Green Wing (BBC comedy) PAL conversion issues
RobAinscough
Post by RobAinscough » Fri Feb 09, 2024 9:40 pm
I tried to convert Disc 1 of Season 1 (Episodes 1-3) but sadly only Episode 1 converted correctly. Getting a lot of "is corrupt..." and "UNCORRECTABLE ERROR".
I've attached the log and was hoping for some input. I'm converting thru one of Billy's drives BDR-S13U with firmware update which is not restricted by region. The drive has worked flawlessly in other conversions just these Green Wing DVDs.
I do have a non Region specific 4K external DVD/BD player that has no problem playing these DVDs back on my NTSC based TV so the DVDs are "good" (i.e. not corrupted).
Any suggestions welcome.
Cheers, Rob.
EDIT: it seems this forum will not allow me to attach logs so here is the Log File
An image: Image
It is far better to grasp the universe as it really is than to persist in delusion, however satisfying and reassuring. - Carl Sagan
Re: Green Wing (BBC comedy) PAL conversion issues
Post by dcoke22 » Mon Feb 12, 2024 3:44 pm
The standard advice is to gently clean the disc and try again.
The log you linked to suggests 6 titles were saved from the rip. But perhaps among the 6 titles saved not all 3 episodes made it?
Debug log started at Fri Feb 09 19:51:53 2024 , written by MakeMKV v1.17.6 win(x64-release)
001005:0000 MakeMKV v1.17.6 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\Rob/MakeMKV_log.txt
DEBUG: Code 3 at (Fjq;j%;wku%(|]PM?.".JoL:29395310
SDF  v098: PIONEER_BD-RW___BDR-S13U_1.03_CGDL300959UC
001011:0000 Using LibreDrive mode (v01.0 id=DFE22909F92F)
003002:0000 Calculated BUP offset for VTS #5 does not match one in IFO header.
003002:0000 Calculated BUP offset for VTS #6 does not match one in IFO header.
003002:0000 Calculated BUP offset for VTS #7 does not match one in IFO header.
003002:0000 Calculated BUP offset for VTS #13 does not match one in IFO header.
Launching C:\Program Files (x86)\MakeMKV\mmgplsrv64.exe
001003:0020 DEBUG: Code 100864261 at SM@e63jNU)cu"$Qt:121271617
001003:0020 DEBUG: Code 100864261 at =a$)zM@!&N!1NmNa:213130559
001003:0020 DEBUG: Code 100864261 at C')Ei;RW<@zk PamDG:121263429
001003:0020 DEBUG: Code 100864261 at C')Ei;RW<@zk PamDG:121262302
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-RE PIONEER BD-RW   BDR-S13U 1.03 CGDL300959UC' at offset '1808635904'
001003:0020 DEBUG: Code 6 at 0`Ya?1$!|%$JJIlO4"I>U-z:29395586
001003:0020 DEBUG: Code 883123 at 0`Ya?1$!|%$JJIlO4"I>U-z:213131939
001003:0020 DEBUG: Code 1693 at _y<{y.H`KydrY`/TJ{+d:213133250
001003:0020 DEBUG: Code 151060481 at _y<{y.H`KydrY`/TJ{+d:121265062
001003:0020 DEBUG: Code 1 at _y<{y.H`KydrY`/TJ{+d:29394689
001003:0020 DEBUG: Code 1 at 0`Ya?1$!|%$JJIlO4"I>U-z:121263636
001003:0020 DEBUG: Code 0 at /u`0WKB|YXK!?|:29397104
003039:0000 Fake cells occupy 58% of the title - assuming fake title
Title skip vts=1 pgcn=1
Title skip vts=2 pgcn=1
003039:0000 Fake cells occupy 59% of the title - assuming fake title
Title skip vts=3 pgcn=1
Title skip vts=4 pgcn=1
003037:0000 Cells 1-5 were removed from title start
003028:0000 Title #5 was added (5 cell(s), 0:50:43)
001003:0020 DEBUG: Code 883160 at rsi1O0~:)@a]=L:29396184
001003:0020 DEBUG: Code 0 at irJ+9p}J=tW`\K/qad:121273641
001003:0020 DEBUG: Code 0 at irJ+9p}J=tW`\K/qad:121274699
003015:0000 Title #6 (0:51:19) was skipped due to navigation error
Title skip vts=6 pgcn=1
001003:0020 DEBUG: Code 22163 at rsi1O0~:)@a]=L:29396184
003015:0000 Title #7 (0:50:55) was skipped due to navigation error
Title skip vts=7 pgcn=1
003028:0000 Title #8 was added (1 cell(s), 0:06:18)
003028:0000 Title #9 was added (1 cell(s), 0:06:18)
003028:0000 Title #10 was added (1 cell(s), 0:06:18)
003028:0000 Title #11 was added (1 cell(s), 0:06:18)
003025:0000 Title #12 has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003028:0000 Title #13 was added (1 cell(s), 0:13:03)
003010:0000 Can't locate a cell for VTS 5 TTN 2 PGCN 2 PGN 2
DEBUG: Code 83886597 at |-aSyP%N%/'o_7a$:29397265
Title skip vts=5 pgcn=2
003010:0000 Can't locate a cell for VTS 6 TTN 2 PGCN 2 PGN 2
DEBUG: Code 100663813 at |-aSyP%N%/'o_7a$:29397265
Title skip vts=6 pgcn=2
003010:0000 Can't locate a cell for VTS 7 TTN 2 PGCN 2 PGN 2
DEBUG: Code 117441029 at |-aSyP%N%/'o_7a$:29397265
Title skip vts=7 pgcn=2
003010:0000 Can't locate a cell for VTS 13 TTN 2 PGCN 2 PGN 2
DEBUG: Code 218104325 at |-aSyP%N%/'o_7a$:29397265
Title skip vts=13 pgcn=2
004004:0000 The source file '/VIDEO_TS/VTS_05_1.VOB' is corrupt or invalid at offset 51200, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_05_1.VOB' is corrupt or invalid at offset 53248, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_13_1.VOB' is corrupt or invalid at offset 51200, attempting to work around
005014:0000 Saving 6 titles into directory file://E:/Video/DVD_VIDEO_A77F
AV sync issues in E:/Video/DVD_VIDEO_A77F/title_t00.mkv
AV sync in 1 at 0:00:00 (192ms) : 6 frame(s) dropped to reduce audio skew to +32ms
AV sync in 2 at 0:00:00 (192ms) : 6 frame(s) dropped to reduce audio skew to +32ms
AV sync in 1,2 at 0:00:00 (224ms) : encountered overlapping frame, audio skew is +32ms
AV sync issues in E:/Video/DVD_VIDEO_A77F/title_t05.mkv
AV sync in 1 at 0:00:00 (224ms) : encountered overlapping frame, audio skew is +32ms
005005:0080 6 titles saved
005036:0104 Copy complete. 6 titles saved.
Application exited at Fri Feb 09 20:48:20 2024
RobAinscough
Post by RobAinscough » Mon Feb 12, 2024 4:39 pm
Thanks for the response. The DVD plays fine in my ALL Region DVD/BD player, just makeMKV doesn't seem to like it ... yes, inspected the disc and tried cleaning but sadly no difference.
1 of the 3 episodes comes out fine. Episode 3 is partial (not complete). All the other outputs are smaller files and play in a repeat of what looks like DVD menu in a loop.
I'm guessing this error in the log: "Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR" is likely the problem. Perhaps some copy protection trickery?
Cheers, Rob.
Post by Billycar11 » Mon Feb 12, 2024 10:52 pm
Nah that's just a read error from a dirty or scratched disc clean the disc and then try.
Clean it with a damp lint free microfiber and then dry immediately with another to avoid water spots
RobAinscough
Post by RobAinscough » Mon Feb 12, 2024 11:35 pm
I'll give it a go ... I used to use mild dishwasher (Dawn) liquid soap and water.
Cheers, Rob.
RobAinscough
Post by RobAinscough » Tue Feb 13, 2024 5:33 am
You were correct, tried cleaning but still no go, so I put the disk under my scope and took some pics of the damage:
Weird burn mark?
Many pits
Big scratch
Not sure how the disc got that way, I'm usually VERY care with my DVD/BD collection.
Cheers, Rob.
thegrinder01
Post by thegrinder01 » Wed Mar 06, 2024 5:45 pm
I'd just like to offer my thanks for this advice as it has enabled me to rip 3 x UHD discs that previously failed to read fully! Thank you :D
dmdmmatt4
Post by dmdmmatt4 » Sat Mar 16, 2024 8:42 am
Weird burn mark?
Cheers, Rob.
The first pic is possibly delamination?
But yes you have a bad disk there. "Challenging", to say the least. Newest Makemkv has new damage workaround voodoo which seems to be very effective, might want to give it a try with the latest download but who knows..
pneumatic
Post by pneumatic » Sat Mar 23, 2024 2:47 am
Cheers, Rob.
If you're still having issues try isopropyl alcohol, it has magical properties where it just lifts and evaporates everything off the surface.
Dish soap works ok but I reckon it leaves an invisible residue even after rinsing. Try washing your hands with dish soap, do they feel slightly different afterwards? More grippy and sticky perhaps?
I have noticed water can actually penetrate between the layers of the inner ring - alcohol just evaporates so quickly it doesn't have this issue.
