Can't read AACS VID from disc
Re: Can't read AACS VID from disc
If this is an AACS issue, MakeMKV should have created a .tgz file in your MakeMKV data directory (Preferences->General to find it). AACS through version 62 should be handled by the latest version 1.10.2; if there is a newer version, the sooner Mike knows about it, the better.
Send the generated file to svq@makemkv.com for analysis. It shouldn't be very large.
Naiera
Post by Naiera »
Thank you. I don't know what else it could be. I searched using one of the error messages My Sassy Girl gave me and I found this thread. The explanation in here seemed logical, but I don't know now that it opened another older disc without any trouble.
Naiera
Post by Naiera »
And NOW the disc loaded?!
The only thing I hadn't done was restart :oops:
spas2k
Post by spas2k »
Bump.
I experienced this when trying to load "The Kitchen".
Probably want to avoid ripping that movie for now.
Edit: Files need to be mailed to svq@makemkv.com rather than be posted to the forum. Only Mike has the tools necessary to make use of them.
bboisvert
Post by bboisvert »
Had same problem with Infinity War 3D. AACS v65 and 1.14.5 Win (current as of today).
Sent TGZ file to svq@makemkv.com
sumcrynsumdien
Post by sumcrynsumdien »
I just started ripping movies today and was able to convert a Blu-Ray however I'm having this issue with two of my 4K Ultra HD dvds. I'm getting "Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive"
This is what I have from Info section:
OS device name: F:
Product: BD-RE BU40N
Revision: 1.02
Serial number: MO8Z8SG3634
Bus encryption flags: 1F
Highest AACS version: 71
Harware support: Yes
Firmware support: No
Firmware version: 1.02
Disc Information
Label: RISE OF THE PLANET OF THE APES
Timestamp: 2017-04-04 12:11:33
Protection: AACS2.0/C v61
Data capacity: 36.26 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
sumcrynsumdien wrote: Sat Mar 09, 2024 12:36 am I just started ripping movies today and was able to convert a Blu-Ray however I'm having this issue with two of my 4K Ultra HD dvds. I'm getting "Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive"
OS device name: F:
Revision: 1.02
Disc Information
Number of layers: 2
see guide below you have to flash your drive
