Can I rip a UHD with a regular bluray drive?
Checkerknight
#1 Post by Checkerknight » Tue Mar 12, 2024 8:55 am
I just bought a new blu ray drive to use a backup because I have been getting quite a few fails lately and I notice that it does have LibreDrive enabled.
The drive is a Pioneer BDR-212D Firmware version 1.02/ID61 (2022-03-16)
I know that this drive is just a standard bluray, and not made for reading 4ks, and I know that Libre isn't an indication of 4k compatability but I was curious if the drive can be changed to be able to read UHD's or if that is something that is beyond a flash. I read through a few threads and I guess I might just need it spelled out for me a bit simpler..Not necessarily asking for the process, moreso just if it is a possibility. If not I may return it to get a 4k drive, but ripping 4ks is not really a necessity at the moment. The speed of this drive is a significant upgrade on its own. Thank you!
Re: Can I rip a UHD with a regular bluray drive?
#2 Post by Coopervid » Tue Mar 12, 2024 10:16 am
Check PM
Checkerknight
#3 Post by Checkerknight » Wed Mar 13, 2024 9:08 am
Thank you so much. Works great now. Pm'd you back but don't know if it worked haha. Reading my discs perfectly!
