Weird color separation
dangertim
Post by dangertim »
(I'm not very tech savvy, so I apologize in advance for inadequate terminology. Could use help though.)
I've been happily using this software for years without problem. Unfortunately within the last year or so, I've noticed some files have a weird color separation. Everything green has shifted upward, out of alignment with the rest of the frame. Has anyone else experienced this (and fixed it)?
It only seems to happen with some color widescreen Blu-ray files. DVDs or programs in 4:3 aspect ratio seem to still rip fine.
Re: Weird color separation
Does it happen with if you use a different player?
dangertim
Post by dangertim »
It isn't happening when those discs are played on any of my set-top players. Unfortunately, I don't have another Blu-ray drive to test.
mike8675309
Post by mike8675309 »
Can you play it in VLC right on the computer and see the problem?
dangertim
Post by dangertim »
UPDATE: it wasn't a problem with MakeMKV or my drive. It was an issue with VLC Player. I had to change an output setting to correct the problem.
Thanks for everyone's help!
BohdisDad
Post by BohdisDad »
I have found this error occurs on rips of discs that utilize the older VC-1 or MPEG2 codecs only. The newer codecs (MPEG4) are not affected. These codecs were used on legacy (older) titles primarily from Warner Bros. and Universal and a few others. I have previously ripped discs using older versions of MKV with these codecs with no issues, but the latest versions of MKV, at least since version 1.15 (2020), seem to have this issue. It appears that the green color palette is shifted upward and not aligned with the rest of the colors (there is a green stripe visible in the top black border).
tisble
Post by tisble »
I'm having the same issue. Green color bar at the top of movie. Season 3 of the Big Bang Theory and now The Green Mile.
So what is the work around for this issue?
tisble wrote: Sun May 26, 2024 1:59 am So what is the work around for this issue?
I take it that the answers posted above had no effect on your issue? Or did you not try them before posting?
tisble
Post by tisble »
I rolled back MKV to 1.14.7
Same Issue. I'm trying an older version today. As for the VLC out put setting, the post wasn't specific what or where the change is made.
tisble
Post by tisble »
Found that setting in VLC to correct that issue
GnomeFondler
Post by GnomeFondler »
Nobody had better post the setting in VLC that needs to be changed to fix this and make the thread USEFUL or anything, just keep treating it like a state secret and saying YOU found it. Lord.
