Can't open FAQ from main page
Swazirs
Post by Swazirs » Fri Dec 08, 2023 4:20 am
It's saying all that instead...
Warning: include(/home/makemkv/public_html/faq/nucleus/libs/globalfunctions.php): failed to open stream: No such file or directory in /home/u235770/makemkv.com/faq/config.php on line 31
Warning: include(): Failed opening '/home/makemkv/public_html/faq/nucleus/libs/globalfunctions.php' for inclusion (include_path='.:/nix/store/ncmrmkw1ags39sar7n38a843d9rns2xc-php-7.2.34/lib/php') in /home/u235770/makemkv.com/faq/config.php on line 31
Fatal error: Uncaught Error: Call to undefined function selector() in /home/u235770/makemkv.com/faq/index.php:12 Stack trace: #0 {main} thrown in /home/u235770/makemkv.com/faq/index.php on line 12
The problematic link is:
https://makemkv.com/faq/
Re: Can't open FAQ from main page
Post by Woodstock » Fri Dec 08, 2023 4:41 am
Maybe your message will have a subject that keeps people from reporting this... Again... And Again... And again...
F.A.Q. page gives error messages
FAQ link on main site is down.
MakeMKV FAQ Page is Broken
It's a known issue. The author has not fixed it in the past year. It could be fixed tomorrow, or in ten more years. It appears that the FAQs are there, but their linkages are screwed up (people have posted links to individual FAQs in the past week or three). But the main page is screwed up...
tronga
Post by tronga » Thu Mar 07, 2024 10:48 pm
@Woodstock
Maybe I can help here. I am a php developer and this should not be a problem at all.
Post by Woodstock » Fri Mar 08, 2024 2:13 am
Hopefully, the author will get in touch with you, if he decides to fix it. Technically, it should have been fixed (it's been repaired a few times over the past several years), but the instability of the chosen network may be an issue.
The problem started when the world started enforcing "thou shalt not even talk about things like this". It's gotten worse since the sanctions-that-aren't-sanctions started against anything involving Russia.
And it hasn't helped that Mike hasn't always kept up with domain payments... :roll:
