Failure - 'A Night At The Roxbury'
Yokozuna
#1 Post by Yokozuna » Thu Jun 09, 2011 12:25 pm
Rip fails.
MakeMKV v1.6.10 win(x86-release) started
Debug logging enabled, log will be saved as C:\Users\admin/MakeMKV_log.txt
Cells 2-end were skipped due to cell commands (structure protection?)
Title #1 was added (1 cell(s), 0:02:18)
Title #2 was added (20 cell(s), 1:18:24)
Saving 1 titles into directory C:/Users/admin/Downloads
DEBUG: Code 186 at 0&8#ut~+\f[<#QlS9!*!~G:213129823
DEBUG: Code 128 at m:&8?QMLXwacca:6'O7pb:121264786
DEBUG: Code 2025 at m:&8?QMLXwacca:6'O7pb:121264786
DEBUG: Code 623 at m:&8?QMLXwacca:6'O7pb:121264786
DEBUG: Code 49 at neBG8dAFG6$j#7"dIIR:29398254
DEBUG: Code 149 at neBG8dAFG6$j#7"dIIR:213134699
DEBUG: Code 6 at neBG8dAFG6$j#7"dIIR:213134722
DEBUG: Code 0 at m:&8?QMLXwacca:6'O7pb:29397472
Failed to save title 1 to file C:/Users/admin/Downloads/title01.mkv
0 titles saved, 1 failed
Re: Problem with A Night At The Roxbury
#2 Post by mike admin » Fri Jun 10, 2011 2:19 pm
Please submit the full log ( C:\Users\admin/MakeMKV_log.txt ) and all IFO files per instructions at http://www.makemkv.com/faq/item/8/catid/6
Yokozuna
#3 Post by Yokozuna » Mon Jul 18, 2011 10:27 am
Mike,
Here is a dump of the error with this DVD - A Night At The Roxbury.
Yokozuna
#4 Post by Yokozuna » Tue Aug 09, 2011 8:48 am
Still does not work with current build.
Yokozuna
Re: Failure - 'A Night At The Roxbury'
#5 Post by Yokozuna » Fri Sep 02, 2011 1:11 pm
Hi Mike,
DVD rip still fails with latest build.
Please find attached log file.
MakeMKV_log.zip
(604.63 KiB) Downloaded 510 times
setarip_old
#6 Post by setarip_old » Fri Sep 02, 2011 7:11 pm
@Yokozuna
Hi! (Same question as "Hunt for Red October")
Is your source material an original, commercial DVD?
Yokozuna
#7 Post by Yokozuna » Thu Aug 02, 2012 2:25 pm
Mike,
When are you planning to address this? I have taken the effort to produce the dump files for you however there appears to be no action by your part to resolve?
setarip_old
#8 Post by setarip_old » Thu Aug 02, 2012 4:49 pm
(Same question as your post regarding "Hunt for Red October")
Since you are continuing to pursue this a year after your initial post, I'd again ask you:
#9 Post by mike admin » Fri Aug 17, 2012 12:17 pm
Yokozuna wrote:Mike,
This bug (code 2025) was fixed a really long time ago. Are you getting the same error on 1.7.7 ?
