I am looking what uhd internal slim drives are available and the only one I can see is:
HLDS BU40N (Still seems to be available in amazon)
Did find the Verbatim 43888, which is external but is it possible to remove the internal odd from it? Possible without destroying the enclosure? As I already have a few LGs x 5.25 wanted to get a Pioneer if possible.
Slim internal UHD drive
Re: Slim internal UHD drive
Yes, it is possible to remove it. On sides there are small holes and you have to pry the top and bottom metal plate ...
josepr wrote: ↑Sun Mar 17, 2024 7:44 amI am looking what uhd internal slim drives are available and the only one I can see is:
if you have the 5.25 lgs why not get a 5.25 pioneer with old fw i have some in the usa and asmcom has them in the UK and Marty in the AUjosepr wrote: ↑Sun Mar 17, 2024 7:44 amI am looking what uhd internal slim drives are available and the only one I can see is:
I second that. And if you think an enclosure is too expensive, replace one LG with a Pioneer and with this cheap adapter you can still use the removed LG via USB. You can even flash with this adapter and attach old hard disks or SATA-SSDs.Billycar11 wrote: ↑Sun Mar 17, 2024 12:19 pmif you have the 5.25 lgs why not get a 5.25 pioneer with old fw i have some in the usa and asmcom has them in the UK and Marty in the AUjosepr wrote: ↑Sun Mar 17, 2024 7:44 amI am looking what uhd internal slim drives are available and the only one I can see is:
https://www.amazon.com/BENFEI-Drive-Ada ... r=8-2&th=1
Form factor currently have space for one slim odd in my case and like to keep it need all together nothing external right now. May get a 5.25 if i decide to build another a bigger case later.Billycar11 wrote: ↑Sun Mar 17, 2024 12:19 pmif you have the 5.25 lgs why not get a 5.25 pioneer with old fw i have some in the usa and asmcom has them in the UK and Marty in the AUjosepr wrote: ↑Sun Mar 17, 2024 7:44 amI am looking what uhd internal slim drives are available and the only one I can see is:
