Application failed to initialize
So, what am I doing wrong. I've uninstalled, restarted, reinstalled. Still same thing. Vista OS. Plenty of HDD space, RAM. Any help? Please?
Re: Application failed to initialize
1) what version are you running?
2) does taskmgr (alt-ctrl-del) show anything started?
Newest version. Just downloaded. Didn't look in task manager.
Getting the same problem. Happened after installing the latest version. Has worked perfectly fine up until now.
- Contact:
Are you talking about 1.6.12 or 1.6.13 ?
Me2. On MacBook Air i7 Lion failed, on MacBook Pro Snow Leopard works. Both 1.6.13
- Contact:
Please try the following:
1. Reboot computer
2. Reinstall latest MakeMKV
Launch MakeMKV and see if it fails again.
1. Reboot computer
It falis again. The previous version works fine before I installed 1.6.13. If i use AppCleaner to remove the latest version, empty trash and reinstall a previous version, I get the same error.
- Crash Report.txt
- (13.56 KiB) Downloaded 350 times
Same thing with me, wanted to buy eventually but now have to reconsider!
Tried everything but everytime my system hangs when starting makemkv...if i uninstall en delete all registery entries, then my system works like a charm!
MUST be makemkv 1.6.13...
Good thing i encounter these problems now while in beta, now i have to reconsider if makemkv is such a good product after all. I spent some days trying to make it work...It is a nice product when it works, but now wasted 3 days trying to make it work...![Crying or Very sad :cry:](./images/smilies/icon_cry.gif)
- Contact:
Sorry about that. Normally MakeMKV works better than that. If you can, please do this as other poster did - http://www.makemkv.com/onlinehelp/dump.htmltourmaline wrote:Same thing with me, wanted to buy eventually but now have to reconsider!
Same here.
Windows 7 x64
MakeMKV v1.6.13
Windows 7 x64
MakeMKV v1.6.13
I am having the same issues since the upgrade. Previous version worked perfectly. Now i can get the application to load, but when i click on open, it hangs. Sometimes i can cntrl alt delete and the open file screen will pop up, but then when i click a file to open it hangs again. i was able to get it to run a few times, but for the most part it has been extremely slow and randomly hangs.
- Contact:
Thanks for the report, this is a bug in 1.6.13 and will be corrected soon. Please see the next message about application data directory for possible workaround.Sluft wrote:It falis again. The previous version works fine before I installed 1.6.13. If i use AppCleaner to remove the latest version, empty trash and reinstall a previous version, I get the same error.
- Contact:
Please launch MakeMKV, go to preferences, (last) "General" tab. What is the value of "application data directory" and can you change it?Mortikai wrote:I am having the same issues since the upgrade. Previous version worked perfectly. Now i can get the application to load, but when i click on open, it hangs. Sometimes i can cntrl alt delete and the open file screen will pop up, but then when i click a file to open it hangs again. i was able to get it to run a few times, but for the most part it has been extremely slow and randomly hangs.
