Expendables 4 Blu-Ray
Terasaka
#1 Post by Terasaka » Wed Mar 06, 2024 1:00 pm
Unable to save Title.
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/02798.m2ts' at offset '2533158912'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk4' at offset '2533158912'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/02798.m2ts' at offset '2533355520'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk4' at offset '2533355520'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/02798.m2ts' at offset '2533490688'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk4' at offset '2533490688'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/02798.m2ts' at offset '2533687296'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk4' at offset '2533687296'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/02798.m2ts' at offset '2533883904'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk4' at offset '2533883904'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/02798.m2ts' at offset '2534012928'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk4' at offset '2534012928'
Error 'Scsi error - HARDWARE ERROR:441E' occurred while reading '/BDMV/STREAM/02798.m2ts' at offset '2534209536'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk4' at offset '2534209536'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/02798.m2ts' at offset '2534209536'
Error 'Scsi error - MEDIUM ERROR:POSITIONING ERROR DETECTED BY READ OF MEDIUM' occurred while reading '/BDMV/STREAM/02798.m2ts' at offset '2534209536'
Re: Expendables 4 Blu-Ray
#2 Post by dcoke22 » Wed Mar 06, 2024 1:57 pm
Errors like this:
mean the optical drive was unable to correctly read the optical disc. The standard advice is to gently clean the disc (even if it is brand new) and try again.
Terasaka
#3 Post by Terasaka » Wed Mar 06, 2024 4:58 pm
Did that already, still running into the read issues. I'll take another look though. Thanks so much.
