FLYBOYS Widescreen DVD - no movie, only trailers
5tephenDD
Post by 5tephenDD »
I loaded FLYBOYS Widescreen DVD (SKU 027616062123) into MakeMKV and I see this in the log:
Using LibreDrive mode (v06.3 id=B540B206A99E)
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-RE ASUS BW-12B1ST a 1.00 K95E9NB3635' at offset '4107194368'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-RE ASUS BW-12B1ST a 1.00 K95E9NB3635' at offset '4060377088'
Cells 47-47 were removed from title end
Title #1 (2:18:33) was skipped due to navigation error
Title #2 has length of 114 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Cells 2-2 were removed from title end
Title #3 was added (1 cell(s), 0:02:28)
Title #4 was added (1 cell(s), 0:02:25)
Fake cells occupy 47% of the title - assuming fake title
Title #6 was added (1 cell(s), 0:02:18)
Title #7 has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #8 has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #10 has length of 13 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #11 was added (1 cell(s), 0:02:07)
The source file '/VIDEO_TS/VTS_05_1.VOB' is corrupt or invalid at offset 28672, attempting to work around
After reading the disc, the upper panel only lists 4 trailer tracks - not the main movie.
Any suggestions on how to locate the actual movie on the disc?
Re: FLYBOYS Widescreen DVD - no movie, only trailers
Errors like this:
indicate that the drive was unable to correctly read the disc. Gently cleaning the disc is the standard advice.
This error:
is likely the one that is why the main movie wasn't ripped. It might be because of the earlier errors and cleaning the disc might clear it up. Or trying the different DVD opening modes might help.
5tephenDD
Post by 5tephenDD »
Thank you for responding. Sorry I'm late getting back to you... didn't get notified for some reason.
I tried cleaning the disk but makeMKV could still not suss it out. Added it to a growing heap of disks that I label "NO makeMKV" :(
