Dump file submitted
MKB20_v77_THE_CREATOR_96AE
The Creator UK
Re: The Creator UK
Wow, that was quick.
I’m ripping it now, fingers crossed.
Re: The Creator UK
Ditto
Re: The Creator UK
I don't understand your comment. The OP indicated a hashed key was available and the disc was decrypting. If you have the same hashed key as the OP (if your dump file is the exact same name), then a key should be available.
Re: The Creator UK
I send the Dump from The Creator
