Pioneer BD-RW BDR-XD07 - Troubleshooting 4kUHD discs not reading
daryth84
#1 Post by daryth84 » Fri Jan 12, 2024 3:39 pm
I was not aware until beginning this attempt at ripping for a home server that there was a difference in 4k UHD and just plane Bluray discs, it appears my drive is MakeMKV LibreDrive Ready ("Enabled") but it does not seem capable of detecting any 4k UHD disc i put in it. It just spins a little, then spins again about 4x and seems to give up and says what you see in the attached image "No disc inserted"
Any advice on how to make this drive detect and rip 4KUHD?
Edit:
I guess the image isn't posting. here's the info from MakeMKV
Manufacturer: PIONEER
Product: BD-RW BDR-XD07
Revision: 1.03
Serial number: ADDL026530UC
Firmware date: 2020-08-20
Bus encryption flags: 13
Highest AACS version: 72
Drive platform: RS8D30
Firmware version: 1.03
Re: Pioneer BD-RW BDR-XD07 - Troubleshooting 4kUHD discs not reading
#2 Post by Coopervid » Fri Jan 12, 2024 4:43 pm
Check PM
daryth84
#3 Post by daryth84 » Fri Jan 12, 2024 5:58 pm
Hmm It seems i can't reply or message people back yet as I dont have enough participation to merit being a human yet and the original post seems to have vanished after i attempted to edit it so here goes again.
Drive isn't detecting the 4kUHD discs and here is the MakeMKV information:
"Drive Information
Revision: 1.03
No disc inserted"
#4 Post by Coopervid » Fri Jan 12, 2024 6:47 pm
Read PM.
daryth84
#5 Post by daryth84 » Sat Jan 13, 2024 12:36 am
Ty Coopervid :D
CyberELF
#6 Post by CyberELF » Sun Jan 28, 2024 7:10 am
Hello! I'm having the same issue. Could you please share if this has a fix or if I need to buy another model? Thanks in advance!1
Skorm
#7 Post by Skorm » Fri Mar 08, 2024 9:35 pm
Good evening,
i am facing the same issue with my bd drive that daryth84 had, its the same model and firmware. I was wondering what the solution was since flashing is not an option for pioneer drives yet, at least according to the flashing guide from 2023 that i found. I hope someone can help me resolve this problem.
Cheers, Skorm
#8 Post by Coopervid » Sat Mar 09, 2024 11:09 am
Please post your Makemkv info like daryth84 did.
Skorm
#9 Post by Skorm » Sat Mar 09, 2024 11:41 am
Hi there, i attached a screenshot from makemkv.
Skorm
#10 Post by Skorm » Sat Mar 09, 2024 4:58 pm
Hi again, seems like my post from earlier this morning isnt showing up for some reason. Maybe because of the linked image?
Anyway, this is what makemkv is showing under drive information.
OS device name: E:
Revision: 1.03
Serial number: ALDL008257WL
Highest AACS version: 68
Best regards, Skorm
#11 Post by MartyMcNuts » Sun Mar 10, 2024 2:03 am
OS device name: E:
Revision: 1.03
Best regards, Skorm
It can't read UHD discs as it is not a UHD drive.
Skorm
#12 Post by Skorm » Sun Mar 10, 2024 7:20 am
Good morning,
Out of the box it shouldn’t be, that much I know. But there has to be a way to flash the XD07 an other pioneer drives, because its getting advertised and sold as such here in this forum.
For example, here the XD07TS (the one I have) is getting advertised as “cross flashed” to a XD07TUHD.
Link: viewtopic.php?f=20&t=19387
#13 Post by MartyMcNuts » Sun Mar 10, 2024 9:01 am
Good morning,
Yes but there has not been any publicly released flasher tool for them.
#14 Post by Coopervid » Sun Mar 10, 2024 10:24 am
Good morning,
Read PM.
Skorm
#15 Post by Skorm » Sun Mar 10, 2024 11:14 am
Thank you Coopervid, it worked perfectly :D
