BP60NB10 Still Not Working
766875
Post by 766875 »
Just received and flashed the LG BP60NB10 on my Mac. Everything went smoothly, after flashing in terminal it said drive was successfully flashed. Yet when I got to run MakeMKV with Fury 4K I get the following error messages:
MakeMKV v1.17.6 darwin(x64-release) started
Optical drive "BD-RE HL-DT-ST BD-RE BP60NB10 1.02 SIM04NBHA3230d" opened in OS access mode.
Error 'OS error - (ipc/send) invalid destination port' occurred while reading 'BD-RE HL-DT-ST BD-RE BP60NB10 1.02 SIM04NBHA3230' at offset '1179648'
udf: node fe/efe failed!
Error 'OS error - (ipc/send) invalid destination port' occurred while reading 'BD-RE HL-DT-ST BD-RE BP60NB10 1.02 SIM04NBHA3230' at offset '2555904'
Error 'OS error - (ipc/send) invalid destination port' occurred while reading 'BD-RE HL-DT-ST BD-RE BP60NB10 1.02 SIM04NBHA3230' at offset '2576384'
Error 'OS error - (ipc/send) invalid destination port' occurred while reading 'BD-RE HL-DT-ST BD-RE BP60NB10 1.02 SIM04NBHA3230' at offset '720896'
Error 'OS error - (ipc/send) invalid destination port' occurred while reading 'BD-RE HL-DT-ST BD-RE BP60NB10 1.02 SIM04NBHA3230' at offset '2359296'
Error 'OS error - (ipc/send) invalid destination port' occurred while reading 'BD-RE HL-DT-ST BD-RE BP60NB10 1.02 SIM04NBHA3230' at offset '1441792'
Error 'OS error - (ipc/send) invalid destination port' occurred while reading 'BD-RE HL-DT-ST BD-RE BP60NB10 1.02 SIM04NBHA3230' at offset '1472512'
Error 'OS error - (ipc/send) invalid destination port' occurred while reading 'BD-RE HL-DT-ST BD-RE BP60NB10 1.02 SIM04NBHA3230' at offset '1482752'
Error 'OS error - (ipc/send) invalid destination port' occurred while reading 'BD-RE HL-DT-ST BD-RE BP60NB10 1.02 SIM04NBHA3230' at offset '1187840'
Error 'OS error - (ipc/send) invalid destination port' occurred while reading 'BD-RE HL-DT-ST BD-RE BP60NB10 1.02 SIM04NBHA3230' at offset '1449984'
Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/AACS/MKB_RO.inf' at offset '0'
Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/AACS/Content000.cer' at offset '0'
Re: BP60NB10 Still Not Working
power issue use both usb cables on separate usb circuits or buy a high powered usb hub
766875
Post by 766875 »
I asked for help, not try to be sold something.
766875
Post by 766875 »
I put the USB's on separate power but still having problems.
Tried to refresh again and it was supposedly successful. Using DE_LG_BP60NB10-NB12_1.02-MK.bin
Current Drive ID: HL-DT-ST_BD-RE_BP60NB10_1.02_*****
Using USB chipset workaround for Desktop drive handshake
yes
 100% Operation finished
Done successfully
But when I go to read a disk I get
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..002000800 to device 'IoKit:/IOBDServices/4E90C431'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'IoKit:/IOBDServices/4E90C431'
Downloading latest HK to /Users/Library/MakeMKV ...
Saved AACS dump file as /Users/Library/MakeMKV/MKB21_v61_Fury_5259.tgz
766875 wrote:
Wed Mar 06, 2024 1:39 am
yes
Done successfully
was not trying to sell you anything but yeah but yeah buying a pioneer from me would fix that issue so buy one lol.
but yeah you removed all the useful info post your drive info in text so it posts we will see if its flashed right
766875
Post by 766875 »
Just want to say I apologize, read it while rushing between something after a bad meeting and for whatever reason read your sig, not your message first. I take back what I said.
Info:
OS device name: /dev/rdisk4
Product: BD-RE BP60NB10
Revision: 1.02
Serial number: *****
Firmware date: 2121-07-08 15:56
Highest AACS version: 61
Harware support: Yes
Firmware support: No
Firmware version: 1.02
Disc Information
Label: FURY
Timestamp: 2018-03-12 13:12:01
Protection: AACS2.1/C v61
Data capacity: 91.2 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
Logs:
MakeMKV v1.17.6 darwin(arm64-release) started
Optical drive "BD-RE HL-DT-ST BD-RE BP60NB10 1.02 ********" opened in OS access mode.
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'IoKit:/IOBDServices/4E90C431'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..03F to device 'IoKit:/IOBDServices/4E90C431'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..07F to device 'IoKit:/IOBDServices/4E90C431'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..07F to device 'IoKit:/IOBDServices/4E90C431'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0BF to device 'IoKit:/IOBDServices/4E90C431'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0BF to device 'IoKit:/IOBDServices/4E90C431'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0FF to device 'IoKit:/IOBDServices/4E90C431'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0FF to device 'IoKit:/IOBDServices/4E90C431'
so you are actually getting another error from the first one the first was power now you have key exchange issue as you did not flash your drive correctly you likely forgot enc reflash with that see the guide again then it should work
766875
Post by 766875 »
Looking at the guide it says
"BP60NB10 on any Firmware directly to > BP60NB10 1.02MK" Which is what I did. I don't see an 'enc' flash specific for this drive. Could you elaborate? I'm struggling a bit here just throwing firmwares at it in the hopes it works. I saw another user with the same drive who flashed it in the same way as me and his worked. Struggling a bit here.
766875 wrote:
Wed Mar 06, 2024 4:54 am
viewtopic.php?f=16&t=19634#:~:text=or%2 ... ted%20list
766875
Post by 766875 »
I've been reading that over and over again. I followed the MacOS CLI instructions and it seems to successfully flash without any error messages. I've tried both of these firmwares.
./makemkvcon f -d '/IOBDServices/4E90C431' -f /Users/Downloads/sdf.bin rawflash main -i /Users/Downloads/DE_LG_BP60NB10-NB12_1.02-MK.bin
./makemkvcon f -d '/IOBDServices/4E90C431' -f /Users/Downloads/sdf.bin rawflash main -i /Users/Downloads/HL-DT-ST-BD-RE_BP60NB10-1.02-NM00800-212005070935.bin
And I still get the big error shown above whenever I try and read the disk in MakeMKV. So I don't know what it is I'm missing? There's no further instruction on the post and as I don't have a Windows machine I can't try the other GUI tools.
766875 wrote:
Wed Mar 06, 2024 5:28 am
not main use enc!!
766875
Post by 766875 »
So like this?
./makemkvcon f -d '/IOBDServices/4E90C431' -f /Users/Downloads/sdf.bin rawflash enc -i /Users/Downloads/DE_LG_BP60NB10-NB12_1.02-MK.bin
Also which firmware should I use?
Do I have to do further steps after this?
yeah
either will work
766875
Post by 766875 »
Huzzah, that worked! Thanks Billy, much appreciated. Perhaps it would be useful to add that specific 'rawflash enc' under the linux/macOS instructions for future users.
766875 wrote:
Wed Mar 06, 2024 5:42 am
it is!!!
bottom of step 7.
