If this is an AACS issue, MakeMKV should have created a .tgz file in your MakeMKV data directory (Preferences->General to find it). AACS through version 62 should be handled by the latest version 1.10.2; if there is a newer version, the sooner Mike knows about it, the better.
Send the generated file to svq@makemkv.com for analysis. It shouldn't be very large.
Can't read AACS VID from disc
Re: Can't read AACS VID from disc
Thank you. I don't know what else it could be. I searched using one of the error messages My Sassy Girl gave me and I found this thread. The explanation in here seemed logical, but I don't know now that it opened another older disc without any trouble.
And NOW the disc loaded?!
The only thing I hadn't done was restart
Bump.
I experienced this when trying to load "The Kitchen".
Probably want to avoid ripping that movie for now.
Edit: Files need to be mailed to svq@makemkv.com rather than be posted to the forum. Only Mike has the tools necessary to make use of them.
Had same problem with Infinity War 3D. AACS v65 and 1.14.5 Win (current as of today).
Sent TGZ file to svq@makemkv.com
sumcrynsumdien
I just started ripping movies today and was able to convert a Blu-Ray however I'm having this issue with two of my 4K Ultra HD dvds. I'm getting "Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive"
This is what I have from Info section:
OS device name: F:
Product: BD-RE BU40N
Revision: 1.02
Serial number: MO8Z8SG3634
Bus encryption flags: 1F
Highest AACS version: 71
Harware support: Yes
Firmware support: No
Firmware version: 1.02
Disc Information
Label: RISE OF THE PLANET OF THE APES
Timestamp: 2017-04-04 12:11:33
Protection: AACS2.0/C v61
Data capacity: 36.26 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
OS device name: F:
Revision: 1.02
Disc Information
Number of layers: 2
see guide below you have to flash your drivesumcrynsumdien wrote: Sat Mar 09, 2024 12:36 am I just started ripping movies today and was able to convert a Blu-Ray however I'm having this issue with two of my 4K Ultra HD dvds. I'm getting "Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive"
OS device name: F:
Revision: 1.02
Disc Information
Number of layers: 2
