Hi, I am planning to rip my UHD collection with DVDFab and will buy the WH16NS40 on Amazon, I assume it is FW 1.05 and SVC:NS50
I reference many posts here but would like to confirm again my step is right and safe, thanks.
1. Use the SDFtool Flasher (v1.3.5)
2. Flash the "HL-DT-ST-BD-RE_WH16NS40-NS50-1.05-NM00900-212005061440" with enable encryption to the drive, it image located at "mk-firmware-pack-20200720" folder.
3. Flash again the drive use "DE_LG_WH16NS40_1.02_NS50"
Then it can work with DVDFab for rip UHD, right ?
WH16NS40 Firmware for rip UHD
Re: WH16NS40 Firmware for rip UHD
No. WH16NS60 firmware is recommended.marcobb0312 wrote: Fri Mar 08, 2024 7:04 pm Hi, I am planning to rip my UHD collection with DVDFab and will buy the WH16NS40 on Amazon, I assume it is FW 1.05 and SVC:NS50
Flash the drive directly to WH16NS60 1.02-MK from the "old" folder of the MK firmware pack then if you want to use DVDfab, fllash it again to DE_LG_WH16NS60_1.00
marcobb0312
@MartyMcNuts Thanks for your support !!!MartyMcNuts wrote: Sat Mar 09, 2024 2:56 amNo. WH16NS60 firmware is recommended.marcobb0312 wrote: Fri Mar 08, 2024 7:04 pm Hi, I am planning to rip my UHD collection with DVDFab and will buy the WH16NS40 on Amazon, I assume it is FW 1.05 and SVC:NS50
At my location, i found the ASUS BC-12D2HT has stock, How about it, which image should I flash if use DVDfab ?
marcobb0312
Is the correct file name as below ?MartyMcNuts wrote: Sat Mar 09, 2024 2:56 amNo. WH16NS60 firmware is recommended.marcobb0312 wrote: Fri Mar 08, 2024 7:04 pm Hi, I am planning to rip my UHD collection with DVDFab and will buy the WH16NS40 on Amazon, I assume it is FW 1.05 and SVC:NS50
1. HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936
2. DE_LG_WH16NS60_1.00
Yes, correct.marcobb0312 wrote: Sat Mar 09, 2024 7:09 amIs the correct file name as below ?MartyMcNuts wrote: Sat Mar 09, 2024 2:56 amNo. WH16NS60 firmware is recommended.marcobb0312 wrote: Fri Mar 08, 2024 7:04 pm Hi, I am planning to rip my UHD collection with DVDFab and will buy the WH16NS40 on Amazon, I assume it is FW 1.05 and SVC:NS50
For the BC-12D2HT, I really couldn't say for sure which firmware is compatible with DVDFab, You could try BC-12D2HT 3.11-MK but it may not work as most (if not all) MK firmwares don't work with DVDFab. You could then maybe flash it to BC-12D2HT 3.00 firmware if you can find it. FYI, I do not recommend that ASUS drive model!marcobb0312 wrote: Sat Mar 09, 2024 7:05 am@MartyMcNuts Thanks for your support !!!MartyMcNuts wrote: Sat Mar 09, 2024 2:56 amNo. WH16NS60 firmware is recommended.marcobb0312 wrote: Fri Mar 08, 2024 7:04 pm Hi, I am planning to rip my UHD collection with DVDFab and will buy the WH16NS40 on Amazon, I assume it is FW 1.05 and SVC:NS50
marcobb0312
Noted, thanks for your information and support !!!MartyMcNuts wrote: Sun Mar 10, 2024 1:29 amFor the BC-12D2HT, I really couldn't say for sure which firmware is compatible with DVDFab, You could try BC-12D2HT 3.11-MK but it may not work as most (if not all) MK firmwares don't work with DVDFab. You could then maybe flash it to BC-12D2HT 3.00 firmware if you can find it. FYI, I do not recommend that ASUS drive model!marcobb0312 wrote: Sat Mar 09, 2024 7:05 am@MartyMcNuts Thanks for your support !!!MartyMcNuts wrote: Sat Mar 09, 2024 2:56 am
is this Asus can be crossflashed to another FW with ability to quality check Bluray records?MartyMcNuts wrote: Sun Mar 10, 2024 1:29 am For the BC-12D2HT, I really couldn't say for sure which firmware is compatible with DVDFab, You could try BC-12D2HT 3.11-MK but it may not work as most (if not all) MK firmwares don't work with DVDFab. You could then maybe flash it to BC-12D2HT 3.00 firmware if you can find it. FYI, I do not recommend that ASUS drive model!
