NO SEEK COMPLETE' occurred while reading '/BDMV/STREAM/00201.m2ts' at offset '8505784320'
Error 'Scsi error - HARDWARE ERROR:TRACK FOLLOWING ERROR' occurred while reading '/BDMV/STREAM/00201.m2ts' at offset '8506374144'
Error 'Scsi error - MEDIUM ERROR:NO SEEK COMPLETE' occurred while reading '/BDMV/STREAM/00201.m2ts' at offset '8506374144'
I'll try with another discs to see if it's disc or software related
hidarapaneni
Post by hidarapaneni » Sun Dec 23, 2018 5:40 pm
Hi - I am getting following error message while ripping UHD bluray -- most likely current AACS host certificate is revoked by your drive
Here are details and dump file attached..
Drive Details -
Product: BD-RE BU40N
Revision: 1.01
Serial number: KZZI49I1914
Firmware date: 2117-12-22 12:21
Bus encryption flags: 1F
Highest AACS version: 65
Disc Information
Label: MISSION IMPOSSIBLE FALLOUT
Timestamp: 2018-10-08 15:16:54
Data capacity: 90.89 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
Error Message --
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0BF to device 'IoKit:IOBDServices:d6dc7916cd1e1a37:HL-DT-ST BD-RE BU40N 1.01'
DEBUG: Code 0 at C-m9rhoWt,$NB;6=#:213130766
DEBUG: Code 2 at RPGj*V3qs7&kNo3AvP:121263521
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0BF to device 'IoKit:IOBDServices:d6dc7916cd1e1a37:HL-DT-ST BD-RE BU40N 1.01'
DEBUG: Code 2 at RPGj*V3qs7&kNo3AvP:213131709
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0FF to device 'IoKit:IOBDServices:d6dc7916cd1e1a37:HL-DT-ST BD-RE BU40N 1.01'
DEBUG: Code 3 at RPGj*V3qs7&kNo3AvP:121263521
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0FF to device 'IoKit:IOBDServices:d6dc7916cd1e1a37:HL-DT-ST BD-RE BU40N 1.01'
DEBUG: Code 3 at RPGj*V3qs7&kNo3AvP:213131709
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..002000800 to device 'IoKit:IOBDServices:d6dc7916cd1e1a37:HL-DT-ST BD-RE BU40N 1.01'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'IoKit:IOBDServices:d6dc7916cd1e1a37:HL-DT-ST BD-RE BU40N 1.01'
DEBUG: Code 0 at RPGj*V3qs7&kNo3AvP:213132721
DEBUG: Code 3 at RPGj*V3qs7&kNo3AvP:213130904
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'IoKit:IOBDServices:d6dc7916cd1e1a37:HL-DT-ST BD-RE BU40N 1.01'
DEBUG: Code 0 at RPGj*V3qs7&kNo3AvP:121263521
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..03F to device 'IoKit:IOBDServices:d6dc7916cd1e1a37:HL-DT-ST BD-RE BU40N 1.01'
DEBUG: Code 0 at RPGj*V3qs7&kNo3AvP:213131709
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..07F to device 'IoKit:IOBDServices:d6dc7916cd1e1a37:HL-DT-ST BD-RE BU40N 1.01'
DEBUG: Code 1 at RPGj*V3qs7&kNo3AvP:121263521
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..07F to device 'IoKit:IOBDServices:d6dc7916cd1e1a37:HL-DT-ST BD-RE BU40N 1.01'
DEBUG: Code 1 at RPGj*V3qs7&kNo3AvP:213131709
DEBUG: Code 4 at RPGj*V3qs7&kNo3AvP:213130904
Saved AACS dump file as /Users/hdarapaneni/Library/MakeMKV/MKB20_v65_MISSION_IMPOSSIBLE_FALLOUT_07C9.tgz
DEBUG: Code 0 at 3-&G:T%sH~_VhW_a:29396115
DEBUG: Code 0 at `o@<-i39-{I+}w; :(]:121273158
DEBUG: Code 0 at :{`'2(+F0q|?:W.dIk2\:29396713
Backup failed
(189.17 KiB) Downloaded 990 times
Post by Woodstock » Mon Dec 24, 2018 12:33 am
The dump file needs to be sent to svq@makemkv.com, rather than uploaded here.
hidarapaneni
Post by hidarapaneni » Fri Dec 28, 2018 7:35 pm
Thanks Woodstock.. I sent that to svq email.
