Seeking Recommendations for the Best Pioneer LibreDrive in 2024
Re: Seeking Recommendations for the Best Pioneer LibreDrive in 2024
Pioneer drives in general use better quality components than the competition and are superior readers and writers.shali wrote: Sun Mar 10, 2024 3:08 pm Hi!
In the next few years I like to transfer my disc-collection (3000+ CDs and 500+ DVDs and BDs and 3D-BDs and 4k-BDs) to HDD and I am looking for the best drive in the Pioneer range to do it.
No need of officialy supported UHD because I don't have an Intel SGX capable Computer. Will use MakeMKV for transfer to HDD and maybe VLC for playback
Europe-based
I have read some comments about slim drives to be shacking and ratteling on the table because of the low weight and I am curious about errors may occur because of that.
An 5.25 external drive, 5.25 internal drive with case or a very robust slim drive are possible.
Don't like Slot-In, will prefer Tray or Top-loader.
Will use it on different PCs and Laptops, most of them offline on Windows 7.
I have read about the noise and vibration reducing coating of the BDR-S13E-X and I am concerned about the longelivity of this coating because EVERY rubberized surface on my devices (IBM and Lenovo Thinkpads, USB-Sticks, Blackberry Smartphone) became sticky after a couple of years and such a coating on the internal tray is a No-Go for me.
I am confused about the nomenclature of Pioneer because the picture of the external BDR-X13E-S is similar to the internal BDR-S13EBK and the same for BDR-X13EBK and BDR-213EBK, so there seems to be no official external choice of BDR-S13E-X.
Because I don't like to use the drive only for ripping it needs to have M-Disc and BDXL support.
For audio transfer with EAC has a Pioneer drive any kind of advantages (audio check function of BDR-S13E-X, PureRead 3 or4, ???) or can I use every other (older) drive and only need to calibrate the offsets with the reference CDs.
So far:
BDR-S13E-X with Vantec NexStar DX2 questionnable because of coating
BDR-X13E-S =?= BDR-S13EBK with Vantec NexStar DX2 possible, better quality
BDR-X13EBK =?= BDR-213EBK with Vantec NexStar DX2 possible, lower quality
BDR-XS07TUHD/TS No-Go because of Slot-in
BDR-XD08EMB-S No-Go because of coating
BDR-XD08TB/TS/TG questionnable because of no official Windows 7 support and maybe stability problems
BDR-XD07TUHD/TB/TS possible but maybe stabibilty problems
Any additional ideas or recommendations?
Feel free to answer her or send me a PM. But because I am new I am not able to send or answer to PMs and I am not able to send Mails to any gmail-account.
Best Regards
For CD's, PureRead 3 is good but the new PureRead 4 is best.
philishere
I wanted to get my hands on a nice external Pioneer drive aswell. Prioritizing longlivety and speed, portability is not important, so 5.25" is fine.
Was eyeing the BDR-X13EBK. Not sure if the firmware can be downgraded or if it's already scrambled.
Wanted to PM Coopervid but I guess my account is too new.
You need to tell me your country of residence.philishere wrote: Sun Jun 30, 2024 7:03 am Hello,
philishere
Germany.Coopervid wrote: Sun Jun 30, 2024 11:17 amYou need to tell me your country of residence.philishere wrote: Sun Jun 30, 2024 7:03 am Hello,
Read your PM.philishere wrote: Sun Jun 30, 2024 2:10 pmGermany.Coopervid wrote: Sun Jun 30, 2024 11:17 amYou need to tell me your country of residence.philishere wrote: Sun Jun 30, 2024 7:03 am Hello,
philishere
Just read your PM, unfortunately, I am not allowed to answer it.
Thanks for the recommendations - it seems like the only viable option for me is the internal drive. The external ones are too slow for my needs.
Unfortunately, that means that I will also have to find some kind of USB/SATA interface.
It's really a shame - it seems like there is no UHD-enabled high-quality external drive at the moment.
There is. Buy from asmcom.philishere wrote: Sun Jun 30, 2024 9:38 pm Just read your PM, unfortunately, I am not allowed to answer it.
