Expendables 4 Blu-Ray
Terasaka
Post by Terasaka »
Unable to save Title.
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/02798.m2ts' at offset '2533158912'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk4' at offset '2533158912'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/02798.m2ts' at offset '2533355520'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk4' at offset '2533355520'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/02798.m2ts' at offset '2533490688'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk4' at offset '2533490688'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/02798.m2ts' at offset '2533687296'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk4' at offset '2533687296'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/02798.m2ts' at offset '2533883904'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk4' at offset '2533883904'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/02798.m2ts' at offset '2534012928'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk4' at offset '2534012928'
Error 'Scsi error - HARDWARE ERROR:441E' occurred while reading '/BDMV/STREAM/02798.m2ts' at offset '2534209536'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk4' at offset '2534209536'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/02798.m2ts' at offset '2534209536'
Error 'Scsi error - MEDIUM ERROR:POSITIONING ERROR DETECTED BY READ OF MEDIUM' occurred while reading '/BDMV/STREAM/02798.m2ts' at offset '2534209536'
Re: Expendables 4 Blu-Ray
Errors like this:
mean the optical drive was unable to correctly read the optical disc. The standard advice is to gently clean the disc (even if it is brand new) and try again.
Terasaka
Post by Terasaka »
Did that already, still running into the read issues. I'll take another look though. Thanks so much.
