Aquaman And The Lost Kingdom
Dump Submitted: MKB20_v77_Aquaman_and_the_Lost_Kingdom_D14A
Not available in Keyed.cfg yet.
Re: Aquaman And The Lost Kingdom
I'm in the same boat. Cannot decrypt the disc.
Loaded in keydb.cfg now.
Just ran into the same issue.
Accidentally tried to post a thread and submitted the dump file for this same one because I didn't see it here originally. It still won't load for me. D14A.tgz
Dump Submitted: MKB20_v77_Aquaman_and_the_Lost_Kingdom_4AAA
dump submitted as well
Submitted again last night (before seeing this thread), but am able to rip it this morning so seems like it's been added.
MKB20_v77_Aquaman_and_the_Lost_Kingdom_ACD2 submitted (Nordics)
EDIT: Now works.
EDIT: Now works.
Can confirm that I was finally able to rip my copy today.
Not sure if the different codes at the end of the dump matter but mine was MKB20_v77_Aquaman_and_the_Lost_Kingdom_D14A.
They do indeed matter. If the codes at the end are the same, then the same hashed key is needed. If the codes are different, then different hashed keys are needed. This is why it is helpful to post the name of the dump file you submitted. That way others can know if their dump file has been submitted or not.Mango Mochi wrote: ↑Fri Mar 15, 2024 10:06 pmCan confirm that I was finally able to rip my copy today.
Dump file: MKB20_v77_AQUAMAN_AND_THE_LOST_KINGDOM_8E8C submitted for the Aussie 4K Steelbook.
I am not able to rip my Walmart steelbook copy. Same dump name as yours. I get the "The volume key is unknown for this disc -video can't be decrypted" error. Then it shows as "No disc"
Got the latest HK download today and and now ripping this!MartyMcNuts wrote: ↑Wed Mar 27, 2024 1:36 amDump file: MKB20_v77_AQUAMAN_AND_THE_LOST_KINGDOM_8E8C submitted for the Aussie 4K Steelbook.
Nevermind. ISP was blocking the HK server. Had to use a ProtonVPN free to get around it. Ripping fine now.pierceal wrote: ↑Sat Mar 30, 2024 3:30 pmMango Mochi wrote: ↑Fri Mar 15, 2024 10:06 pmCan confirm that I was finally able to rip my copy today.
