poppo
I have just received a new LG BD rewriter WH14NS40 (firmware 1.05; manufacture date: 2023).
Running MakeMKV 1.17.6 on Windows 10 x64, the drive information is as follows:
drive information:
manufactturer: HL-DT-ST
Product: BD-RE WH14NS40
revision: 1.05
serial number: XXXXXXXXXXX
firmware date: 2120-05-06 14:44
bus encryption flags: 17
LibreDrive information:
Status: possible (with patched firmware)
hardware support: yes
firmware support: no
firmware type: Original (patrched version available)
firmware version: 1.05
DVD all regions: possible (with patched firmware)
BD raw data read: possible (with patched firmware)
BD raw metadata read: possible (with patched firmware)
unrestricted read speed: possible (with patched firmware)
No info on "Highest AACS version".
What would be the best firmware version to flash this drive so that I can play and rip UHD disc via MakeMKV?
Should it be:
1) HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin (The all you need firmware pack)
from: https://drive.google.com/file/d/1HRnbXi ... sp=sharing
or
2) DE_LG_WH14NS40-NS50_1.02.bin (All You Need Firmware Pack (MartyMcNuts))
from: https://www.mediafire.com/file/ph1ap2eg ... 9.zip/file
or
3)HL-DT-ST-BD-RE_WH14NS40-NS50-1.05-NM00900-212005061444.bin (MK firmware)
from:https://www.makemkv.com/download/mk-fir ... 200720.zip
or some other versions?
Where is the version of WH16NS60 1.02MK
Thanks.
drive information:
revision: 1.05
Should it be:
or
or
Thanks.
poppo
I have a LG WH14NS40 (Firmware 1.05, Manufactured in 2023).
For WH14NS40, the recommended Firmware to flash is suggested to be "WH16NS60 1.02MK". But where is "WH16NS60 1.02MK"? I can't locate it.
Thanks for any help.
In the appropriately named "The all you need firmware pack"poppo wrote: Tue Mar 12, 2024 11:05 pm I have a LG WH14NS40 (Firmware 1.05, Manufactured in 2023).
poppo
You mean:
right?
After firmware flashing, the drive will become WH16NS60?
Thanks.
right?
Thanks.
yespoppo wrote: Tue Mar 12, 2024 11:52 pm You mean:
right?
Thanks.
poppo
I have a new LG (firmware 1.05; Made in 2023). Running MakeMKV 1.17.6 on Windows 10 x64, the drive information is as follows:
drive information:
revision: 1.05
A line with "Highest AACS version" is missing, which seems different from any other BD writers that I have seen. Will this be an issue?
Thanks.
drive information:
revision: 1.05
Thanks.
"Highest AACS version" reports what THAT drive has processed. Have you ripped any discs yet?poppo wrote: Wed Mar 13, 2024 2:07 am I have a new LG (firmware 1.05; Made in 2023). Running MakeMKV 1.17.6 on Windows 10 x64, the drive information is as follows:
drive information:
revision: 1.05
Thanks.
tryingtolearn
Just Got My BRUHD-PU3-BK Up and operational and Ripping its First 4k Movie. I just want to say those of you who figured this out. Well done
kiranmehta
Hi,waitin_outside wrote: Thu Mar 07, 2024 9:29 pmI have all 3 of them. My recommendation - go with the Asus.kiranmehta wrote: Tue Feb 27, 2024 2:35 pm Hi I am from India, I have been reading a lot of this forum and gotten very interested in ripping blurays but there are not a lot of options available here in India and those which are available are almost double the price if not more.
Initially I was interested in the latest pioneer drives (BDR xd08-umb-s) but due to firmware support for makemkv unavailable stopped pursuing it. I currently have shortlisted following options for me here in India -
lg wh14ns40 (rupees 11492 i.e USD - )
lg wh16ns40 (rupees 11492 i.e USD - )
ASUS BW-16D1HT (rupees 11492 i.e USD - )
I am leaning towards Asus as i have heard that it handles large disks well without read errors. Also Lg drive i am not sure of the svc version as the seller on amazon is not able to provide this info.
Any recommendations apart from the above are welcome
I bought the asus drive and it displays below information -
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.11
Serial number: ***
Firmware date: 2120-12-01 17:59
Bus encryption flags: 1F
Should I flash it or not as it says possible not yet enabled....
If you want to enable LibreDrive and/or rip UHD discs, then yes, it must be flashed.kiranmehta wrote: Wed Mar 13, 2024 7:19 amHi,waitin_outside wrote: Thu Mar 07, 2024 9:29 pmI have all 3 of them. My recommendation - go with the Asus.kiranmehta wrote: Tue Feb 27, 2024 2:35 pm Hi I am from India, I have been reading a lot of this forum and gotten very interested in ripping blurays but there are not a lot of options available here in India and those which are available are almost double the price if not more.
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.11
Serial number: KLLNBJB5228
kiranmehta
MartyMcNuts wrote: Wed Mar 13, 2024 7:35 amIf you want to enable LibreDrive and/or rip UHD discs, then yes, it must be flashed.kiranmehta wrote: Wed Mar 13, 2024 7:19 amHi,waitin_outside wrote: Thu Mar 07, 2024 9:29 pm
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.11
Serial number: ***
Can you please point to the exact steps, I am searching the forum but not getting anyone who has mentioned the steps with firmware 3.11
Ps. Yes I want to make it uhd friendly.
Go to the SDFtool Flasher thread and follow the first post.kiranmehta wrote: Wed Mar 13, 2024 8:02 amMartyMcNuts wrote: Wed Mar 13, 2024 7:35 amIf you want to enable LibreDrive and/or rip UHD discs, then yes, it must be flashed.kiranmehta wrote: Wed Mar 13, 2024 7:19 am
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.11
If you don't care about writing discs, flash it directly to WH16NS60 1.02-MK firmware. If you do plan on writing discs occasionally, flash it directly to BW-16D1HT 3.10-MK firmware.
kiranmehta
Thank you for quick reply and resolution.MartyMcNuts wrote: Wed Mar 13, 2024 9:04 amGo to the SDFtool Flasher thread and follow the first post.kiranmehta wrote: Wed Mar 13, 2024 8:02 amMartyMcNuts wrote: Wed Mar 13, 2024 7:35 am
My drive arrived today and I'll be getting my first 4k uhd disc in 2-3 days will flash it then and will keep updated
Thank you!
kiranmehta
Hi i got my joker 4k bluray and uhd disc today and was able to rip it ootb without flashing, however when flashing to make it uhd friendly i am getting below errorMartyMcNuts wrote: Wed Mar 13, 2024 9:04 amGo to the SDFtool Flasher thread and follow the first post.kiranmehta wrote: Wed Mar 13, 2024 8:02 amMartyMcNuts wrote: Wed Mar 13, 2024 7:35 am
"Command produced error code0x82000000"
PS : My drive enclosure is USB 2.0 only currently
Most likely the chipset of that enclosure doesn't support flashing. You will need to attach it to SATA or buy this USB-> SATA adapter.
https://www.amazon.com/BENFEI-Drive-Ada ... r=8-3&th=1
