#9751 Post by RESET_9999 » Sun Mar 10, 2024 3:28 pm
21.0.3beta
was via webos dev manager?
yes, im connected to an AVR too via ARC
LV8HD
#9752 Post by LV8HD » Sun Mar 10, 2024 3:38 pm
What are those L6 values? (The movie in question is Cars 3):
Summary:
  Frames: 147321
  Profile: 8
  DM version: 1 (CM v2.9)
  Scene/shot count: 1630
  RPU mastering display: 0.0020/1000 nits
  RPU content light level (L1): MaxCLL: 10000.00 nits, MaxFALL: 892.53 nits
  L6 metadata
    Mastering display: 0.0020/1000 nits. MaxCLL: 1000 nits, MaxFALL: 1000 nits
    Mastering display: 0.0020/1000 nits. MaxCLL: 1000 nits, MaxFALL: 372 nits
    Mastering display: 0.0020/1000 nits. MaxCLL: 1000 nits, MaxFALL: 347 nits
    Mastering display: 0.0020/1000 nits. MaxCLL: 1000 nits, MaxFALL: 471 nits
    Mastering display: 0.0020/1000 nits. MaxCLL: 1000 nits, MaxFALL: 592 nits
    Mastering display: 0.0020/1000 nits. MaxCLL: 1000 nits, MaxFALL: 532 nits
    Mastering display: 0.0020/1000 nits. MaxCLL: 1000 nits, MaxFALL: 835 nits
    Mastering display: 0.0020/1000 nits. MaxCLL: 1000 nits, MaxFALL: 767 nits
    Mastering display: 0.0020/1000 nits. MaxCLL: 1000 nits, MaxFALL: 179 nits
    Mastering display: 0.0020/1000 nits. MaxCLL: 709 nits, MaxFALL: 121 nits
    Mastering display: 0.0020/1000 nits. MaxCLL: 1000 nits, MaxFALL: 598 nits
    Mastering display: 0.0020/1000 nits. MaxCLL: 1000 nits, MaxFALL: 561 nits
    Mastering display: 0.0020/1000 nits. MaxCLL: 1000 nits, MaxFALL: 606 nits
    Mastering display: 0.0020/1000 nits. MaxCLL: 1000 nits, MaxFALL: 467 nits
    Mastering display: 0.0020/1000 nits. MaxCLL: 1000 nits, MaxFALL: 983 nits
    Mastering display: 0.0020/1000 nits. MaxCLL: 1000 nits, MaxFALL: 400 nits
  L2 trims: 1000 nits, 100 nits, 600 nits
  L5: Left=0, Right=0, Top=276, Bottom=276
gm23o
#9753 Post by gm23o » Sun Mar 10, 2024 5:20 pm
I'm experiencing raised blacks in DV with some movies.
I'm using an Oppo clone connected to a Nexigo Aurora Pro UST projector.
Full Disc Rip - BDMV
I've noticed this recently when watching :
- Mission Impossible : Dead Reckoning
- True Romance
The letterbox bars and opening credits etc are very raised to a medium grey.
When I switch from TV led to Player led it improves.
Any ideas?
scaramanga
#9754 Post by scaramanga » Tue Mar 12, 2024 3:52 pm
Apologies to Reset - I know you mentioned to use Doom forum but it's a 5 day wait after registration so trying in here first.
I've got a setup of Shield 2019 through to LG TV utilising a Plex server and it can happily play native DV rips (Dune) and standard UHD rips (Sicario) from MKV
no issue.
When I have ran Sicario through the script (3-1) the film does trigger DV on the TV but there are blocky aspects when it comes to dark colours on light background and a few frames that are obviously awry.
Just wondered if I am doing something wrong in prepping the scripts, or do I need to invest in a Nvidia GFX card or a SSD to carry out the conversion work?
gm23o
#9755 Post by gm23o » Wed Mar 13, 2024 9:20 am
- True Romance
Any ideas?
Any thoughts on this guys? RESET_9999?
jayper
#9756 Post by jayper » Wed Mar 13, 2024 2:26 pm
- True Romance
Any ideas?
RESET_9999 wrote:
Tue Feb 13, 2024 1:43 pm
please ask any further questions related to the dovi_scripts here: https://forum.doom9.org/showthread.php? ... ost1997616
thanks.
scaramanga
#9757 Post by scaramanga » Wed Mar 13, 2024 9:45 pm
You have to wait 5 days after registering for Doom Forum so in my case I took a punt on here whilst waiting to post in there.
croweyes1121
#9758 Post by croweyes1121 » Wed Mar 20, 2024 1:37 pm
PlatypusW wrote:
Sat Dec 05, 2020 7:17 pm
RESET_9999 wrote:
Sat Dec 05, 2020 4:09 pm
TickTock wrote:
Sat Dec 05, 2020 1:18 pm
Last night I watched The Lord of the Rings The Fellowship of the Ring and I was able to fast forward. I used the latest version of tsMuxer and muxed both parts to individual m2ts files.
I merged mine in a single TS file.
So if FF works for each individual part, that pretty much confirms the issue is related to the length of the movie.
thank you
Yes but that isn't enough for me :P
I still haven't got myself a x700 yet, but I dug out my old x800. It can't do dolby vision, but I had some time today and figured it should be close enough to see whats going on (they should be very similar internal players if not the same).
Started with the second hobbit film. The raw m2ts and the tsmuxer file both wouldn't seek. 'Operation not permitted'.
Tried cutting the file with tsmuxer to 2 hours and 45 minutes. Seek worked.
Then I went for 2 hours 50 minutes. Seek didn't work.
Something in tsmuxer caught my eye: "--cut-end=10200000ms"
To me that seemed like such a specific round number. I have now tested both hobbit 1 and 2...
If the file is 2 hours, 46 minutes and 39 seconds or shorter. The file will allow seeking.
If the file is 2 hours, 46 minutes and 40 seconds or longer. The file will not allow seeking.
Turns out in milliseconds that is:
9999000ms: Seeks
10000000ms: Does not seek
From all this, I believe that if the file is greater than (or equal to) 10 million millisconds then seeking will not work. Anything below seems to work fine.
Does this align with what you have experienced on the x700? Know any titles that might be under this 10 million ms 'limit' that don't allow seeking?
Note: For me, on the latest tsmuxer nightly, the resulting file was always 1 second less than what I put into the 'end'. So if anyone tries this, take this into account if you are trying to be precise.
Why there might be such a limit I'm not sure - maybe someone else might know that :?:
Never seen something related to length in ms, at least 10 million...doesn't really strike me as a number that would normally cause issues in the computing world :?
Has anyone ever figured out a workaround for this issue that doesn't involve splitting the file (which I really would prefer not to have to do)? Surely there's some way to change a setting in tsmuxer that allows the file to be seekable...
#9759 Post by RESET_9999 » Wed Mar 20, 2024 2:08 pm
I dont think there's anything you can do about it except using BDMV folder and It looks like a bug with the oppo and x700 with TS DV rip because the x800m2 doesnt have this problem.
#9760 Post by RESET_9999 » Wed Mar 20, 2024 2:10 pm
- True Romance
Any ideas?
full disc rip?? are you sure because it sounds like your video is cropped which would produce a raised letterbox...
jayper
#9761 Post by jayper » Wed Mar 20, 2024 2:48 pm
thank you
9999000ms: Seeks
If you have an x700 or x800m2, and you're trying to play back a Profile 7 file (ie a UHD with DV), use tsmuxer to create a BDMV folder output. Place the BDMV folder in the root of a USB drive.
To my knowledge, there is no workaround for the seeking issue with TS files. I believe that is a device limitation.
croweyes1121
#9762 Post by croweyes1121 » Wed Mar 20, 2024 3:16 pm
Oh, if that works, then I'm a happy camper. I'm happy to do it this way, I just want to be able to watch a 3-hr movie without stopping it. I just assumed it still would not be seekable even if I put it on the drive that way. Trying it now! :)
croweyes1121
#9763 Post by croweyes1121 » Wed Mar 20, 2024 3:39 pm
This is not working for me.
The standalone m2ts file plays fine (albeit without the ability to seek). When I export to a BDMV folder, the X700 sees it as an AVCHD video file (as I understand it should), but it won't play. In fact, attempting to play it just locks up the player to the point that I have to unplug it. I've tried running the original m2ts file through tsmuxer to a BDMV folder and putting it back on the USB drive multiple times, same result every time. Any suggestions?
#9764 Post by RESET_9999 » Wed Mar 20, 2024 7:07 pm
i dont know, it worked the last time I tried a long time ago and I don't have to bother with this anymore with the x800m2.
Maybe something changed in tsmuxer?
Hellboy.
#9765 Post by Hellboy. » Wed Mar 20, 2024 8:06 pm
If you no longer use the x800m2, what do you use for DV?
