MakeMKV Not Working
Tyler94
MakeMKV Not Working
Post by Tyler94 »
Used MakeMKV several times a couple months ago for some Blu-rays. Trying to digitize some more and now MakeMKV isn't working. I'll launch the program and when the disc is read I'll click on the drive icon to open the disc and make an MKV file. Only issue is once it starts spinning up it stops and give me this message. "Evaluation period has expired. Please purchase an activation key if you've found this application useful. You may still use all free functionality without any restrictions." This is a fresh install of MakeMKV and I've reinstalled it several times. I've uninstalled it normally on windows 10 from the application settings and used Revo uninstaller, same issue. It's the same computer, same drive and firmware as before. Even the drive and firmware that this forum recommends. I think MakeMKV is bugged. If you got anything that might help, that would be much appreciated, thanks.
Product: BD-RE WH16NS60
Revision: 1.02
Serial number: KLNN7I81322
Highest AACS version: 14
Firmware version: 1.02
Disc Information
Label: GREEN_MILE_THE
Timestamp: 2009-09-04 05:38:51
Protection: AACS v14
Data capacity: 40.10 Gb
Disc type: BD-ROM
Number of layers: 2
The bottom log give me this info.
MakeMKV v1.17.6 win(x64-release) started
Downloading latest SDF to C:\Users\Tyler/.MakeMKV ...
Using LibreDrive mode (v06.3 id=7FA2657C7667)
Evaluation period has expired, shareware functionality unavailable.
Re: MakeMKV Not Working
Are you trying to use the key that is "built in" to the file you downloaded, or the one posted in the forum each time it changes? It DOES change every 60 days, which is why it's posted.
