Ripping 4K UHD with ASUS BW-16D1H-U Pro
szymixsiorek
Post by szymixsiorek »
hi everyone i have a quick question. im going to buy queen rock Montreal 4k uhd blu ray release and i was wondering will i be able to rip that into mkv using my ASUS BW-16D1H-U Pro. any answer will be very appriciated
Re: Ripping 4K UHD with ASUS BW-16D1H-U Pro
What year? What does MakeMKV say about it, especially about its UHD capabilities?
The BW-16D1H-U has changed drives over the years. Early ones aren't UHD. Later ones need to have new firmware.
szymixsiorek wrote: Sat Mar 16, 2024 9:43 pm hi everyone i have a quick question. im going to buy queen rock Montreal 4k uhd blu ray release and i was wondering will i be able to rip that into mkv using my ASUS BW-16D1H-U Pro. any answer will be very appriciated
Post your Makemkv info.
AngryVirginian
Post by AngryVirginian »
1. Your drive needs to be flashed with appropriate Libre Drive firmware to enable UHD disc ripping.
2. UHD discs are encrypted from factory. The Queen disc will be rippable with MakeMkv once the decryption key is created by MakeMkv. You can aid the process by sending the disc dump file to svq@makemkv.com once you get the disc. The dump file is required by MakeMkv to create the decryption key.
EventDriven
Post by EventDriven »
I have a version of this drive that works for ripping 4K BD using MakeMKV and I've never updated the firmware.
OS device name: \Device\CdRom3
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: A201
Serial number: SIK9EH4RG495
Firmware date: 2116-01-14 13:58
Bus encryption flags: 1F
Highest AACS version: 81
Firmware version: 0.A201W
szymixsiorek
Coopervid wrote: Sat Mar 16, 2024 10:27 pm
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: A205
Serial number: KLDM6DB2544
Firmware date: 2120-12-01 18:18
Highest AACS version: 63
szymixsiorek
i flashed my ASUS BW-16D1H-U Pro with DE_LG_BU40N_1.03_MK.bin and now its not working, anyone can help ?
How stupid! You should have waited for advice. Maybe the recover option helps but it's complicated and you nedd to follow exactly the steps.
Try this and follow the video with recovery:
viewtopic.php?f=16&t=22896&hilit=SDFToolFlasher
Pick the firmware that you flashed.
Then pick any ASUS / LG firmware for 5,25" drives. WH16NS60 1.02 is recommended.
You got a penalty for NOT READING. DON'T EVER DO THAT AGAIN.
szymixsiorek
but there is no bin file for ASUS BW-16D1H-U Pro i tried recorvery with everybbin file and it didnt worked
szymixsiorek
anyone could recommend any bluray 4k drive available on polish amazon that could be flashed correctly with any bin file from All You Need Firmware Pack (MartyMcNuts)?
szymixsiorek
could be Archgon Premium Aluminum External USB 3.0 UHD 4K Blu-Ray Writer Super Drive for PC and Mac ?
https://amzn.to/3PUwa0c
